扫一扫,分享给好友
使用quarters ll 13.0调用modelsim仿真报错,不知道是哪里错了。 下面是代码:module ADC0809sampling(clk,ale,start,oe,eoc,adds,data_in,data_out,rst); input clk; input rst; input eoc; input [7:0]data_in; output ale; output start; output oe; output [2:0]adds; output [7:0]data_out; reg ale,start,oe; wire [2:0]adds; reg [7:0]data_out; reg [7:0]data_temp; reg [7:0]state; parameter st0=7'b0000000, st1=7'b0000001, st2=7'b0000010, st3=7'b0000100, st4=7'b0001000, st5=7'b0010000, st6=7'b0100000, st7=7'b1000000; always @(posedge clk or negedge rst) begin if(!rst) begin data_temp<=0; state<=st0; end else case(state) st0: begin ale<=1'b0; start<=1'b0; oe<=1'b0; state<=st1; end st1: begin ale<=1'b1; start<=1'b0; oe<=1'b0; state<=st2; end st2: begin ale<=1'b0; start<=1'b1; oe<=1'b0; state<=st3; end st3: begin ale<=1'b0; start<=1'b0; oe<=1'b0; state<=st4; end st4: begin if(eoc==1'b1) state<=st5; else state=st4; end st5: begin ale<=1'b0; start<=1'b0; oe<=1'b0; state<=st6; end st6: begin ale<=1'b0; start<=1'b0; oe<=1'b1; data_temp<=data_in; state<=st7; end st7: begin ale<=1'b0; start<=1'b0; oe<=1'b0; state<=st0; end endcase end assign adds=3'b001; always @(negedge oe) data_out<=data_temp; endmodule testbench如下: `timescale 1ns/1ps module ADC0809sampling_tb; reg clk; reg eoc; reg [7:0]data_in; reg rst; wire [2:0]adds; wire oe; wire start; wire [7:0]data_out; wire ale; ADC0809sampling T0(.clk(clk), .ale(ale), .start(start), .oe(oe), .eoc(eoc), .adds(adds), .data_in(data_in), .data_out(data_out), .rst(rst)); initial begin clk=0; rst=0; #100; rst=1; end always #20 clk=~clk; initial begin data_in=8'b00000000; eoc=1; end always@(negedge start) begin eoc=0; data_in<=data_in+1'b1; #200 eoc=1; end endmodule 编译和仿真结果图片在下面,是程序错了还是啥问题呀,研究了两三天了,好难! |
2个回答
可能是操作问题:
01.两个警告warning,直接看第二个,显示I/O分配未完成。这个warning直接导致第一个error。 02.第一个error显示25个pins未准确分配,它由“01”描述的warning导致。 03.缺少Synopsys的引脚约束文件“ADC0809sampling.sdc”。 由上述三点,导致时序仿真的时序不满足requirements。 //------- 每条可以单独执行的建议: a.完成引脚分配,满足Synopsys的需求; b.功能仿真不需要引脚分配,附图就是功能仿真结果。功能仿真没有问题之后完成引脚约束,再进行时序仿真。 //------- 功能仿真截图如下:
最佳答案
4 条评论
我复制你的代码,直接进行功能仿真没有任何问题,所以要查找你这边软件设置或者软件关联的问题。
平时我很少用modelsim,软件环境是Xilinx_FPGA的开发软件vivado2019.1自带sim工具。 01.建议你查看以往的仿真工程能否正常打开。 02.如果“01”正常,那么是现在的工程设置问题;如果“01”不正常,软件关联有问题/modelsim设置有问题。 03.尝试使用其他电脑仿真。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
828 浏览 0 评论
367 浏览 0 评论
1089 浏览 0 评论
380 浏览 0 评论
FPGA零基础学习系列精选:半导体存储器和可编程逻辑器件简介
1013 浏览 0 评论
1446 浏览 36 评论
GMT+8, 2024-4-24 15:56 , Processed in 0.356915 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
