收的二手板子,按照官方教程成功烧了uboot,但还是无法从SD卡启动,
板子有点老了,是不是套壳的SD卡不行?哪位资深大神能帮忙看一下咋回事? DNW的串口输出信息如下: OK U-Boot 1.3.4 (Oct 28 2013 - 08:58:54) for SMDKV210 CPU: S5PV210@1000MHz(OK) APLL = 1000MHz, HclkMsys = 200MHz, PclkMsys = 100MHz MPLL = 667MHz, EPLL = 80MHz HclkDsys = 166MHz, PclkDsys = 83MHz HclkPsys = 133MHz, PclkPsys = 66MHz SCLKA2M = 200MHz Serial = CLKUART Board: SMDKV210 RAM Configuration: Bank #0: 20000000 256 MB Bank #1: 40000000 256 MB Flash: 0 kB SD/MMC: S3C_HSMMC0_dev0, S3C_HSMMC2_dev1 Card channel 1 init fail! 0 MB NAND: Nandflash:ChipType= SLC ChipName=MT29F8G08ABABAWP No No Calc pagesize, blocksize, erasesize, use ids table ............. NandFlash:name=NAND 1GiB 1,8V 8-bit,id=38, pagesize=4096 ,chipsize=1024 MB,erasesize=524288 oobsize=128 NandFlash Size is 1024 MB The input address don't need a virtual-to-physical translation : 2c89d2a0 error during transfer: 0x00208001 mmc read failed *** Warning - using default environment In: serial Out: serial Err: serial checking mode for fastboot ... Hit any key to stop autoboot: 0 bs debug sdmmc init is failed. [Fusing Image from SD Card.] Fastboot: employ default partition information [Partition table on NAND] ptn 0 name='bootloader' start=0x0 len=0x100000(~1024KB) (Uboot) ptn 1 name='kernel' start=0x100000 len=0x500000(~5120KB) ptn 2 name='system' start=0x600000 len=N/A (Yaffs) Partition: bootloader, File: /sdfuse/u-boot-210.bin bs dev_desc->dev=1** Can't read from device 1 ** ** Invalid partition ** SMDKV210 # |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
ElfBoard ELF 1板卡-开发板启动后打印random: nonblocking pool is initialized
370 浏览 0 评论
G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
1589 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡- 减少uboot阶段的等待时间
1199 浏览 0 评论
嵌入式学习-飞凌ElfBoard ELF 1板卡 - 重新打包文件系统发现ftp无法正常连接
1697 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-6ull设置两个ip
2294 浏览 0 评论
GMT+8, 2024-4-18 11:52 , Processed in 0.622631 second(s), Total 70, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
