可以的吧.
试一下,不就知道了。
我试了好像不行,所以来问问情况,求证一下
要在初始化模式,才能修改波特率和时间片。
能否上传工程给需要的朋友参考?
我可以把关于CAN的上传,但是不是stm芯片的,而是飞思卡尔的一款单片机,可以吗?
都可以.
参数:usBaudRate为要设的波特率,stInit是一个结构体
unsigned char sj,p; unsigned char t_seg1, t_seg2; unsigned char BRP = stInit.ucBaudRate; unsigned int uiDMR = 0, uiDAR = 0; //使能CAN CANCTL1_CANE = 1; //进入初始化模式 if (!(CANCTL1&0x01)) CANCTL0 =0x01; // 确认是否进入初始化模式 while (!(CANCTL1&0x01)); //********************* 设置ID过滤器**************************************** switch(stInit.ucFilterMode) { case 0: { // Disables all the Filters CANIDMR0 = 0xFF; CANIDMR1 = 0xFF; CANIDMR2 = 0xFF; CANIDMR3 = 0xFF; CANIDMR4 = 0xFF; CANIDMR5 = 0xFF; CANIDMR6 = 0xFF; CANIDMR7 = 0xFF; break; } case 1: { //Abales Filter0; CANIDAC_IDAM0 = 1; CANIDAC_IDAM1 = 0; if(stInit.uiFilterID1 == 0 || stInit.uiFilterID2 == 0) { uiDAR = stInit.uiFilterID1 | stInit.uiFilterID2; uiDMR = 0; } else { uiDAR = stInit.uiFilterID1; uiDMR = stInit.uiFilterID1 ^ stInit.uiFilterID2; } CANIDAR0 = (unsigned char)(uiDAR >> 3); CANIDAR1 = (uiDAR & 0x07) << 5; CANIDMR0 = (unsigned char)(uiDMR >> 3); CANIDMR1 = ((uiDMR & 0x07) << 5) | 0x1f; CANIDAR2 = 0; CANIDAR3 = 0; CANIDMR2 = 0x00; CANIDMR3 = 0x1f; if(stInit.uiFilterID3 == 0 || stInit.uiFilterID4 == 0) { uiDAR = stInit.uiFilterID3 | stInit.uiFilterID4; uiDMR = 0; } else { uiDAR = stInit.uiFilterID3; uiDMR = stInit.uiFilterID3 ^ stInit.uiFilterID4; } CANIDAR4 = (unsigned char)(uiDAR >> 3); CANIDAR5 = (uiDAR & 0x07) << 5; CANIDMR4 = (unsigned char)(uiDMR >> 3); CANIDMR5 = ((uiDMR & 0x07) << 5) | 0x1f; CANIDAR6 = 0; CANIDAR7 = 0; CANIDMR6 = 0x00; CANIDMR7 = 0x1f; break; } } //设置波特率 switch(usBaudRate) { case BAUDRATE_50K: sj=(SJW_50K-1)<<6; p=(PRE_50K-1); t_seg1=(T_SEG1_50K-1); t_seg2=(T_SEG2_50K-1)<<4; break; case BAUDRATE_100K: sj=(SJW_100K-1)<<6; p=(PRE_100K-1); t_seg1=(T_SEG1_100K-1); t_seg2=(T_SEG2_100K-1)<<4; break; case BAUDRATE_125K: sj=(SJW_125K-1)<<6; p=(PRE_125K-1); t_seg1=(T_SEG1_125K-1); t_seg2=(T_SEG2_125K-1)<<4; break; case BAUDRATE_250K: sj=(SJW_250K-1)<<6; p=(PRE_250K-1); t_seg1=(T_SEG1_250K-1); t_seg2=(T_SEG2_250K-1)<<4; break; case BAUDRATE_500K: sj=(SJW_500K-1)<<6; p=(PRE_500K-1); t_seg1=(T_SEG1_500K-1); t_seg2=(T_SEG2_500K-1)<<4; break; case BAUDRATE_800K: sj=(SJW_800K-1)<<6; p=(PRE_800K-1); t_seg1=(T_SEG1_800K-1); t_seg2=(T_SEG2_800K-1)<<4; break; case BAUDRATE_1000K: sj=(SJW_1000K-1)<<6; p=(PRE_1000K-1); t_seg1=(T_SEG1_1000K-1); t_seg2=(T_SEG2_1000K-1)<<4; break; default: break; } //选择时钟源 CANCTL1_CLKSRC=0; // 设置SJW和Tq clock分频器 CANBTR0 = (sj|p); // 设置时间段1和时间段2 CANBTR1 = (t_seg1 | t_seg2); CANCTL1 = 0x84; // 设置CAN的loop功能 if(stInit.ucLoopEnable == 1) CANCTL1_LOOPB = 1; else CANCTL1_LOOPB = 0; CANCTL0 = 0x00; // 让CAN进入正常运行模式 while(CANCTL1&0x01); // 确认CAN进入正常模式 while(!(CANCTL0&0x10)); //等待CAN同步 CANRIER_RXFIE = 1; // 使能接收中断 |
代码不方便完全上传,不过这部分就是整个CAN初始化的一个过程了。当然代码不完善,还有许多要改进的地方。如果有什么问题可以一起讨论,共同进步。
只有小组成员才能发言,加入小组>>
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
529 浏览 2 评论
551 浏览 2 评论
信号发生器产生的正弦频率信号,用定时器进行捕获,当幅值低于3V后为什么MCU就无法捕获到了?
209 浏览 2 评论
876 浏览 2 评论
编码器模式下,中断内访问其他定时器cnt值,会导致进入中断次数丢失的原因?
859 浏览 2 评论
1332浏览 9评论
STM32出现error downloading following files怎么解决?
29浏览 3评论
stm32f103的RST复位后PWM就停止输出了,为什么?
38浏览 3评论
STM32G0空闲中断异常,且DMA接收不到数据是怎么回事?
27浏览 3评论
STM32F103用Timer3TRGO通道触发ADC,ADC在三路输出PWM高电平中间点采样,如何配置?
17浏览 3评论
GMT+8, 2024-3-29 20:53 , Processed in 0.681827 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
