//! brief Writes PWM data to the PWM comparators for motor control//! param[in] handle The hardware abstraction layer (HAL) handle//! param[in] pPwmData The pointer to the PWM datastatic inline void HAL_writePwmData(HAL_Handle handle,HAL_PwmData_t *pPwmData)[ uint_least8_t cnt; HAL_Obj *obj = (HAL_Obj *)handle; PWM_Obj *pwm; _iq period; _iq pwmData_neg; _iq pwmData_sat; _iq pwmData_sat_dc; _iq value; uint16_t value_sat; for(cnt=0;cnt<3;cnt++) [ pwm = (PWM_Obj *)obj->pwmHandle[cnt]; period = (_iq)pwm->TBPRD; pwmData_neg = _IQmpy(pPwmData->Tabc.value[cnt],_IQ(-1.0)); pwmData_sat = _IQsat(pwmData_neg,_IQ(1.0),_IQ(-1.0)); pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); value = _IQmpy(pwmData_sat_dc, period); value_sat = (uint16_t)_IQsat(value, period, _IQ(0.0)); // write the PWM data PWM_write_CmpA(obj->pwmHandle[cnt],value_sat); ] return;]在这个函数中,for循环部分,特别是下面这段:
period = (_iq)pwm->TBPRD; pwmData_neg = _IQmpy(pPwmData->Tabc.value[cnt],_IQ(-1.0)); pwmData_sat = _IQsat(pwmData_neg,_IQ(1.0),_IQ(-1.0)); pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); value = _IQmpy(pwmData_sat_dc, period); value_sat = (uint16_t)_IQsat(value, period, _IQ(0.0));这段怎么理解?求各位大神指教啊!! |
5 个讨论
而且老板的库中是这个:pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5));
新版的库中是这个:pwmData_sat_dc = pwmData_sat + _IQ(0.5); 在同等电压下 用pwmData_sat_dc = pwmData_sat + _IQ(0.5); 转速有提高,但是油门就没有最大,转速就已经最高了 用pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); 转速比上者低几百转,但是油门可以提到最高 这是什么原因呢?? |
adaliu001 发表于 2020-7-24 10:24 而且老板的库中是这个:pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); 新版的库中是这个:pwmData_sat_dc = pwmData_sat + _IQ(0.5); 在同等电压下 用pwmData_sat_dc = pwmData_sat + _IQ(0.5); 转速有提高,但是油门就没有最大,转速就已经最高了 用pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); 转速比上者低几百转,但是油门可以提到最高 这是什么原因呢?? ERIC: 新版本在这里做了调整了,所以你看到user.h里面的VS最大都是比以前除以2. 新版的库中是这个:pwmData_sat_dc = pwmData_sat + _IQ(0.5); 这里还是把pwmData_sat_dc 调整到 0~ 1. pwmData_sat 是-0.5~0.5. 用pwmData_sat_dc = pwmData_sat + _IQ(0.5); 转速有提高,但是油门就没有最大,转速就已经最高了 用pwmData_sat_dc = _IQmpy(pwmData_sat + _IQ(1.0), _IQ(0.5)); 转速比上者低几百转,但是油门可以提到最高 ERIC: 不理解你这个内容,油门表示什么?扭矩? 你用新的版本就好了。 - ERIC |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3645 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9368 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
675浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1771浏览 1评论
GMT+8, 2024-4-24 03:33 , Processed in 0.528249 second(s), Total 43, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
