发 帖
原厂入驻New
[资料] Cadence原理图中Title Blocks的使用方法(一)
2020-1-2 18:47:55  585 Cadence
分享
以下的关键字可应用在自己绘制的title Blocks:
软件版本:Cadence OrCAD Capture CIS 17.2
Cage Code
SpecIFies  the Cage Code. You can set the value for this property in the Title Block tab  of the Design Template dialog box (Options - Design Template).
Design Create Date
Specifies  the date of creation for the design. The value for this property is set  automatically.
Design Create Time
Specifies  the time of creation for the design. The value for this property is set  automatically.
Design File Name
Specifies  the path and file name of the design file. The value for this property is set  automatically.
Design Modify Date
Specifies  the date of the last modification to the design. The value for this property  is set automatically.
Design Modify Time
Specifies  the time of the last modification to the design. The value for this property  is set automatically.
Design Name
Specifies  the name of the design. The value for this property is set automatically.
Doc
Specifies  the document number. You can set the value for this property in the Title  Block tab of the Design Template dialog box (Options - Design Template).
Name
Specifies  the name of the title block. By default, this is the name of the symbol in  the library. You can manually update this field.
OrgAddr1
Specifies  the first line of the organization address. You can set the value for this  property in the Title Block tab of the Design Template dialog box (Options -  Design Template).
OrgAddr2
Specifies  the second line of the organization address. You can set the value for this  property in the Title Block tab of the Design Template dialog box (Options -  Design Template).
OrgAddr3
Specifies  the third line of the organization address. You can set the value for this  property in the Title Block tab of the Design Template dialog box (Options -  Design Template).
OrgAddr4
Specifies  the fourth line of the organization address. You can set the value for this  property in the Title Block tab of the Design Template dialog box (Options -  Design Template).
OrgName
Specifies  the organization name. You can set the value for this property in the Title  Block tab of the Design Template dialog box (Options - Design Template).
Page Count
Specifies  the number of schematic pages in the design. This value is updated when you  annotate a design.
Page Create Date
Specifies  the date of creation for the schematic page. The value for this property is  set automatically.
Page Create Time
Specifies  the time of creation for the schematic page. The value for this property is  set automatically.
Page Modify Date
Specifies  the date of the last modification to the schematic page. The value for this  property is set automatically.
Page Modify Time
Specifies  the time of the last modification to the schematic page. The value for this  property is set automatically.
Page Name
Specifies  the name of the schematic page. The value for this property is set  automatically.
Page Number
Specifies  the number of the schematic page. The page number determines when it will be  printed in relation to the other schematic pages of the design. This value is  updated when you annotate a design.
Page Size
Specifies  the page size of the schematic page, as was set at creation time.
RevCode
Specifies  the revision. You can set the value for this property in the Title Block tab  of the Design Template dialog box (Options - Design Template).
Schematic Create  Date
Specifies  the date of creation for the schematic. The value for this property is set  automatically.
Schematic Create Time
Specifies  the time of creation for the schematic. The value for this property is set  automatically.
Schematic Modify Date
Specifies  the date of the last modification to the schematic. The value for this  property is set automatically.
Schematic Modify Time
Specifies  the time of the last modification to the schematic. The value for this  property is set automatically.
Schematic Page Count
Specifies  the number of schematic pages in the given schematic. This value is updated when you annotate a design.
Schematic Page Number
Specifies  the order of the schematic page within the schematic. This value is updated when you annotate a design.
Source Library
Specifies  the path and file name of the library from where the title block was placed.  The value for this property is set automatically.
Source Symbol
Specifies  the name of the symbol for the title block in the Source Library. The value  for this property is set automatically.
Title
Specifies  the title. You can set the value for this property in the Title Block tab of  the Design Template dialog box (Options - Design Template).
1
分享淘帖 显示全部楼层
· 2020-1-10 13:39:21
感谢楼主,好资料,值得学习,认真学习一下!
高级模式
您需要登录后才可以回帖 登录 | 注册
声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容图片侵权或者其他问题,请联系本站作侵删。 侵权投诉
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
