使用JZ2440V2板子出现问题:Root-NFS: Unable to get mountd port number from server, using default
使用uboot 加载 nfs 30000000 192.168.1.101:/work/nfs_root/uImage_nonand /*uImage_nonand是按照韦老师视频去掉nand驱动部分*/ bootm 30000000 出现以下错误,无法挂接根文件系统,奇怪的是不使用uImage_nonand,却能正常挂接NFS根文件系统,请问哪里出错了。 ------------------------------------------------------------------------------------------------------------------------------------------------------ book@book-desktop:~$ sudo /etc/init.d/nfs restart sudo: /etc/init.d/nfs: command not found /*找不到命令,为何*/ book@book-desktop:~$ service portmap status portmap start/running, process 700 book@book-desktop:~$ service nfs status nfs: unrecognized service /*不成功*/ ------------------------------------------------------------------------------------------------------------------------------------------------------ sudo service portmap restart service portmap status portmap start/running, process 700 ------------------------------------------------------------------------------------------------------------------------------------------------------ sudo /etc/init.d/nfs-kernel-server restart book@book-desktop:~$ sudo /etc/init.d/nfs-kernel-server restart * Stopping NFS kernel daemon ...done. * Unexporting directories for NFS kernel daemon... ...done. * Exporting directories for NFS kernel daemon... exportfs: No options for /work/nfs_root 192.168.1.: suggest 192.168.1.(sync) to avoid warning exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "192.168.1.:/work/nfs_root". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/work/nfs_root". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x exportfs: No options for /work/nfs_root/first_fs 192.168.1.: suggest 192.168.1.(sync) to avoid warning exportfs: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "192.168.1.:/work/nfs_root/first_fs". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x exportfs: /etc/exports [2]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/work/nfs_root/first_fs". Assuming default behaviour ('no_subtree_check'). NOTE: this default has changed since nfs-utils version 1.0.x ...done. * Starting NFS kernel daemon ...done. ---------------------------------------------------------------------------------------------------- service --status-all信息如下:book@book-desktop:~$ service --status-all [ ? ] acpi-support [ ? ] acpid [ ? ] alsa-utils [ ? ] anacron [ - ] appARMor [ ? ] apport [ ? ] atd [ ? ] avahi-daemon [ ? ] binfmt-support [ - ] bluetooth [ - ] bootlogd [ - ] brltty [ ? ] console-setup [ ? ] cron [ + ] cups [ ? ] dbus [ ? ] dmesg [ ? ] dns-clean [ ? ] gdm [ - ] grub-common [ ? ] gssd [ ? ] hal [ ? ] hwclock [ ? ] hwclock-save [ ? ] idmapd [ - ] jetty [ + ] kerneloops [ ? ] keyboard-setup [ ? ] killprocs [ - ] laptop-mode [ ? ] module-init-tools [ ? ] network-manager [ ? ] networking [ + ] nfs-kernel-server [ ? ] ondemand [ ? ] openbsd-inetd [ ? ] pcmciautils [ ? ] portmap [ ? ] pppd-dns [ ? ] procps [ + ] pulseaudio [ ? ] rc.local [ ? ] rpc_pipefs [ - ] rsync [ ? ] rsyslog [ ? ] rsyslog-kmsg [ - ] saned [ ? ] screen-cleanup [ ? ] sendsigs [ ? ] speech-dispatcher [ ? ] sreadahead [ + ] ssh [ ? ] statd [ ? ] stop-bootlogd [ ? ] stop-bootlogd-single [ ? ] udev [ ? ] udev-finish [ ? ] udevmonitor [ ? ] udevtrigger [ ? ] ufw [ ? ] umountfs [ ? ] umountnfs.sh [ ? ] umountroot [ ? ] unattended-upgrades [ - ] urandom [ ? ] usplash [ + ] vsftpd [ ? ] wpa-ifupdown [ - ] x11-common --------------------------------------------------------------打印信息------------------------------------------------------------------------------------------------------------------- OpenJTAG> nfs 30000000 192.168.1.101:/work/nfs_root/uImage_nonand ERROR: resetting DM9000 -> not responding dm9000 i/o: 0x20000000, id: 0x90000a46 DM9000: running in 16 bit mode MAC: 08:00:3e:26:0a:5b could not establish link File transfer via NFS from server 192.168.1.101; our IP address is 192.168.1.123 Filename '/work/nfs_root/uImage_nonand'. Load address: 0x30000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# #################################### done Bytes transferred = 1845496 (1c28f8 hex) OpenJTAG> bootm 30000000 ## Booting image at 30000000 ... Image Name: Linux-2.6.22.6 Created: 2014-07-28 14:55:03 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1845432 Bytes = 1.8 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK OK Starting kernel ... Uncompressing Linux...................................................................................................................... done, booting the kernel. NET: Registered protocol family 1 drivers/rtc/hctosys.c: unable to open rtc device (rtc0) eth0: link down IP-Config: Complete: device=eth0, addr=192.168.1.102, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.102, domain=, nis-domain=(none), bootserver=192.168.1.101, rootserver=192.168.1.101, rootpath= Looking up port of RPC 100003/2 on 192.168.1.101 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1 rPCBind: server 192.168.1.101 not responding, timed out Root-NFS: Unable to get nfsd port number from server, using default Looking up port of RPC 100005/1 on 192.168.1.101 rpcbind: server 192.168.1.101 not responding, timed out Root-NFS: Unable to get mountd port number from server, using default mount: server 192.168.1.101 not responding, timed out Root-NFS: Server returned error -5 while mounting /work/nfs_root/first_fs VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "nfs" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) |
3个回答
去掉NAND的时候,把网卡相关的也去掉了?
如果不去掉内核配置的nand驱动模块,正常的直接就直接可以挂在根文件系统了,但是也无法做这个nandflash的linux驱动试验了,还有接下来的norflash驱动。
只是去掉了nandflash部分,net部分没动,请看截图: |
做nandflash驱动测试 还是在板子上做好吧 板子启动后 用 mount -t nfs -o nolock IP:目录 /mnt 然后把.ko拷贝到板子上做测试就可以了
只有小组成员才能发言,加入小组>>
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2010 浏览 6 评论
1823 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4377 浏览 1 评论
GMT+8, 2024-4-18 14:46 , Processed in 0.751859 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
