* 红外接收数据,查询方式,并通过串口发送 * * 晶振:11.0592M */ #include typedef unsigned char uint8; ***it Ir_Pin = P3^3; uint8 Ir_Buf[4]; //用于保存解码结果 /* * UART初始化 * 波特率:9600 */ void uart_init(void) { TMOD = 0x21; //此处使用两个定时器发生中断 SCON = 0x50; TH1 = 0xFD; TL1 = 0xFD; TR1 = 1; } /* * UART发送一字节 */ void UART_Send_Byte(uint8 dat) { SBUF = dat; while (ti == 0); TI = 0; } /* * 获取低电平时间 */ unsigned int Ir_Get_Low() { TL0 = 0; TH0 = 0; TR0 = 1; while (!Ir_Pin && (TH0&0x80)==0); /*此处不明白为什么TH0要与上0x80*/ TR0 = 0; return (TH0 * 256 + TL0); //把十进制数转换一把 } /* * 获取高电平时间 */ unsigned int Ir_Get_High() { TL0 = 0; TH0 = 0; TR0 = 1; while (Ir_Pin && (TH0&0x80)==0); TR0 = 0; return (TH0 * 256 + TL0); } main() { unsigned int temp; char i,j; uart_init(); while (1) { start: //此数为goto语句的用法 while (Ir_Pin); temp = Ir_Get_Low(); // 获取低电平的时间 if ((temp < 7833) || (temp > 8755)) //引导脉冲低电平8500~9500us goto start; temp = Ir_Get_High(); //获取高电平的时间 if ((temp < 3686) || (temp > 4608)) //引导脉冲高电平4000~5000us goto start; for (i=0; i<4; i++) //4个字节 { for (j=0; j<8; j++) //每个字节8位 { temp = Ir_Get_Low(); if ((temp < 184) || (temp > 737)) //200~800us goto start; temp = Ir_Get_High(); if ((temp < 184) || (temp > 1843)) //200~2000us goto start; Ir_Buf[i] >>= 1; if (temp > 1032) //1120us Ir_Buf[i] |= 0x80; } } UART_Send_Byte(Ir_Buf[0]); UART_Send_Byte(Ir_Buf[1]); UART_Send_Byte(Ir_Buf[2]); UART_Send_Byte(Ir_Buf[3]); } } |
5 个讨论
只有小组成员才能发言,加入小组>>
GMT+8, 2024-4-24 07:07 , Processed in 0.344832 second(s), Total 44, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
