STM8的C语言编程.doc
STM8的C语言编程(1)基本程序与启动代码分析现在几乎所有的单片机都能用C语言编程了,采用C语言编程确实能带来很多好处,至少可读性比汇编语言强多了。在STM8的开发环境中,可以通过新建一个工程,自动地建立起一个C语言的框架,生成后开发环境会自动生成2个C语言的程序,一个是main.c,另一个是stm8_interrupt_vector.c。main.c中就是一个空的main函数,如下所示/* MAIN.C file* * Copyright c 2002-2005 STMicroelectronics*/main while 1;而在stm8_interrupt_vector.c中,就是声明了对应该芯片的中断向量,如下所示/* BASIC INTERRUPT VECTOR TABLE FOR STM8 devices* Copyright c 2007 STMicroelectronics*/typedef void far *interrupt_handler_tvoid;struct interrupt_vector unsigned char interrupt_instruction; interrupt_handler_t interrupt_handlerfar interrupt void NonHandledInterrupt void /* in order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction */ return;extern void _stext; /* startup routine */struct interrupt_vector const _vectab 0 x82, interrupt_handler_t_stext, /* reset */ 0 x82, NonHandledInterrupt, /* trap */ 0 x82, NonHandledInterrupt, /* irq0 */ 0 x82, NonHandledInterrupt, /* irq1 */ 0 x82, NonHandledInterrupt, /* irq2 */ 0 x82, NonHandledInterrupt, /* irq3 */ 0 x82, NonHandledInterrupt, /* irq4 */ 0 x82, NonHandledInterrupt, /* irq5 */ 0 x82, NonHandledInterrupt, /* irq6 */ 0 x82, NonHandledInterrupt, /* irq7 */ 0 x82, NonHandledInterrupt, /* irq8 */ 0 x82, NonHandledInterrupt, /* irq9 */ 0 x82, NonHandledInterrupt, /* irq10 */ 0 x82, NonHandledInterrupt, /* irq11 */ 0 x82, NonHandledInterrupt, /* irq12 */ 0 x82, NonHandledInterrupt, /* irq13 */ 0 x82, NonHandledInterrupt, /* irq14 */ 0 x82, NonHandledInterrupt, /* irq15 */ 0 x82, NonHandledInterrupt, /* irq16 */ 0 x82, NonHandledInterrupt, /* irq17 */ 0 x82, NonHandledInterrupt, /* irq18 */ 0 x82, NonHandledInterrupt, /* irq19 */ 0 x82, NonHandledInterrupt, /* irq20 */ 0 x82, NonHandledInterrupt, /* irq21 */ 0 x82, NonHandledInterrupt, /* irq22 */ 0 x82, NonHandledInterrupt, /* irq23 */ 0 x82, NonHandledInterrupt, /* irq24 */ 0 x82, NonHandledInterrupt, /* irq25 */ 0 x82, NonHandledInterrupt, /* irq26 */ 0 x82, NonHandledInterrupt, /* irq27 */ 0 x82, NonHandledInterrupt, /* irq28 */ 0 x82, NonHandledInterrupt, /* irq29 */;在stm8_interrupt_vector.c中,除了定义了中断向量表外,还定义了空的中断服务程序,用于那些不用的中断。当然在自动建立时,所有的中断服务都是空的,因此,除了第1个复位的向量外,其它都指向那个空的中断服务函数。生成框架后,就可以用Build菜单下的Rebuild All对项目进行编译和连接,生成所需的目标文件,然后就可以加载到STM8的芯片中,这里由于main函数是一个空函数,因此没有任何实际的功能。不过我们可以把这个框架对应的汇编代码反出来,看看C语言生成的代码,这样可以更深入地了解C语言编程的特点。生成的代码包括4个部分,如图1、图2、图3、图4所示。 图1 图2 图3 图4 图1显示的是从内存地址8000H开始的中断向量表,中断向量表中的第1行82008083H为复位后单片机运行的第1跳指令的地址。从表中可以看出,单片机复位后,将从8083H开始运行。其它行的中断向量都指向同一个位置的中断服务程序80D0H。 图2显示的是3个字节,前2个字节8083H为复位后的第1条指令的地址,第3个字节是一个常量0,后面的启动代码要用到。 图3显示的是启动代码,启动代码中除了初始化堆栈指针外,就是初始化RAM单元。由于目前是一个空的框架,因此在初始化完堆栈指针(设置成0FFFH)后,由于8082H单元的内容为0,因此程序就跳到了80B1H,此处是一个循环,将RAM单元从0到5初始化成0。然后由于寄存器X设置成0100H,就直接通过CALL main进入C的main函数。 图4显示的是main函数和中断服务函数,main函数对应的代码就是一个无限的循环,而中断服务函数就一条指令,即中断返回指令。 通过分析,可以看出用C语言编程时,比汇编语言编程时,就是多出了一段启动代码。 STM8的C语言编程(2) 变量空间的分配采用C这样的高级语言,其实可以不用关心变量在存储器空间中是如何具体分配的。但如果了解如何分配,对编程还是有好处的,尤其是在调试时。例如下面的程序定义了全局变量数组buffer和一个局部变量i,在RAM中如何分配的呢/* MAIN.C file* * Copyright c 2002-2005 STMicroelectronics*/unsigned char buffer10; 定义全局变量main unsigned char i; 定义局部变量 fori0;i10;i bufferi 0 x55; 我们可以通过DEBUG中的反汇编窗口,看到如下的对应代码从这段代码中可以看到,全局变量buffer被分配到空间从地址0000H到0009H。而局部变量i则在堆栈空间中分配,通过PUSH A指令,将堆栈指针减1,腾出一个字节的空间,而SP1指向的空间就是分配给局部变量使用的空间。由此可以得出初步的结论,对于全局变量,内存分配是从低地址0000H开始向上分配的。而局部变量则是在堆栈空间中分配。另外从上一篇文章中,可以知道堆栈指针初始化时为0FFFH。而根据PUSH指令的定义,当压栈后堆栈指针减1。因此堆栈是从上往下使用的。因此根据内存分配和堆栈使用规则,我们在程序设计时,不能定义过多的变量,免得没有空间给堆栈使用。换句话说,当定义变量时,一定要考虑到堆栈空间,尤其是那些复杂的系统,程序调用层数多,这样就会占用大量的堆栈空间。总之,在单片机的程序设计时,由于RAM空间非常有限,要充分考虑到全局变量、局部变量、程序调用层数和中断服务调用对空间的占用。 STM8的C语言编程(3) GPIO输出与前些日子写的用汇编语言进行的实验一样,从今天开始,要在ST的三合一开发板上,用C语言编写程序,进行一系列的实验。首先当然从最简单的LED指示灯闪烁的实验开始。开发板上的LED1接在STM8的PD3上,因此要将PD3设置成输出模式,为了提高高电平时的输出电流,要将其设置成推挽输出方式。这主要通过设置对应的DDR/CR1/CR2寄存器实现。利用ST的开发工具,先生成一个C语言程序的框架,然后修改其中的main.c,修改后的代码如下。编译通过后,下载到开发板,运行程序,可以看到LED1在闪烁,且闪烁的频率为5HZ。/* MAIN.C file* * Copyright c 2002-2005 STMicroelectronics*/include STM8S207C_S.h 函数功能延时函数 输入参数ms 要延时的毫秒数,这里假设CPU的主频为2MHZ 输出参数无 返 回 值无 备 注无void DelayMSunsigned int ms unsigned char i; whilems 0 fori0;i250;i fori0;i75;i ms; 函数功能主函数 初始化GPIO端口PD3,驱动PD3为高电平和低电平 输入参数ms 要延时的毫秒数,这里假设CPU的主频为2MHZ 输出参数无 返 回 值无 备 注无main PD_DDR 0 x08; PD_CR1 0 x08; 将PD3设置成推挽输出 PD_CR2 0 x00; while1 PD_ODR PD_ODR | 0 x08; 将PD3的输出设置成1 DelayMS100; 延时100MS PD_ODR PD_ODR 将PD3的输出设置成0 DelayMS100; 延时100MS 需要注意的是,当生成完框架后,为了能方便使用STM8的寄存器名字,必须包括STM8S207C_S.h,最好将该文件拷贝到CProgram FilesSTMicroelectronicsst_toolsetinclude目录下,拷贝到工程目录下。或者将该路径填写到该工程的Settings中的C Compiler选项Preprocessor的Additional include中,这样编译时才会找到该文件。 STM8的C语言编程(4) GPIO输出和输入今天要进行的实验,是利用GPIO进行输入和输出。在ST的三合一开发板上,按键接在GPIO的PD7上,LED接在GPIO的PD3上,因此我们要将GPIO的PD7初始化成输入,PD3初始化成输出。关于GPIO的引脚设置,主要是要初始化方向寄存器DDR,控制寄存器1(CR1)和控制寄存器2(CR2),寄存器的每一位对应GPIO的每一个引脚。具体的设置功能定义如下DDR CR1 CR2 引脚设置0 0 0 悬浮输入0 0 1 上拉输入0 1 0 中断悬浮输入0 1 1 中断上拉输入1 0 0 开漏输出1 1 0 推挽输出1 X 1 输出(最快速度为10MHZ)另外,输出引脚对应的寄存器为ODR,输入引脚对应的寄存器为IDR。下面的程序是检测按键的状态,当按键按下时,点亮LED,当按键抬起时,熄灭LED。同样也是利用ST的开发工具,先生成一个C语言程序的框架,然后修改其中的main.c,修改后的代码如下。编译通过后,下载到开发板,运行程序,按下按键,LED就点亮,抬起按键,LED就熄灭了。另外,要注意,将STM8S207C_S.h拷贝到当前项目的目录下。 程序描述检测开发板上的按键,若按下,则点亮LED,若抬起,则熄灭LED 按键接在MCU的GPIO的PD7上 LED接在MCU的GPIO的PD3上include STM8S207C_S.hmain PD_DDR 0 x08; PD_CR1 0 x08; 将PD3设置成推挽输出 PD_CR2 0 x00; while1 进入无限循环 ifPD_IDR 如果PD7为1,则将PD3的输出设置成0,熄灭LED else PD_ODR PD_ODR | 0 x08; 否则,将PD3的输出设置成1,点亮LED STM8的C语言编程(5)8位定时器应用之一在STM8单片机中,有多种定时器资源,既有8位的定时器,也有普通的16位定时器,还有高级的定时器。今天的实验是用最简单的8位定时器TIM4来进行延时,然后驱动LED闪烁。为了简单起见,这里是通过程序查询定时器是否产生更新事件,来判断定时器的延时是否结束。同样还是利用ST的开发工具,生成一个C程序的框架,然后修改其中的main.c,修改后的代码如下。编译通过后,下载到开发板,运行程序,可以看到LED在闪烁,或者用示波器可以在LED引脚上看到方波。在这里要特别提醒的是,从ST给的手册上看,这个定时器中的计数器是一个加1计数器,但本人在实验过程中感觉不太对,经过反复的实验,我认为应该是一个减1计数器(也许是我拿的手册不对,或许是理解上有误)。例如,当给定时器中的自动装载寄存器装入255时,产生的方波频率最小,就象下面代码中计算的那样,产生的方波频率为30HZ左右。若初始化时给自动装载寄存器装入1,则产生的方波频率最大,大约为3.9K左右。也就是说实际的分频数为ARR寄存器的值1。 程序描述通过初始化定时器4,进行延时,驱动LED闪烁 LED接在MCU的GPIO的PD3上include STM8S207C_S.hmain 首先初始化GPIO PD_DDR 0 x08; PD_CR1 0 x08; 将PD3设置成推挽输出 PD_CR2 0 x00; 然后初始化定时器4 TIM4_IER 0 x00; 禁止中断 TIM4_EGR 0 x01; 允许产生更新事件 TIM4_PSCR 0 x07; 计数器时钟主时钟/1282MHZ/128 相当于计数器周期为64uS TIM4_ARR 255; 设定重装载时的寄存器值,255是最大值 TIM4_CNTR 255; 设定计数器的初值 定时周期ARR1*6416320uS TIM4_CR1 0 x01; b0 1,允许计数器工作 b1 0,允许更新 设置控制器,启动定时器 while1 进入无限循环 whileTIM4_SR1 等待更新标志 TIM4_SR1 0 x00; 清除更新标志 PD_ODR PD_ODR 0 x08; LED驱动信号取反 LED闪烁频率2MHZ/128/255/230.63 STM8的C语言编程(6)8位定时器应用之二今天进行的实验依然是用定时器4,只不过改成了用中断方式来实现,由定时器4的中断服务程序来驱动LED的闪烁。实现中断方式的关键点有几个,第一个关键点就是要打开定时器4的中断允许位,在定时器4的IER寄存器中有定义。第二个关键点,就是打开CPU的全局中断允许位,在汇编语言中,就是执行RIM指令,在C语言中,用下列语句实现_asmrim;第3个关键点就是中断服务程序的框架或写法,中断服务程序的写法如下far interrupt void TIM4_UPD_OVF_IRQHandler void 下面是中断服务程序的实体 第4个关键点就是要设置中断向量,即将中断服务程序的入口填写到中断向量表中,如下所示,将IRQ23对应的中断服务程序的入口填写成TIM4_UPD_OVF_IRQHandlerstruct interrupt_vector const _vectab 0 x82, interrupt_handler_t_stext, /* reset */ 0 x82, NonHandledInterrupt, /* trap */ 0 x82, NonHandledInterrupt, /* irq0 */ 0 x82, NonHandledInterrupt, /* irq1 */ 0 x82, NonHandledInterrupt, /* irq2 */ 0 x82, NonHandledInterrupt, /* irq3 */ 0 x82, NonHandledInterrupt, /* irq4 */ 0 x82, NonHandledInterrupt, /* irq5 */ 0 x82, NonHandledInterrupt, /* irq6 */ 0 x82, NonHandledInterrupt, /* irq7 */ 0 x82, NonHandledInterrupt, /* irq8 */ 0 x82, NonHandledInterrupt, /* irq9 */ 0 x82, NonHandledInterrupt, /* irq10 */ 0 x82, NonHandledInterrupt, /* irq11 */ 0 x82, NonHandledInterrupt, /* irq12 */ 0 x82, NonHandledInterrupt, /* irq13 */ 0 x82, NonHandledInterrupt, /* irq14 */ 0 x82, NonHandledInterrupt, /* irq15 */ 0 x82, NonHandledInterrupt, /* irq16 */ 0 x82, NonHandledInterrupt, /* irq17 */ 0 x82, NonHandledInterrupt, /* irq18 */ 0 x82, NonHandledInterrupt, /* irq19 */ 0 x82, NonHandledInterrupt, /* irq20 */ 0 x82, NonHandledInterrupt, /* irq21 */ 0 x82, NonHandledInterrupt, /* irq22 */ 0 x82, TIM4_UPD_OVF_IRQHandler,/* irq23 */ 0 x82, NonHandledInterrupt, /* irq24 */ 0 x82, NonHandledInterrupt, /* irq25 */ 0 x82, NonHandledInterrupt, /* irq26 */ 0 x82, NonHandledInterrupt, /* irq27 */ 0 x82, NonHandledInterrupt, /* irq28 */ 0 x82, NonHandledInterrupt, /* irq29 */;解决了以上4个关键点,我们就能很轻松地用C语言实现中断服务了。同样还是利用ST的开发工具,生成一个C程序的框架,然后修改其中的main.c,修改后的代码如下。另外还要修改stm8_interrupt_vector.c。编译通过后,下载到开发板,运行程序,可以看到LED在闪烁,或者用示波器可以在LED引脚上看到方波。 修改后的main.c如下 程序描述通过初始化定时器4,以中断方式驱动LED闪烁 LED接在MCU的GPIO的PD3上include STM8S207C_S.hmain 首先初始化GPIO PD_DDR 0 x08; PD_CR1 0 x08; 将PD3设置成推挽输出 PD_CR2 0 x00; 然后初始化定时器4 TIM4_IER 0 x00; 禁止中断 TIM4_EGR 0 x01; 允许产生更新事件 TIM4_PSCR 0 x07; 计数器时钟主时钟/1282MHZ/128 相当于计数器周期为64uS TIM4_ARR 255; 设定重装载时的寄存器值,255是最大值 TIM4_CNTR 255; 设定计数器的初值 定时周期ARR1*6416320uS TIM4_CR1 0 x01; b0 1,允许计数器工作 b1 0,允许更新 设置控制器,启动定时器 TIM4_IER 0 x01; 允许更新中断 _asmrim; 允许CPU全局中断 while1 进入无限循环 函数功能定时器4的更新中断服务程序 输入参数无 输出参数无 返 回 值无far interrupt void TIM4_UPD_OVF_IRQHandler void TIM4_SR1 0 x00; 清除更新标志 PD_ODR PD_ODR 0 x08; LED驱动信号取反 LED闪烁频率2MHZ/128/255/230.63 修改后的stm8_interrupt_vector.c如下/* |
BASIC INTERRUPT VECTOR TABLE FOR STM8 devices* Copyright c 2007 STMicroelectronics*/typedef void far *interrupt_handler_tvoid;struct interrupt_vector unsigned char interrupt_instruction; interrupt_handler_t interrupt_handlerfar interrupt void NonHandledInterrupt void /* in order to detect unexpected events during development, it is recommended to set a breakpoint on the following instruction */ return;extern void _stext; /* startup routine */extern far interrupt void TIM4_UPD_OVF_IRQHandler void;struct interrupt_vector const _vectab 0 x82, interrupt_handler_t_stext, /* reset */ 0 x82, NonHandledInterrupt, /* trap */ 0 x82, NonHandledInterrupt, /* irq0 */ 0 x82, NonHandledInterrupt, /* irq1 */ 0 x82, NonHandledInterrupt, /* irq2 */ 0 x82, NonHandledInterrupt, /* irq3 */ 0 x82, NonHandledInterrupt, /* irq4 */ 0 x82, NonHandledInterrupt, /* irq5 */ 0 x82, NonHandledInterrupt, /* irq6 */ 0 x82, NonHandledInterrupt, /* irq7 */ 0 x82, NonHandledInterrupt, /* irq8 */ 0 x82, NonHandledInterrupt, /* irq9 */ 0 x82, NonHandledInterrupt, /* irq10 */ 0 x82, NonHandledInterrupt, /* irq11 */ 0 x82, NonHandledInterrupt, /* irq12 */ 0 x82, NonHandledInterrupt, /* irq13 */ 0 x82, NonHandledInterrupt, /* irq14 */ 0 x82, NonHandledInterrupt, /* irq15 */ 0 x82, NonHandledInterrupt, /* irq16 */ 0 x82, NonHandledInterrupt, /* irq17 */ 0 x82, NonHandledInterrupt, /* irq18 */ 0 x82, NonHandledInterrupt, /* irq19 */ 0 x82, NonHandledInterrupt, /* irq20 */ 0 x82, NonHandledInterrupt, /* irq21 */ 0 x82, NonHandledInterrupt, /* irq22 */ 0 x82, TIM4_UPD_OVF_IRQHandler,/* irq23 */ 0 x82, NonHandledInterrupt, /* irq24 */ 0 x82, NonHandledInterrupt, /* irq25 */ 0 x82, NonHandledInterrupt, /* irq26 */ 0 x82, NonHandledInterrupt, /* irq27 */ 0 x82, NonHandledInterrupt, /* irq28 */ 0 x82, NonHandledInterrupt, /* irq29 */; STM8的C语言编程(7)16位定时器的中断应用在STM8中,除了有8位的定时器外,还有16位的定时器。今天进行的实验就是针对16位定时器2来进行的。除了计数单元为16位的,其它设置与前面8位的定时器基本一样。下面的程序也是采样中断方式,由定时器2的中断服务程序来驱动LED的闪烁。具体的程序代码如下,其它注意点见上一篇,另外要注意别忘了修改相应的中断向量。 程序描述通过初始化定时器2,以中断方式驱动LED闪烁 LED接在MCU的GPIO的PD3上include STM8S207C_S.hmain 首先初始化GPIO PD_DDR 0 x08; PD_CR1 0 x08; 将PD3设置成推挽输出 PD_CR2 0 x00; 然后初始化定时器4 TIM2_IER 0 x00; 禁止中断 TIM2_EGR 0 x01; 允许产生更新事件 TIM2_PSCR 0 x01; 计数器
使用的是哪个IDE呢,都是有新建工程的目录与菜单的啊
只有小组成员才能发言,加入小组>>
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
382 浏览 1 评论
250 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
230 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
590 浏览 2 评论
615 浏览 2 评论
1345浏览 9评论
STM32F429 U盘IAP升级程序跳转APP异常的原因?
14浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
12浏览 3评论
STM32F103时钟硬件程序会卡在“while((SPI3->SR SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);”导致异常复位的原因?
68浏览 3评论
10浏览 3评论
GMT+8, 2024-4-20 03:28 , Processed in 0.605150 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
