pingingI有一个VEE程序,提示用户输入他们正在测试的单元的序列号。
如果操作员在大约10分钟内未输入序列号,则计算机开始发出蜂鸣声,例如 从计算机扬声器听到大约一秒钟的响铃。我没有把它放到程序中,并且想知道这是否是VEE自动的东西。 还有其他人经历过这个吗?罗斯 以上来自于谷歌翻译 以下为原文 pingingI have a VEE program that prompts the user to enter the serial number of the unit they are testing. If the operator does not enter a serial number within approximately 10 minutes the computer starts to beep e.g. an audible bell is heard from the computers speaker about once a second.I didn't put this into the program and was wondering if this is something automatic with VEE. Has anybody else experienced this ?Ross |
4个回答
大家好,有没有更优雅的方法将Int32分成两个有效的Int 16(签名),即MSB和LSB?
目前我将这个数字写成一个二进制文件作为Int32并将其作为Int16读回。任何帮助都将受到赞赏.Reiner SchliekerTest设备设计师西门子Milltronics过程仪器公司电话:(705)740-7553传真:(705)740-7692e -mail:reiners@milltronics.com------------------------------------------ ---------------------------这是由Majordomo管理的“vrf”maillist。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 Hello All, Is there a more elegant way to split an Int32 into two valid Int 16's (signed) i.e. MSB and LSB? Currently I write the number to a binary file as an Int32 and read it back as an Int16. Any help would be appreciated. Reiner Schlieker Test Equipment Designer Siemens Milltronics Process Instruments Inc. Phone: (705) 740-7553 Fax: (705) 740-7692 e-mail: reiners@milltronics.com --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
威廉,a)我从不使用延迟对象的数据输出引脚,只需继续.b)使用Sample& Hold Object来解决像你这样的问题。
Georg Nied Software-DevelopmentHansestr.7 - 51149科隆德国邮箱:info@gn-software.de------------------------------ ---------------------------------------这是由Majordomo管理的“vrf”maillist 。 要向该maillist发送消息,只需发送电子邮件至“vrf@lvld.agilent.com”。 订阅和取消订阅是通过地址“vrf-request@lvld.agilent.com”完成的。如果您需要详细信息,只需将包含“help”文本的消息发送到“vrf-request@lvld.agilent.com”.--- -------------------------------------------------- ---------------- 以上来自于谷歌翻译 以下为原文 William, a) I never use the data out pin of the delay object, just continue after . b) Use the Sample&Hold Object to solve problems like yours. Georg Nied Software-Development Hansestr.7 - 51149 Cologne Germany Mail: info@gn-software.de --------------------------------------------------------------------- This is the "vrf" maillist, managed by Majordomo. To send messages to this maillist, just email to "vrf@lvld.agilent.com". Subscriptions and unsubscriptions are done through the address "vrf-request@lvld.agilent.com". If you need details, just send a message containing the text "help" to "vrf-request@lvld.agilent.com". --------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2096 浏览 1 评论
1854 浏览 1 评论
1712 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2257浏览 0评论
GMT+8, 2024-4-24 12:53 , Processed in 0.563822 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
