Chamber Structure
The inner bladder of the chamber is made of SUS304 stainless steel plate while the outer bladder is made of A3 steel plate sprayed with plastic(linpin). A large observation window is set on the chamber door. A test hole with 25mm, or 50mm or 100mm diameter is set on the left of the chamber body. A fixable PU moving wheel is adopted on the bottom of the test chamber(linpin). Controller The temperature controller adopts fully imported (Japanese PKC) meter with touch keys. P.I.D automation calculation function is available. Cooling and Air Path Circulation System The cooler adopts original French Tecumseh fully-closed compressor(linpin). The cooling system adopts single or dual low-temperature loop system design. Standards Applied GB/T2423.1-2001 and GB/T2423.2-2001 Specs and Technical Parameters Model(cm) GDW-100 GDW-225 GDW-500 GDW-800 GDW-010 Workroom Dimensions 45*45*50 50*60*75 80*70*90 80*100*100 100*100*100 Exterior Dimensions 105*97*176.5 105*102*200 132*132*217 147*152*231.5 167*152*231.5 Power(@-40℃) 4.5(KW) 5.5 (KW) 8.0(KW) 9.0(KW) 11.0(KW) Temperature Range A:-20℃~150℃ B:-40℃~150℃ C:-60℃~150℃ D:-70℃~150℃ Fluctuation/Evenness ≤±0.5℃/≤±2℃ Temperature Rise Speed 1.0~3.0℃/min Temperature Fall Speed 0.7~1.0℃/min |
2 个讨论
只有小组成员才能发言,加入小组>>
如何用AD844运算放大器完成双二阶滤波器的Pspice仿真
4422 浏览 0 评论
PSPICE二极管Model,修改结电压参数Vj0后,仿真导通电压不变?
3274 浏览 1 评论
4736 浏览 3 评论
3123 浏览 2 评论
我给导线一个网络节点,命名为V2,请问为什么在直流扫描的时候识别不了呢?
3463 浏览 0 评论
Cadence capture原理图中如果有没连接的电源符号,可以通过什么方式检查出来
10214浏览 1评论
5040浏览 1评论
954浏览 0评论
新手做pspice仿真,没有找到C3M0032120K的pspice模型,改用STW56N65M2-4_TN代替,仿真出现一堆问题,求帮助
3181浏览 0评论
GMT+8, 2024-4-19 17:57 , Processed in 0.514295 second(s), Total 57, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
