Public Sub Main()
CompareBookmarksX
End Sub
Public Sub CompareBookmarksX()
Dim rst As ADODB.Recordset
Dim count As Integer
Dim target As Variant
Dim result As Long
Dim strAns As String
Dim strtitle As String
strTitle = "CompareBookmarks Example"
Set rst = New ADODB.Recordset
rst.Open "SELECT * FROM Authors", _
"DSN=Pubs;Provider=MSDASQL; uid=sa;pwd=;", _
adOpenStatic, adLockReadOnly, adCmdText
count = rst.RecordCount
Debug.Print "Rows in the Recordset = "; count
If count = 0 Then Exit Sub 'Exit if an empty recordset
Randomize
count = (Int(count * Rnd)) 'Get position between 0 and count-1
Debug.Print "Randomly chosen row position = "; count
rst.Move count, adBookmarkFirst 'Move row to random position
target = rst.Bookmark 'Remember the mystery row.
count = 0
rst.MoveFirst
Do While Not rst.EOF 'Loop through recordset
result = rst.CompareBookmarks(rst.Bookmark, target)
If result = adCompareNotEqual Then
Debug.Print "Row "; count; ": Bookmarks are not equal."
ElseIf result = adCompareNotComparable Then
Debug.Print "Row "; count; ": Bookmarks are not comparable."
Else
Select Case result
Case adCompareLessThan
strAns = "less than"
Case adCompareEqual
strAns = "equal to"
Case adCompareGreaterThan
strAns = "greater than"
Case Else
strAns = "in error comparing to"
End Select
Debug.Print "Row position " & count & " is " & strAns & _
" the target."
End If
count = count + 1
rst.MoveNext
Loop
rst.Close
End Sub
