在引用头文件"utils/uartstdio.h"时一旦使用该头文件包含的函数时,CCS就会报错内容为
undefined first referenced symbol in file --------- ---------------- UARTprintf ./main.obj error #10234-D: unresolved symbols remain error #10010: errors encountered during linking; "SSI.out" not built 是不是工程配置有问题? 源代码如下| #include #include #include"inc/hw_memmap.h" #include"driverlib/gpio.h" #include"driverlib/pin_map.h" #include"driverlib/ssi.h" #include"driverlib/uart.h" #include"driverlib/sysctl.h" #include "utils/uartstdio.h" #define NUM_SSI_DATA 3 //串口初始化函数 void InitConsole(void) [ SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA0_U0RX); GPIOPinConfigure(GPIO_PA1_U0TX); SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0); //使用16MHZ内部时钟源作为串口时钟 UARTClockSourceSet(UART0_BASE,UART_CLOCK_PIOSC); GPIOPinTypeUART(GPIO_PORTA_BASE,GPIO_PIN_0|GPIO_PIN_1); //串口号、波特率、时钟频率 UARTConfigSetExpClk(UART0_BASE,SysCtlClockGet(),115200,(UART_CONFIG_WLEN_8|UART_CONFIG_STOP_ONE|UART_CONFIG_PAR_NONE)); ] int main(void) [ uint32_t pui32DataTX[NUM_SSI_DATA]; uint32_t pui32DataRX[NUM_SSI_DATA]; uint32_t ui32Index; SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ); InitConsole(); //UARTprintf("ssi ->n"); //UARTprintf("Mode:spin"); //UARTprintf("Data:8-bitnn"); SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0); SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA); GPIOPinConfigure(GPIO_PA2_SSI0CLK); GPIOPinConfigure(GPIO_PA3_SSI0FSS); GPIOPinConfigure(GPIO_PA4_SSI0RX); GPIOPinConfigure(GPIO_PA5_SSI0TX); GPIOPinTypeSSI(GPIO_PORTA_BASE,GPIO_PIN_5|GPIO_PIN_4|GPIO_PIN_3|GPIO_PIN_2); //SSI0_BASE/时钟频率、时钟协议,moto代表SPI协议、工作模式:主机模式、位速率1M、数据帧位数为8 SSIConfigSetExpClk(SSI0_BASE,SysCtlClockGet(),SSI_FRF_MOTO_MODE_0,SSI_MODE_MASTER,1000000,8); SSIEnable(SSI0_BASE); while(SSIDataPutNonBlocking(SSI0_BASE,&pui32DataRX[0]));//确保RXFIFO中没有数据 pui32DataTX[0]='s'; pui32DataTX[1]='P'; pui32DataTX[2]='i'; UARTprintf("sent:n"); for(ui32Index=0;ui32Index //UARTprintf("'%C'",pui32DataTX[ui32Index]); SSIDataPut(SSI0_BASE,pui32DataTX[ui32Index]); ] //等待SSI0将所有数据发送到FIFO中 while(SSIBusy(SSI0_BASE)); //UARTprintf("nReceived:n"); for(ui32Index=0;ui32Index SSIDataGet(SSI0_BASE,&pui32DataRX[ui32Index]); pui32DataRX[ui32Index]&=0x00FF; //UARTprintf("'%C'",pui32DataRX[ui32Index]); ] ] |
5 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-19 08:50 , Processed in 0.427893 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
