ad转换开始后发现ad数据寄存器值始终为零,模拟输入我测得是有值(2.8v)程序和cpu图如下,pb1为模拟输入,苦逼的用库男
#include "STM32f10x.h" #define ADC1_DR_Address ((uint32_t)0x4001244C) void Delay(uint32_t delaytime); void RCC_Config(void); void GPIO_Config(void); void da_convert(vu16 dabl); void SPI1_Config(void); void DMA_Config(void); void ADC_Config(void); vu16 da_buf; vu16 ADC_ConvertedValue; int main(void) { vu16 bl; RCC_Config(); GPIO_Config(); SPI1_Config(); DMA_Config(); ADC_Config(); DMA_Cmd(DMA1_Channel1, ENABLE); //使能DMA1通道1 ADC_SoftwareStartConvCmd(ADC1, ENABLE);//ad转换开始 while (1) { while(DMA_GetFlagStatus(DMA1_FLAG_TC1) == RESET);//等待DMA传输完成 { DMA_ClearFlag(DMA1_FLAG_TC1); bl=ADC_ConvertedValue; ADC_ConvertedValue=(vu16)(ADC_ConvertedValue*1024/4096 ); //12位转换为10位 ADC_ConvertedValue=ADC_ConvertedValue<<2 ; da_convert(ADC_ConvertedValue); } } } void da_convert(uint16_t dabl) { vu16 da_code ; da_code = 0x4000 | dabl; GPIO_ResetBits(GPIOA,GPIO_Pin_6); //拉低使能da转换 Delay(0xff);//加入延时 //while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); //等待发送完成 SPI_I2S_SendData(SPI1,da_code); //发送转换数据 //GPIO_ResetBits(GPIOB,GPIO_Pin_2);//灯灭 Delay(0xfff); GPIO_SetBits(GPIOA,GPIO_Pin_6); } void RCC_Config(void) { SystemInit(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_SPI1|RCC_APB2Periph_GPIOB|RCC_APB2Periph_ADC1, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); } void GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_4; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_6|GPIO_Pin_4); //拉高电位使外部芯片不使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = (GPIO_Pin_2|GPIO_Pin_0); GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_SetBits(GPIOB,GPIO_Pin_0); //拉高电位使外部芯片不使能 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//配置PB1为模拟输入 GPIO_Init(GPIOB, &GPIO_InitStructure); } void DMA_Config(void) { DMA_InitTypeDef DMA_InitStructure; DMA_DeInit(DMA1_Channel1);//复位DMA通道1 DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //定义 DMA通道外设基地址=ADC1_DR_Address DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //定义DMA通道存储器地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //指定外设为源地址 DMA_InitStructure.DMA_BufferSize = 1; //定义DMA传输数据大小1 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //当前外设寄存器地址不变 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //当前存储器地址不变 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //定义外设数据宽度16位 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //定义存储器数据宽度16位 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //DMA通道操作模式位环形缓冲模式 DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道优先级高 DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //禁止DMA通道存储器到存储器传输 DMA_Init(DMA1_Channel1, &DMA_InitStructure); //初始化DMA1通道1 //DMA_Cmd(DMA1_Channel1, ENABLE); //使能DMA1通道1 } void ADC_Config(void) { ADC_InitTypeDef ADC_InitStructure; ADC_DeInit(ADC1); ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC1和ADC2工作在独立模式 ADC_InitStructure.ADC_ScanConvMode = ENABLE; //使能扫描 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;//ADC转换工作在连续模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//转换数据右对齐 ADC_InitStructure.ADC_NbrOfChannel = 1;//转换通道数1 ADC_Init(ADC1, &ADC_InitStructure); //初始化ADC ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1, ADC_SampleTime_28Cycles5); //转换时间是28个周期 ADC_DMACmd(ADC1, ENABLE);//使能ADC1模块DMA ADC_Cmd(ADC1, ENABLE);//使能ADC1 ADC_ResetCalibration(ADC1); //重置ADC1校准寄存器 while(ADC_GetResetCalibrationStatus(ADC1));//等待ADC1校准重置完成 ADC_StartCalibration(ADC1);//开始ADC1校准 while(ADC_GetCalibrationStatus(ADC1));//等待ADC1校准完成 } void SPI1_Config(void) { SPI_InitTypeDef SPI_InitStructure; SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; //设置SPI的数据大小:SPI发送接收8位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //选择了串行时钟的稳态:时钟悬空高 SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //数据捕获于第二个时钟沿 SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制 SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; //定义波特率预分频的值:波特率预分频值为256 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始 SPI_InitStructure.SPI_CRCPolynomial =7; //CRC值计算的多项式 SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器 SPI_Cmd(SPI1, ENABLE); //使能SPI外设 } void Delay(uint32_t delaytime) { for(;delaytime>0;delaytime--); } |
2个回答
找到了pb1对应的是通道9
这么多看到头晕晕, 最后亮点居然是通道9 我了个去
只有小组成员才能发言,加入小组>>
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
407 浏览 1 评论
262 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
230 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
602 浏览 2 评论
627 浏览 2 评论
1354浏览 9评论
STM32F429 U盘IAP升级程序跳转APP异常的原因?
26浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
23浏览 3评论
STM32F103时钟硬件程序会卡在“while((SPI3->SR SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);”导致异常复位的原因?
119浏览 3评论
21浏览 3评论
GMT+8, 2024-4-24 02:47 , Processed in 0.716760 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
