我用28035芯片的AD模块采集数据并传上位机,用Example_2803xAdcTempSensor.c例子,AD引脚只有选择ADCINA5通道并且内部温度传感器置1时才能识别传感器电压,选择其他通道时均不能识传感器电压,想问一下这是问什么?我把程序贴在下边 #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // Prototype statements for functions found within this file. interrupt void adc_isr(void); // Global variables used in this example: Uint16 ConversionCount; float TempSensorVoltage; float adclo=0; float Dec; char rec_data[9]; int SampleCount=0; //采样次数 int SampleCountSCI=0; static int AsciiBuff[9]; #define array_size 9 typedef struct array array; struct array [ int v[array_size]; ]; array a; void HexToASCII(float data); array f(); void scia_fifo_init(void); void scia_echoback_init(void); void main (void) [ // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2803x_SysCtrl.c file. InitSysCtrl(); // Step 2. Initialize GPIO: // This example function is found in the DSP2803x_Gpio.c file and // illustrates how to set the GPIO to it's default state. InitSciaGpio(); // Skipped for this example // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2803x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; EALLOW; PieVectTable.ADCINT1 = &adc_isr; EDIS; // Step 4. Initialize the ADC: // This function is found in DSP2803x_Adc.c InitAdc(); // For this example, init the ADC scia_fifo_init(); scia_echoback_init(); // Step 5. Configure ADC to sample the temperature sensor on ADCIN5: // The output of Piccolo temperature sensor can be internally connected to the ADC through ADCINA5 // via the TEMPCONV bit in the ADCCTL1 register. When this bit is set, any voltage applied to the external // ADCIN5 pin is ignored. EALLOW; AdcRegs.ADCCTL1.bit.TEMPCONV= 0; EDIS; // Step 6. Continue configuring ADC to sample the temperature sensor on ADCIN5: EALLOW; AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINT1 trips after AdcResults latch AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1 AdcRegs.INTSEL1N2.bit.INT1CONT = 0; //Disable ADCINT1 Continuous mode AdcRegs.INTSEL1N2.bit.INT1SEL = 0; //setup EOC0 to trigger ADCINT1 to fire AdcRegs.ADCSOC0CTL.bit.CHSEL = 4; //set SOC0 channel select to ADCINA5 (which is internally connected to the temperature sensor) AdcRegs.ADCSOC0CTL.bit.TRIGSEL = 5; //set SOC0 start trigger on EPWM1A AdcRegs.ADCSOC0CTL.bit.ACQPS = 6; //set SOC0 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1) EDIS; // Step 7. User specific code, enable interrupts: // Enable ADCINT1 in PIE PieCtrlRegs.PIECTRL.bit.ENPIE = 1; PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable INT 1.1 in the PIE PieCtrlRegs.PIEIER9.bit.INTx1 = 1; PieCtrlRegs.PIEIER9.bit.INTx2 = 1; IER |= M_INT1; IER |= M_INT9; // Enable CPU Interrupt 1 EINT; // Enable Global interrupt INTM ERTM; // Enable Global realtime interrupt DBGM ConversionCount = 0; // Assumes ePWM1 clock is already enabled in InitSysCtrl(); EPwm1Regs.ETSEL.bit.SOCAEN = 1; // Enable SOC on A group EPwm1Regs.ETSEL.bit.SOCASEL = 4; // Select SOC from from CPMA on upcount EPwm1Regs.ETPS.bit.SOCAPRD = 1; // Generate pulse on 1st event EPwm1Regs.CMPA.half.CMPA = 0x0080; // Set compare A value EPwm1Regs.TBPRD = 0xFFFF; // Set period for ePWM1 EPwm1Regs.TBCTL.bit.CTRMODE = 0; // count up and start // Wait for ADC interrupt for(;;) [ ] ] interrupt void adc_isr(void) [ ConversionCount++; TempSensorVoltage =((float)AdcResult.ADCRESULT0)*3.0/65520.0+adclo;; // If 20 conversions have been logged, start over /*if(ConversionCount == 9) [ ConversionCount = 0; ] else ConversionCount++;*/ HexToASCII(TempSensorVoltage); a=f(); //SciaRegs.SCIFFTX.bit.TXFFINTCLR=1; //清除TXFFINT标志位 AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Clear ADCINT1 flag reinitialize for next SOC PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE return; ] interrupt void SCITXINTA_ISR(void)//SCIA发送中断函数 [ unsigned int i,j,k; SampleCountSCI++; for(i=0;i<9;i++) [ SciaRegs.SCITXBUF=a.v; //发送数据 for(j=0;j<300;j++) for(k=0;k<1000;k++); ] SciaRegs.SCIFFTX.bit.TXFFINTCLR=1; PieCtrlRegs.PIEACK.all=0x0100; //使同组其他中断能够得到响应 EINT; // 开全局中断 ] interrupt void SCIRXINTA_ISR(void) //SCIA接收中断函数 [ int i; SampleCountSCI++; for(i=0;i<9;i++) [ rec_data=SciaRegs.SCIRXBUF.all; //接收数据 ] Dec=(int)(rec_data[0]-0x30)*100.0+(int)(rec_data[1]-0x30)*10.0+(int)(rec_data[2]-0x30)*1.0 +(int)(rec_data[4]-0x30)/10.0+(int)(rec_data[5]-0x30)/100.0+(int)(rec_data[6]-0x30)/1000.0; SciaRegs.SCIFFRX.bit.RXFIFORESET=0; //复位FIFO指针 SciaRegs.SCIFFRX.bit.RXFIFORESET=1; //重新使能接收FIFO SciaRegs.SCIFFRX.bit.RXFFINTCLR=1; //清除RXFFINT标志位 PieCtrlRegs.PIEACK.all=0x0100; //使同组其他中断能够得到响应 EINT; // 开全局中断 ] //SCIA初始化 void scia_echoback_init() [ // Note: Clocks were turned on to the SCIA peripheral // in the InitSysCtrl() function SciaRegs.SCICCR.all=0x0007; // 1 stop bit, No loopback // No parity,8 char bits, // async mode, idle-line protocol SciaRegs.SCICTL1.all=0x0003; // enable TX, RX, internal SCICLK, // Disable RX ERR, SLEEP, TXWAKE SciaRegs.SCICTL2.all=0x0003; SciaRegs.SCICTL2.bit.TXINTENA=1; SciaRegs.SCICTL2.bit.RXBKINTENA=1; SciaRegs.SCIHBAUD=0x0000; // 9600 baud @LSPCLK = 15MHz (60 MHz SYSCLK). SciaRegs.SCILBAUD=0x00C2; SciaRegs.SCICTL1.all=0x0023; // Relinquish SCI from Reset ] void scia_fifo_init() [ SciaRegs.SCIFFTX.all=0xE020; //SciaRegs.SCIFFTX.all=0xE040; SciaRegs.SCIFFRX.all=0x2061; //SciaRegs.SCIFFRX.all=0x204f; SciaRegs.SCIFFCT.all=0x0; ] void HexToASCII(float data) [ AsciiBuff[0]=(Uint16)(data/100)%10+0x30; //Chr(48) 0 AsciiBuff[1]=(Uint16)(data/10)%10+0x30; AsciiBuff[2]=(Uint16)((int)(data)%10)+0x30; AsciiBuff[3]=46; //chr(46) .小数点 AsciiBuff[4]=((int)(data*10))%10+0x30; AsciiBuff[5]=((int)(data*100))%10+0x30; AsciiBuff[6]=((int)(data*1000))%10+0x30; AsciiBuff[7]=0x20; //chr(9) 空格 AsciiBuff[8]=(Uint16)' |
