扫一扫,分享给好友
allegro问题,skill无法载入,环境变量已经设定了文件指向,还是不行,出现以下error 有人会解答吗 ,麻烦告知,谢谢
can't access file - "rep_ucshape.il" E- *Error* load: can't access file - "ruler.il" E- *Error* load: can't access file - "save_shape_drc.il" E- *Error* load: can't access file - "shape_push.il" E- *Error* load: can't access file - "show_height.il" E- *Error* load: can't access file - "show_library.il" E- *Error* load: can't access file - "thermal.il" E- *Error* load: can't access file - "cal_start.il" E- *Error* load: can't access file - "cal_start_name.il" E- E- load("xrf.il""usi") E- ^ E- SYNTAX ERROR found at line 73 column 18 of file allegro.ilinit E- *Error* lineread/read: syntax error encountered in input E- *Error* load: can't access file - "checkdis3.il" E- *Error* load: can't access file - "checkMax.il" E- *Error* load: can't access file - "checkminimus.il" E- *Error* load: can't access file - "checknpth.il" E- *Error* load: can't access file - "checkpadsmt.il" E- *Error* load: can't access file - "crdev.il" E- *Error* load: can't access file - "op.il" E- *Error* load: can't access file - "testpad.il" E- *Error* load: can't access file - "testpaddis.il" E- *Error* load: can't access file - "viasolder.il" E- *Error* load: can't access file - "valor_ext.il" E- *Error* load: can't access file - "Thermal_PAD.il" E- *Error* load: can't access file - "CreateSMDPad.il" E- *Error* load: can't access file - "CreateBGAPad.il" E- *Error* load: can't access file - "CreThruHolePad.il" E- *Error* load: can't access file - "BGA.il" E- *Error* load: can't access file - "Chip2p.il" E- *Error* load: can't access file - "qf.il" E- *Error* load: password required for reading file - "diff_phase_tune.ile" E- *Error* load: can't access file - "SOP.il" E- *Error* load: can't access file - "Athermal_PAD.il" E- *Error* load: can't access file - "Dfa.il" E- *Error* load: can't access file - "Apinadd.il" E- *Error* load: can't access file - "SK_Refdes_find.il" E- *Error* load: can't access file - "SKMV.il" E- *Error* load: can't access file - "Idfa.il" E- *Error* load: can't access file - "cutcline.il" E- *Error* load: can't access file - "assembly.il" E- *Error* load: can't access file - "x_silk_in_out.il" E- *Error* load: can't access file - "plccomp.il" E- *Error* load: can't access file - "chk_tp.il" E- *Error* load: can't access file - "Quick_pinpair.il" E- *Error* load: can't access file - "RotateTexts.il" E- *Error* load: password required for reading file - "x_align_symbol.il" E- *Error* load: password required for reading file - "via_pitch.ile" E- *Error* load: can't access file - "xnet.ile" E- *Error* load: can't access file - "x_downrev17.il" W- *WARNING* Symbol stroke_fix_166 is not a function. E- Cannot open script file; No match found for 'startup.scr' in the search path. E- E- ===load("xangle.il") E- ^ E- SYNTAX ERROR found at line 128 column 3 of file allegro.ilinit E- *Error* lineread/read: syntax error encountered in input Opening existing design... last pick: 2956.0000 -1160.0000 No element found. Command > |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1176 浏览 1 评论
836 浏览 0 评论
1286 浏览 0 评论
推动SiCMOSFET国产化,华秋获“芯塔电子”优秀媒体合作伙伴奖
1717 浏览 0 评论
3075 浏览 1 评论
GMT+8, 2024-4-20 09:52 , Processed in 0.674133 second(s), Total 60, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
