[tr]新买了两个TDS100V3仿真器,连到TL138/1808/6748F-EasyEVM-A2开发板上,test connection无法通过,显示错误如下:
[Start] Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersadminAppDataLocal.TI3553585580 0 BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'jioserdesu***v3.dll'. The library build date was 'Aug 20 2013'. The library build time was '22:56:19'. The library package version is '5.1.232.0'. The library component version is '35.34.40.0'. The controller does not use a programmable FPGA. The controller has a version number of '4' (0x00000004). The controller has an insertion length of '0' (0x00000000). This utility will attempt to reset the controller. This utility has successfully reset the controller. -----[Print the reset-command hardware log-file]----------------------------- The scan-path will be reset by toggling the JTAG TRST signal. The controller is the FTDI FT2232 with USB interface. The link from controller to target is direct (without cable). The software is configured for FTDI FT2232 features. The controller cannot monitor the value on the EMU[0] pin. The controller cannot monitor the value on the EMU[1] pin. The controller cannot control the timing on output pins. The controller cannot control the timing on input pins. The scan-path link-delay has been set to exactly '0' (0x0000). An error occurred while hard opening the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-233' (0xffffff17). The title is 'SC_ERR_PATH_BROKEN'. The explanation is: The JTAG IR and DR scan-paths cannot circulate bits, they may be broken. An attempt to scan the JTAG scan-path has failed. The target's JTAG scan-path appears to be broken with a stuck-at-ones or stuck-at-zero fault. [End] 系统是win10,ccs版本5.5,在win7上也试过了,不行。 驱动确定是安装好的。 工程配置文件设置的仿真器类型也是XDS100V3 USB Emulator,device选的是6748(买了两块核心板,原来的是138,现在的是6748,都试过,不行)。 请问怎么解决? [/tr] |
3个回答
我这边搞错了,我们也在供应100V3。。。.
我看底板是我们之前的老版本,估计您这边买了挺久的,加上目前基本能够判读驱动已经正确安装,连接也没有问题。有一定可能是核心板B2B的插拔有局部不兼容导致了,建议你寄过来我们帮你检查下,解决问题。 光盘资料技术支持服务保修说明.pdf |
你好,如上面回复,其中可能的原因应该是B2B连接器匹配的问题导致的,A1和A2版本是完全兼容的,这点我们都是测试过。连接器的问题导致的这个问题是有先例的,所以建议你寄回来确认。如果是B2B连接器的问题我们会帮你更换连接器的 |
1 条评论
只有小组成员才能发言,加入小组>>
【创龙科技TL570x-EVM开发板试用体验】 GStreamer 功能测评
8245 浏览 8 评论
【创龙科技TL570x-EVM开发板试用体验】创龙TL5708-EVM开发板入手使用体验评测
6082 浏览 0 评论
【创龙TLZ7x-EasyEVM评估板试用连载】+3.环境搭建vmware+ubuntu详细教程(二)
1225 浏览 0 评论
【创龙TLZ7x-EasyEVM评估板试用连载】TcL脚本的使用
1715 浏览 0 评论
创龙TLZ7x-EasyEVM评估板试用连载】+开发板开箱及介绍
1750 浏览 0 评论
8245浏览 8评论
【创龙科技TL570x-EVM开发板试用体验】智能工业通讯网关
2268浏览 5评论
【创龙科技TL570x-EVM开发板试用体验】TL570x-EVM 的QT软件开发
2981浏览 2评论
【创龙科技TL570x-EVM开发板试用体验】晚来的开箱报告!
1768浏览 2评论
2028浏览 1评论
GMT+8, 2024-4-25 21:51 , Processed in 0.735448 second(s), Total 113, Slave 90 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
