4 个讨论
link时报错如下:
Description Resource Path Location Type #10263 ledcfg.cmd CACHE_L1D memory range has already been ledold line 249 C/C++ Problem #10263 ledcfg.cmd CACHE_L1P memory range has already been ledold line 248 C/C++ Problem #10263 ledcfg.cmd DDR2 memory range has already been ledold line 250 C/C++ Problem #10263 ledcfg.cmd IRAM memory range has already been ledold line 251 C/C++ Problem #10264 ledcfg.cmd CACHE_L1D memory range overlaps existing ledold line 249 C/C++ Problem #10264 ledcfg.cmd CACHE_L1P memory range overlaps existing ledold line 248 C/C++ Problem #10264 ledcfg.cmd DDR2 memory range overlaps existing ledold line 250 C/C++ Problem #10264 ledcfg.cmd IRAM memory range overlaps existing ledold line 251 C/C++ Problem |
twtgffwer 发表于 2020-8-5 19:20 用的是dsp/bios吗?dsp/bios本身会有个cmd文件 ledcfg.cmd,如果要添加自己的linker.cmd文件,可以在linker.cmd文件开始处-l legcfg.cmd,注意自己的cmd文件memory map定义不要与ledcfg.cmd overlap。 5.1.3 Defining Segments in Your Own Linker Command File www.ti.com/.../spru423i.pdf |
vuywsdfwf 发表于 2020-8-5 19:39 是直接import进来的,linker.cmd确实是-l legcfg.cmd,会不会是和led.tcf冲突了?删除Linker.cmd后能编译通过。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-18 20:59 , Processed in 0.714343 second(s), Total 56, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
