在用LCD12864的串行控制,程序如下:
//写指令 void LCD12864_write_com(unsigned char com) { unsigned char dattemp,i; LCD12864_cs = 1; dattemp = 0xf8; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } dattemp = com & 0xf0; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } dattemp = (com << 4) & 0xf0; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } LCD12864_sclk = 0; LCD12864_sid = 1; LCD12864_cs = 0; } //写数据 void LCD12864_write_dat(unsigned char dat) { unsigned char dattemp,i; LCD12864_cs = 1; dattemp = 0xfa; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } dattemp = dat & 0xf0; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } dattemp = (dat << 4) & 0xf0; for (i = 0; i < 8; i++) { dattemp <<= 1; LCD12864_sclk = 0; delay9us(1); LCD12864_sid = CY; delay9us(1); LCD12864_sclk = 1; } LCD12864_sclk = 0; LCD12864_sid = 1; LCD12864_cs = 0; } 主函数如下: void main() { LCD12864_init(); LCD12864_write_com(0x80); LCD12864_write_dat('0'); LCD12864_write_dat('1'); while(1); } 这样写就不会显示01,但如果把写指令函数中的LCD12864_cs = 0;删掉,就只会显示一个0,如果再把写数据函数中的LCD12864_cs = 0;删掉就能显示01了。这样感觉就是LCD12864_write_com(0x80);中的LCD12864_cs = 0;是的后面的显示数据都失效了,而LCD12864_write_dat('0');中的LCD12864_cs = 0;也会让后面的LCD12864_write_dat('1');失效。但我两个函数一开始就又把LCD12864_cs置一了。实在想不通为什么。后面我又试了,把那三句顺序改变,改为 LCD12864_cs = 0; LCD12864_sclk = 0; LCD12864_sid = 1; 也可以正常显示。这是CS的时序问题吗,还请各位指点一下。 |
1个回答
我试过将CS线去掉,用电阻拉高,只要2根信号线也能正常显示
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
GMT+8, 2024-4-25 02:26 , Processed in 0.523071 second(s), Total 70, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
