datasheet阅读攻略.pdf
(278.63 KB, 下载次数: 9
datasheet阅读攻略 How to Read a Datasheet Prepared for the WIMS outreach program 5/6/02, D. Grover In order to use a PIC microcontroller, a flip-flop, a photodetector, or practically any electronic device, you need to consult a datasheet. This is the document that the manufacturer provides telling you • the typical device performance • minimum and maximum requirements and characteristics • what you can do to the device without harming it • suggested uses and hints Manufacturers want you, the designer, to have a successful experience with their device. They are trying to be helpful. They don’t always succeed. The datasheet on the following pages is a relatively good datasheet. It tries to concisely tell you everything you need to know about the device, a common 555 timer chip (the duct-tape of the electronics hobbyist). Most datasheets for ICs follow the same general layout. You don’t have to understand everything in a datasheet. There’s a lot of information that might not be of any use to you. The annotations that follow try to point out parts of the datasheet that you should pay particular attention to. Where do you find datasheets? Nowadays you can find almost any datasheet on the internet, often in PDF (Acrobat) form. For example, the LM555 datasheet from National Semiconductor is on their website at |
3268 浏览 0 评论
5342 浏览 0 评论
《电子工程师必备——九大系统电路识图宝典》之浅读负反馈以及四种组态
4042 浏览 0 评论
2039 浏览 0 评论
59495 浏览 0 评论
GMT+8, 2024-4-20 13:50 , Processed in 0.451890 second(s), Total 62, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
