使用的开发板:
我下载的28035例程关于adc采样的,DSP2803x_examplesadc_soc,我在程序中跑时,从AdcResult.ADCRESULT0得到的采样数字量与实际电压值经过 4096*(input Analog -0)/3.3运算得到的值不对,要小的多这是为什呢,我程序都没动,基准电压是用的内部参考: AdcRegs.ADCCTL1.bit.ADCBGPWD = 1; // Power ADC BG AdcRegs.ADCCTL1.bit.ADCREFPWD = 1; // Power reference AdcRegs.ADCCTL1.bit.ADCPWDN = 1; // Power ADC AdcRegs.ADCCTL1.bit.ADCENABLE = 1; // Enable ADC AdcRegs.ADCCTL1.bit.ADCREFSEL = 0; // Select interal BG |
7 个讨论
otinn 发表于 2020-6-1 23:58 当程序跑在flash的时候,你需要调用memcpy函数,将有些运行在RAM的函数复制到RAM中运行,如DELAY US,如initlfash。 参考历程 C:ticontrolSUITEdevice_supportf2803xv130DSP2803x_examples_ccsv5flash_f28035 Eric - ERIC |
guigui_7044 发表于 2020-6-2 00:17 你好,这个例程我看了,试过了把DELAY_US弄到RAM里面运行。可是为什么我又写了一个小小的程序,在主函数直接调用DELAY_US函数闪烁LED,烧录到flash后没有调用memcpy函数也可以运行,貌似周期也没变大。 然后,ADC的程序烧录到flash时,运行到AdcOffsetSelfCal()就会卡在下面那判断ADC转换是否完成的地方,可是在RAM调试时就没有这样。 下面是在flash运行时AdcOffsetSelfCal()函数里面调用到的AdcConversion()函数,程序在判断标志位时进入死循环 //ADC Conversion AdcRegs.ADCSOCFRC1.all = 0x00FF; // Force Start SOC0-7 to begin ping-pong sampling while( index < SampleSize )[ //Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum while (AdcRegs.ADCINTFLG.bit.ADCINT1 == 0)[] AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Must clear ADCINT1 flag since INT1CONT = 0 Sum += AdcResult.ADCRESULT0; Sum += AdcResult.ADCRESULT1; Sum += AdcResult.ADCRESULT2; Sum += AdcResult.ADCRESULT3; Sum += AdcResult.ADCRESULT4; Sum += AdcResult.ADCRESULT5; Sum += AdcResult.ADCRESULT6; // Wait for SOC9 conversion to start, which gives time for SOC7 conversion result while( AdcRegs.ADCSOCFLG1.bit.SOC9 == 1 )[] Sum += AdcResult.ADCRESULT7; //Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum while (AdcRegs.ADCINTFLG.bit.ADCINT2 == 0)[] AdcRegs.ADCINTFLGCLR.bit.ADCINT2 = 1; //Must clear ADCINT2 flag since INT2CONT = 0 Sum += AdcResult.ADCRESULT8; Sum += AdcResult.ADCRESULT9; Sum += AdcResult.ADCRESULT10; Sum += AdcResult.ADCRESULT11; Sum += AdcResult.ADCRESULT12; Sum += AdcResult.ADCRESULT13; Sum += AdcResult.ADCRESULT14; // Wait for SOC1 conversion to start, which gives time for SOC15 conversion result while( AdcRegs.ADCSOCFLG1.bit.SOC1 == 1 )[] Sum += AdcResult.ADCRESULT15; index+=16; ] // end data collection |
guigui_7044 发表于 2020-6-2 00:17 对了,还有一个问题对memcpy的,是不是如果要把某个函数放到RAM里面运行,应该在那个函数所在的C文件开头使用#pragma CODE_SECTION(InitFlash, "ramfuncs");? 然后main函数里面的memcpy((uint16_t *)&RamfuncsRunStart,(uint16_t *)&RamfuncsLoadStart, (unsigned long)&RamfuncsLoadSize);是不是只要出现在移动到RAM里执行的函数执行之前,它就自动把所有要移动到RAM里的函数转移过去? 谢谢解答! |
otinn 发表于 2020-6-2 00:43 #pragma语句是预编译指令,不管出现在程序的后面还是前面都会在预编译的时候就固定他所放的位置 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1897 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3647 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9372 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
675浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1772浏览 1评论
GMT+8, 2024-4-24 17:34 , Processed in 0.546761 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
