硬件平台: 蓝牙 和 MSP430 音频信宿参考设计 CC2564 + MSP430F5229
http://www.ti.com.cn/tool/cn/bt- ... -CN#descriptionArea 软件版本:Bluepia for MSP430 V1.4 R2 使用的工程: C:tiConnectivityCC256X BTCC256x MSP430 Bluetopia SDKv1.4 R2MSP430_ExperimentorSamplesA3DPDemo_SNKProjectsIAR IAR for MSP430 版本: V6.10.1 —————————————————— (1)打开工程A3DPDemo_SNK,默认的MCU型号为 MSP430F5438A,编译结果如下: ----优化等级 高(Size) 121 646 bytes of CODE memory 7 864 bytes of DATA memory (+ 89 absolute ) 9 627 bytes of CONST memory ----优化等级为低; 126 130 bytes of CODE memory 7 864 bytes of DATA memory (+ 89 absolute ) 9 629 bytes of CONST memory (2)更改MCU型号为MSP430F5229: 编译结果如下: ---优化等级为低; Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE. Unable to place 209 block(s) (0x1ea5e byte(s) total) in 0x1dfea byte(s) of memory. The problem occurred while processing the segment placement command "-P(CODE)CODE=4400-FF7F,10000-243FF", where at the moment of placement the available memory ranges were "CODE:6396-ff7f,CODE:10000-243ff" Error while running Linker 0x1ea5e byte -- 122KB 0x1dfea byte(s) -- 119KB ---优化等级为高(Size) Error[e16]: Segment DATA20_C (size: 0x7e5 align: 0) is too long for segment definition. At least 0xd3 more bytes needed. The problem occurred while processing the segment placement command "-Z(CONST)DATA20_C,DATA20_ID=4400-FF7F,10000-243FF", where at the moment of placement the available memory ranges were "CODE:23cee-243ff" Reserved ranges relevant to this placement: 4400-6105 DATA16_C 6106-61b5 DATA16_ID 61b6-61e5 CSTART 61e6-636d ISR_CODE 636e-ff7f CODE 10000-23ced CODE 23cee-243ff DATA20_C Error while running Linker 问题: (1)在哪可以下载到DEMO板可以使用的工程? http://processors.wiki.ti.com/in ... dio_Sink_User_Guide ---上面提到的下载地址,就是Bluetopia的软件包,解压之后出现的问题如本贴描述。 (2)MSP430F5229有128K的Flash空间,实际编译出来的代码并未大于128K,就已经提示空间不足。 ----是否有优化代码分配的配置选项? 例如ccs中lnk_msp430f5529.cmd文件,可以直接查看地址分配? |
1 个讨论
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3648 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9382 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
676浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1773浏览 1评论
GMT+8, 2024-4-25 06:32 , Processed in 0.597547 second(s), Total 71, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
