- #include
- #include
- #define a8255_PA XBYTE[0xd900] /*PA 口地址 */
- #define a8255_PB XBYTE[0xdb00] /*PB 口地址 */
- #define a8255_PC XBYTE[0xD5FF] /*PC 口地址 */
- #define a8255_CON XBYTE[0xde00] /*控制字地址 */
- #define uchar unsigned char
- #define uint unsigned long int
- uint a,n,i,j,x=1,b=1,tt=0;
- uint table[]={0x80,0x9B,0x42,0x0A,0x19,0x0C,0x04,0x9A,0x00,0x08};
- void delay1(void)
- unsigned char i;
- for(i=250; i>0;i--);
- uchar inkey()
- uchar i,j=0x10,k;
- uchar keytab[20]={0x18, /*0*/
- 0x28, /*1*/
- 0x48, /*2*/
- 0x88, /*3*/
- 0x14, /*4*/
- 0x24, /*5*/
- 0x44, /*6*/
- 0x84, /*7*/
- 0x12, /*8*/
- 0x22, /*9*/
- 0x42, /*10*/
- 0x82, /*11*/
- 0x11, /*12*/
- 0x21, /*13*/
- 0x41, /*14*/
- 0x81 /*15*/
- a8255_CON=0x81;
- a8255_PC=0x00;
- for(i=0;i<4;i++)
- a8255_PC=j;
- a8255_PA=0xff;
- a8255_PB=0xff;
- k=a8255_PC;
- k=k&0x0f;
- if(k!=0)
- { delay1();
- k=a8255_PC;
- k=k&0x0f;
- if(k!=0)
- break;
- j=j<<1;
- delay1();
- k=k+j;
- for(i=0;i<16;i++)
- if(keytab==k) break;
- return i;
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=11;y>0;y--);
- void display(uint a)
- uint wan,qian,bai,shi,ge;
- wan=a/10000;
- qian=a%10000/1000;
- bai=a%1000/100;
- shi=a%100/10;
- ge=a%10;
- a8255_PA=0xfd;
- a8255_PB=table[wan];
- delay(1);
- a8255_PA=0xfb;
- a8255_PB=table[qian];
- delay(1);
- a8255_PA=0xf7;
- a8255_PB=table[bai];
- delay(1);
- a8255_PA=0xef;
- a8255_PB=table[shi];
- delay(1);
- a8255_PA=0xdf;
- a8255_PB=table[ge];
- delay(1);
- void display1()
- a8255_PA=0xdf;
- a8255_PB=0x80;
- delay(1);
- a8255_PA=0xef;
- a8255_PB=0x7f;
- delay(1);
- void init()
- { a8255_PA=0xff;
- a8255_CON=0x81;
- tt=0;
- TMOD=0x01;
- TH0=0x3c;
- TL0=0xb0;
- EA=1;
- ET0=1;
- TR0=1;
- EX0=1;
- IT1=1;
- void main()
- uchar n=0,k=0xdf;
- init();
- a=0;
- while(1)
- n=inkey();
- switch(n)
- case 0: a=99999; break;
- case 1: a=9999; break;
- case 2: a=999; break;
- case 3: a=99; break;
- case 4: a=9; break;
- if(n==5)
- do
- display1();
- n=inkey();
- if((n!=5)&&(n!=16))
- x=0;
- }while(x);
- x=1;
- display(a);
- void timer0() interrupt 1
- TH0=0x3c;
- TL0=0xb0;
- tt++;
- if(tt==20)
- tt=0;
- if(a)
- a--;
复制代码
4个回答
