/*以下为ADC触发*/
/* time base configuration */ TIM_TimeBaseStructure.TIM_Period = BufferSize-1; TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_RepetitionCounter=0; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); /* TIM2 channel2 configuration in PWM mode */ TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 8; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; TIM_OC2Init(TIM2, &TIM_OCInitStructure); TIM_SelectMasterSlaveMode(TIM8,TIM_MasterSlaveMode_Enable);// 主从模式 TIM_SelectSlaveMode(TIM2,TIM_SlaveMode_External1); //从模式 上升沿作为计数脉冲 TIM_ITRxExternalClockConfig(TIM2,TIM_TS_ITR1); /* DMA1 Channel1 Configuration ----------------------------------------------*/ DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_1RegularConvertedValueTab; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为源 DMA_InitStructure.DMA_BufferSize =32; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word; DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* Enable DMA1 channel1 */ DMA_Cmd(DMA1_Channel1, ENABLE); /* ADC1 configuration ------------------------------------------------------*/ ADC_DeInit(ADC1); ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; //ADC1 and ADC2 为同步规则模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE; //单通道模式 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //循换模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T2_CC2; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; ADC_Init(ADC1, &ADC_InitStructure); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 1, ADC_SampleTime_1Cycles5); ADC_DMACmd(ADC1, ENABLE); // /* ADC2 configuration ------------------------------------------------------*/ ADC_DeInit(ADC2); ADC_InitStructure.ADC_Mode = ADC_Mode_RegSimult; ADC_InitStructure.ADC_ScanConvMode = DISABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 1; ADC_Init(ADC2, &ADC_InitStructure); ADC_RegularChannelConfig(ADC2, ADC_Channel_14, 1, ADC_SampleTime_1Cycles5); /* Enable ADC1 */ ADC_Cmd(ADC1, ENABLE); /* Enable ADC1 reset calibaration register */ ADC_ResetCalibration(ADC1); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC1)); /* Start ADC1 calibaration */ ADC_StartCalibration(ADC1); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC1)); /* Enable ADC2 */ ADC_Cmd(ADC2, ENABLE); /* Enable ADC2 reset calibaration register */ ADC_ResetCalibration(ADC2); /* Check the end of ADC1 reset calibration register */ while(ADC_GetResetCalibrationStatus(ADC2)); /* Start ADC2 calibaration */ ADC_StartCalibration(ADC2); /* Check the end of ADC1 calibration */ while(ADC_GetCalibrationStatus(ADC2)); ADC_SoftwareStartConvCmd(ADC1, ENABLE); TIM_CtrlPWMOutputs(TIM2, ENABLE); TIM_Cmd(TIM8, ENABLE); TIM_Cmd(TIM2, ENABLE); DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); 双ADC无法完成采集,也无法跳DMA中断,不知道什么原因,触发时钟没有问题,就是无法完成AD转换啊。我是利用TIM2_CC2触发的,已经将ADC1设置为TIM2_CC2触发,ADC2为软件触发。ADC时钟使能,ADC端口都已经设置好了。 |
1个回答
一步步来,一次就搞这么多,难免出问题.
首先,单个ADC转换完成了么? 2,两个ADC轮流工作,完成了么? 3,单个ADC+DMA转换,完成了么? 4,单个ADC+TIM触发,完成了么? 5,单个TIM触发+ADC+DMA,完成了么? 以上这些都完成了,就离胜利不远了. |
只有小组成员才能发言,加入小组>>
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
407 浏览 1 评论
262 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
230 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
602 浏览 2 评论
627 浏览 2 评论
1354浏览 9评论
35浏览 3评论
STM32CUBEMX4.22.1在main函数里面添加一行语句就死机的原因?
34浏览 3评论
36浏览 3评论
KEIL MDK为什么无法debug library中的代码?
73浏览 3评论
GMT+8, 2024-4-24 07:34 , Processed in 0.574981 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
