您好,
配置28069的PWM为UPDOWN模式,预设值9000,比较值4500,但实测PWM占空比为25%,请专家帮忙看看哪里设置得不对? ============================================= EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN;// TB_COUNT_UP; EPwm1Regs.TBPRD = 9000; EPwm1Regs.CMPA.half.CMPA = 4500; // Fix duty at 50% EPwm1Regs.TBPHS.all = 0; EPwm1Regs.TBCTR = 0; EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;//TB_CTR_ZERO; //used to sync EPWM(n+1) "down-stream" EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL; EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active Hi Complimentary // Dead time setting EPwm1Regs.DBRED = 360;//12; // dummy value for now EPwm1Regs.DBFED = 360;//12; // dummy value for now //TZ EPwm1Regs.TZFRC.bit.OST = 1; EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO ; // EPWMxA will go low EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO ; // EPWMxB will go low EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD;// ET_CTR_ZERO; //ET_CTR_ZERO;ET_CTR_PRD //触发CLA1的ADC任务 EPwm1Regs.ETSEL.bit.INTEN = 1; //使能中断 EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate INT on 1st event |
1 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3645 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9368 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
1761浏览 1评论
GMT+8, 2024-4-23 16:11 , Processed in 0.809408 second(s), Total 63, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
