发 帖
原厂入驻New
申请华秋企业认证 多层板首单免费打样!
30s提交资料,10分钟通过审核(免费赔付+顺丰包邮)>>立即报名
[问答] dsp生成pwm波形控制mos管
430 DSP PWM MOS管
分享
在生成的pwm波生成的栅极脉冲信号时,使用AQ生成的是方波 ,但是运行仿真时,使用示波器测试后发现是三角波,哪位大神可以帮忙解答一下程序如下
#include "Example_2823xEPwm_duty.h"
#include "DSP2833x_Device.h"     // DSP2833x HeadeRFile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
#define   Hall_num1   0x5  //BLDC电机的霍尔相序
#define   Hall_num2   0x1
#define   Hall_num3   0x3
#define   Hall_num4   0x2
#define   Hall_num5   0x6
#define   Hall_num6   0x4
//#include "DSP2833x_GlobalPrototypes.h"
//Uint16    *ExRamstart = (Uint16 *)0x100000;
void EPwm_Setup(void);          //所有函数不用出现
void changephase(void);
void Init_FMQ_voice(void);
void Start_car(void);
void Stop_car(void);
void HVDMC_Protection(void);
void MOS_V1_V4PWM(void) ;  // 切换V1V4MOS驱动
void MOS_V1_V6PWM(void) ;  // 切换V1V6MOS驱动
void MOS_V3_V6PWM(void) ;  // 切换V3V6MOS驱动
void MOS_V3_v2PWM(void) ;  // 切换V3V2MOS驱动
void MOS_V5_V2PWM(void) ;  // 切换V5V2MOS驱动
void MOS_V5_V4PWM(void) ;  // 切换V5V4MOS驱动
interrupt void MotorControl_ISR(void);
Uint16 hall=0;          //赋值0 在Example_2823xEPwm_duty.h外部变量
Uint16 ThreeHall_H[3]={0,0,0};
Uint16 ThreeHall_State=0;
Uint16 ThreeHall_text[50]={0};
Uint16 ThreeHall_OldState=0;
Uint16 ThreeHall_Speed_count=0;
Uint16 count1=0;
Uint16 count2=0;
Uint16 duty=5000;
void main(void)
   //初始化系统、中断
   InitSysCtrl();   //Initialize System Control
   InitPieCtrl();   // Initialize the PIE control registers to their default state.
   InitPieVectTable();    // Initialize the PIE vector table with pointers to the shell Interrupt
   // Interrupts that are used in this example are re-mapped to
   InitePwmGpio(); //Initialize pwmGPIO   √
//  InitECapGpio();    // √
   Init_FMQ_voice();   // √   在线调试所以先不对电机三霍尔的GPIO初始化
//  InitFlash();
     EPwm_Setup();       //初始化EPwm;
  // InitECap();        //初始化捕获
     CpuTimer0Regs.PRD.all = 30000000;   //  200ms          500MS   75 000000
    HVDMC_Protection( ); //PWM的保护初始化
    EALLOW;
    PieVectTable.EPWM1_INT = &MotorControl_ISR;     //指向中断函数  PWM中断
    EDIS;
    EALLOW;
    PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // 使能 PIE 时钟
    PieCtrlRegs.PIEIER3.bit.INTx1 = 1;   // 中断向量  EPWM1
       //启动EPWM 1 中断
    EPwm1Regs.ETSEL.bit.INTEN = 1;   // Enable EPWM1INT generation
    EPwm1Regs.ETSEL.bit.INTSEL = 1;  // Enable interrupt CNT_zero event
    EPwm1Regs.ETPS.bit.INTPRD = 1;   // 产生周期事件中断
    EPwm1Regs.ETCLR.bit.INT = 1;     // 使能更多中断
    IER |= M_INT3;  //使能 中断向量
    EINT;   // 使能全局中断 INTM
    ERTM;   // 使能全局中断 DBGM
    EDIS;
// Step 6. IDLE loop. Just sit and loop forever (optional):
    //Start_car();
    for(;;);
                          /*换向函数*/
        //捕获霍尔信号
             ThreeHall_H[0]=GpioDataRegs.GPCDAT.bit.GPIO67;
             ThreeHall_H[1]=GpioDataRegs.GPCDAT.bit.GPIO68;
             ThreeHall_H[2]=GpioDataRegs.GPCDAT.bit.GPIO69;
             ThreeHall_State=ThreeHall_H[0]+(ThreeHall_H[1]<<1)+(ThreeHall_H[2]<<2);
IF ( ThreeHall_State!=ThreeHall_OldState )
        /*ThreeHall_text[count1]=ThreeHall_State;
         count1++;                                                    //  记录霍尔状态数据
          if( count1>49)
           count1=0;
switch (ThreeHall_State)
   case Hall_num1:    //换向   V1、V4导通
    MOS_V1_V4PWM();
           break;
   case Hall_num2:    //换向   V1、V6导通
    MOS_V1_V6PWM() ;
           break;
   case Hall_num3:     //换向   V3、V6导通
   MOS_V3_V6PWM() ;
           break;
   case Hall_num4:    //换向   V3、V2导通
    MOS_V3_V2PWM() ;
           break;
   case Hall_num5:     //换向   V5、V2导通
   MOS_V5_V2PWM() ;
           break;
   case Hall_num6:     //换向   V5、V4导通
   MOS_V5_V4PWM() ;
           break;
default:
            Stop_car();
    break;
else  if ( ThreeHall_State==ThreeHall_OldState )        //  ( Hall_Three.Hall_State==Hall_Three.OldHall_State )
            ThreeHall_Speed_count++;
     if( ThreeHall_Speed_count>=5000 )
             Stop_car();
         MOS_V1_V4PWM();
                break;
         MOS_V1_V6PWM() ;
                break;
         MOS_V3_V6PWM() ;
                break;
         MOS_V3_V2PWM() ;
                break;
         MOS_V5_V2PWM() ;
                break;
         MOS_V5_V4PWM() ;
                break;
     default:
                 Stop_car();
         break;
        ThreeHall_OldState=ThreeHall_State;*/
             /*6种PWM状态的开关管*/
void MOS_V1_V4PWM(void) //开关管V1和V4导通
{   // Set action
EALLOW;
         EPwm1Regs.AQCSFRC.bit.CSFA=0x0;
         EPwm1Regs.AQCSFRC.bit.CSFB=0x1;
         EPwm2Regs.AQCSFRC.bit.CSFA=0x1;
         EPwm2Regs.AQCSFRC.bit.CSFB=0x2;
         EPwm3Regs.AQCSFRC.bit.CSFA=0x1;
         EPwm3Regs.AQCSFRC.bit.CSFB=0x1;
         EPwm1Regs.AQCTLA.bit.CAU = 0x2;
         EPwm1Regs.AQCTLA.bit.CAD = 0x1;
         EPwm1Regs.AQCTLB.bit.CBU = 0x0;
         EPwm1Regs.AQCTLB.bit.CBD = 0x0;
         EPwm2Regs.AQCTLA.bit.CAU = 0x0;
         EPwm2Regs.AQCTLA.bit.CAD = 0x0;
         EPwm2Regs.AQCTLB.bit.CBU = 0x2;
         EPwm2Regs.AQCTLB.bit.CBD = 0x2;
         EPwm3Regs.AQCTLA.bit.CAU = 0x0;
         EPwm3Regs.AQCTLA.bit.CAD = 0x0;
         EPwm3Regs.AQCTLB.bit.CBU = 0x0;
         EPwm3Regs.AQCTLB.bit.CBD = 0x0;
EDIS;
    // Hall_Three.MOSFET_State = 0x32;
void MOS_V1_V6PWM(void)   //开关管V1和V6导通
{   // Set actions
EALLOW;
         EPwm2Regs.AQCSFRC.bit.CSFB=0x1;
         EPwm3Regs.AQCSFRC.bit.CSFB=0x2;
         EPwm2Regs.AQCTLB.bit.CBU = 0x0;
         EPwm2Regs.AQCTLB.bit.CBD = 0x0;
         EPwm3Regs.AQCTLB.bit.CBU = 0x2;
         EPwm3Regs.AQCTLB.bit.CBD = 0x2;
EDIS;
      //Hall_Three.MOSFET_State= 0x25;
void MOS_V3_V6PWM(void)   //开关管V3和V6导通
{   // Set actions
EALLOW;
         EPwm1Regs.AQCSFRC.bit.CSFA=0x1;
         EPwm2Regs.AQCSFRC.bit.CSFA=0x0;
         EPwm1Regs.AQCTLA.bit.CAU = 0x0;
         EPwm1Regs.AQCTLA.bit.CAD = 0x0;
         EPwm2Regs.AQCTLA.bit.CAU = 0x2;
         EPwm2Regs.AQCTLA.bit.CAD = 0x1;
EDIS;
      // Hall_Three.MOSFET_State = 0x54;
void MOS_V3_V2PWM(void)     //开关管V3和V2导通
{   // Set actions
EALLOW;
         EPwm1Regs.AQCSFRC.bit.CSFB=0x2;
         EPwm1Regs.AQCTLB.bit.CBU = 0x2;
         EPwm1Regs.AQCTLB.bit.CBD = 0x2;
EDIS;
void MOS_V5_V2PWM(void)         //开关管V5和V2导通
{   // Set actions
EALLOW;
         EPwm3Regs.AQCSFRC.bit.CSFA=0x0;
         EPwm3Regs.AQCTLA.bit.CAU = 0x2;
         EPwm3Regs.AQCTLA.bit.CAD = 0x1;
EDIS;
void MOS_V5_V4PWM(void)     //开关管V5和V4导通
{   // Set actions
EALLOW;
         EPwm2Regs.AQCTLB.bit.CBD = 0x1;
EDIS;
void Stop_car(void)
         EALLOW;
         EDIS;
         EALLOW;
         EPwm1Regs.CMPA.half.CMPA = duty;
         EPwm1Regs.CMPB = duty;
         EPwm2Regs.CMPA.half.CMPA = duty;
         EPwm2Regs.CMPB = duty;
         EPwm3Regs.CMPA.half.CMPA = duty;
         EPwm3Regs.CMPB = duty;
     EDIS;
         changephase();
         EPwm1Regs.ETCLR.bit.INT = 1; // 使能中断
     PieCtrlRegs.PIEACK.all = PIEACK_GROUP3; //开中断向量
     Start_car();
     ThreeHallout_PWM();
void ThreeHallout_PWM(void)
       EALLOW;
       EPwm1Regs.TZSEL.bit.CBC6=0x1;
       EPwm2Regs.TZSEL.bit.CBC6=0x1;
       EPwm3Regs.TZSEL.bit.CBC6=0x1;
       EPwm1Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
       EPwm2Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
       EPwm3Regs.TZSEL.bit.OSHT1   = 1;  //enable TZ1 for OSHT
       EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
       EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
       EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
       EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
       EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // EPWMxA will go low
       EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // EPWMxB will go low
       EDIS;
// No more.
2019-11-13 20:46:25   评论 分享淘帖 邀请回答
相关问题
1个回答
2019-11-14 22:04:10 评论
举报
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
高级模式
您需要登录后才可以回帖 登录 | 注册
我要提问
关闭
站长推荐 上一条 /7 下一条
快速回复 返回顶部 返回列表
