数字矩阵芯片方案
VSC3104 Up to 6.5 Gbps 4x4 Asynchronous VSC3303 Up to 8.5 Gbps 4x4 Asynchronous with support of SAS/SATA VSC3304 Up to 8.5 Gbps 4x4 Asynchronous VSC3108 Up to 6.5 Gbps 8x8 Asynchronous VSC3008 Up to 11 Gbps 8x8 Asynchronous VSC3308 Up to 11.5 Gbps 8x8 Asynchronous with advanced EQ VSC3208 150 Mbps to 4.25 Gbps 8x8 Synchronous using CDR VSC3312 Up to 6.5 Gbps 12x12 Asynchronous with support for SAS/SATA VSC3212 150 Mbps to 4.25 Gbps 12x12 Synchronous using CDR VSC3316 Up to 11.5 Gbps 16x16 Asynchronous VSC3340 Up to 6.5 Gbps 40x40 Asynchronous with power-scaling green modes VSC3139 Up to 4.25 Gbps 72x72 Asynchronous VSC3172 Up to 6.5 Gbps 72x72 Asynchronous VSC3140 Up to 4.25 Gbps 144x144 Asynchronous VSC3144 Up to 10.709 Gbps 144x144 Asynchronous
最佳答案
1 条评论
可以选择视频矩阵柜,不知道需要几路的控制。
1 条评论
Vitesse 的一些数字矩阵芯片方案
2010-04-28 12:07:12 分享到: Vitesse was first to introduce input signal equalization in crosspoint switches and now has a decade of successful product developments with more than a dozen products in production. Key Features • Highest data rates in the industry (up to 11 Gbps) • Programmable individual and global input signal equalization and output drive levels • Programmable power-down for unused channels • Differential current-mode logic data output driver • On-chip input and output terminations • Per-channel clock and data recovery (VSC3208 and VSC3212) • Support for signal monitoring and OOB signal forwarding for SAS/SATA applications (VSC3208, VSC3304, and VSC3312) Product Data Rate per Serial Lane Channels Distinction VSC3104 Up to 6.5 Gbps 4x4 Asynchronous VSC3303 Up to 8.5 Gbps 4x4 Asynchronous with support of SAS/SATA VSC3304 Up to 8.5 Gbps 4x4 Asynchronous VSC3108 Up to 6.5 Gbps 8x8 Asynchronous VSC3008 Up to 11 Gbps 8x8 Asynchronous VSC3308 Up to 11.5 Gbps 8x8 Asynchronous with advanced EQ VSC3208 150 Mbps to 4.25 Gbps 8x8 Synchronous using CDR VSC3312 Up to 6.5 Gbps 12x12 Asynchronous with support for SAS/SATA VSC3212 150 Mbps to 4.25 Gbps 12x12 Synchronous using CDR VSC3316 Up to 11.5 Gbps 16x16 Asynchronous VSC3340 Up to 6.5 Gbps 40x40 Asynchronous with power-scaling green modes VSC3139 Up to 4.25 Gbps 72x72 Asynchronous VSC3172 Up to 6.5 Gbps 72x72 Asynchronous VSC3140 Up to 4.25 Gbps 144x144 Asynchronous VSC3144 Up to 10.709 Gbps 144x144 Asynchronous |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
9160 浏览 1 评论
596 浏览 0 评论
硬创大赛项目专访 | 田奕鑫:专注细分领域创新,我们和行业巨头“化敌为友”
60566 浏览 1 评论
硬创大赛项目专访 | 王猛:专研降噪技术,让中国的黑科技产品服务全球用户
23611 浏览 1 评论
8452 浏览 3 评论
GMT+8, 2024-3-28 21:00 , Processed in 0.779171 second(s), Total 95, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
