请问,我想用labview生成word报表的时候,用书签的方式插入文本,在插入文本前,更改了颜色,插入文本后再将颜色改回去,但是生成的word里面,字体颜色没有变,请问是怎么回事。有什么解决办法吗,改颜色
4个回答
你的颜色函数使用的位置不对哦。
report in is a reference to the report whose appearance, data, and printing you want to control. Use the Create Report VI to generate this LabVIEW class object.
value contains an array of strings to insert into the table cell. table index specifies the index of the table to edit. The default is –1, in which the VI modifies the last table in the current document. Note Graphs, tables, images, ActiveX controls, and OLE objects form a collection for each document. Each object has an index value based on the order of the objects in the document. Index values begin at 0. For example, if you insert two images into the document before you insert a graph, the index value for the graph is 2. error in describes error conditions that occur before this node runs. This input provides standard error in functionality. start defines the position of the edited cell. rows specifies the row index. columns specifies the column index. report out is a reference to the report whose appearance, data, and printing you want to control. You can wire this output to other Report Generation VIs. error out contains error information. This output provides standard error out functionality. |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
111 浏览 0 评论
148 浏览 0 评论
152 浏览 0 评论
1145 浏览 1 评论
Labview在生成安装文件的时候,提示“在本计算机上找不到已选定的某些安装程序”
1314 浏览 1 评论
GMT+8, 2024-4-23 20:42 , Processed in 0.473546 second(s), Total 43, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
