apt-get方法
使用apt-get install来安装应用程序算是最常见的一种安装方法了,比如我要安装build-essential这个软件,使用以下,他会帮我把所有的依赖包都一起安装了。 sudo apt-get install build-essential 执行上述命令以后,我们可以看到一下信息,The following extra packages will be installed:表示所有需要再安装的依赖包。 sudo apt-get install build-essential [sudo] password for enadmin: Reading package lists.。. Done Building dependency tree Reading state information.。. Done The following extra packages will be installed: binutils cpp cpp-4.6 dpkg-dev fakeroot g++ g++-4.6 gcc gcc-4.6 libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libc-bin libc-dev-bin libc6 libc6-dev libdpkg-perl libgomp1 libmpc2 libmpfr4 libquadmath0 libstdc++6-4.6-dev linux-libc-dev manpages-dev Suggested packages: binutils-doc cpp-doc gcc-4.6-locales debian-keyring g++-multilib g++-4.6-multilib gcc-4.6-doc libstdc++6-4.6-dbg gcc-multilib autoconf automake1.9 libtool flex bison gdb gcc-doc gcc-4.6-multilib libmudflap0-4.6-dev libgcc1-dbg libgomp1-dbg libquadmath0-dbg libmudflap0-dbg binutils-gold glibc-doc libstdc++6-4.6-doc The following NEW packages will be installed: binutils build-essential cpp cpp-4.6 dpkg-dev fakeroot g++ g++-4.6 gcc gcc-4.6 libalgorithm-diff-perl libalgorithm-diff-xs-perl libalgorithm-merge-perl libc-dev-bin libc6-dev libdpkg-perl libgomp1 libmpc2 libmpfr4 libquadmath0 libstdc++6-4.6-dev linux-libc-dev manpages-dev The following packages will be upgraded: libc-bin libc6 2 upgraded, 23 newly installed, 0 to remove and 101 not upgraded. Need to get 36.3 MB of archives. After this operation, 83.6 MB of additional disk space will be used. Do you want to continue [Y/n]? y |
dpkg安装deb包
Ubuntu软件包格式为deb,安装方法如下: sudo dpkg -i package.deb dpkg的详细使用方法,网上有很多,下面简单列了几个:
enadmin@ubuntu-server:~/ftp$ sudo cp -r archives/ /var/cache/apt/ |
make install源代码安装
如果要使用make安装的话,那么必须得安装build-essential这个依赖包,安装方法已经在前面说过了。在安装完毕以后,我们就可以进行源码安装。源码安装大致可以分为三步骤:(./configure)–> 编译(sudo make) –> 安装(sudo make install)。
//1.解压缩tar -zxf nagios-4.0.2.tar.gz //2.进入目录cd nagios-4.0.2//3.配置./configure --prefix=/usr/local/nagios //4.编译make all//5.安装make install && make install-init && make install-commandmode && make install-config以上就是源代码安装方式。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
防止AI大模型被黑客病毒入侵控制(原创)聆思大模型AI开发套件评测4
434 浏览 0 评论
不可错过!人工神经网络算法、PID算法、Python人工智能学习等资料包分享(附源代码)
2324 浏览 0 评论
21137 浏览 0 评论
31699 浏览 0 评论
5045 浏览 0 评论
GMT+8, 2024-4-23 22:28 , Processed in 0.531956 second(s), Total 69, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
