在过去的几天里,我一直在尝试为HP54615B示波器找到替换键盘P N 54600-66052。
显然,安捷伦在2006年放弃了对该项目的支持,不再需要更换零件。 我已将示波器故障范围缩小到单个机械旋转编码器,用于通过前面板设置触发电平。 该部件的后盖上印有9707和1-2-36。 它是一个3针,2个正交通道,每转9个脉冲,无制动器,连续旋转编码器。 是否可以找到该部件的原始制造商的部件号或功能替换件? 将这个范围隐藏在这样一个小问题上是一种耻辱。 谢谢你提供的所有帮助。 以上来自于谷歌翻译 以下为原文 For the past few days I’ve been trying to locate a replacement keyboard PN 54600-66052 for the HP54615B oscilloscope. Evidently Agilent dropped the support for this item in 2006 and no longer has replacement parts. I have narrowed the scope’s failure down to a single mechanical rotary encoder that is used for setting the trigger level via the front panel. The part has 9707 and 1-2-36 stamped on its rear cover. It is a 3-pin, 2 quadrature channel, 9 pulse per rotation, no detent, continuously rotating encoder. Is it possible to find the original manufacturer’s part number for this part or a functional replacement? It's a shame to mothball this scope over such a minor issue. Thanks for any help you can give. |
4个回答
我的两台54616C示波器都遇到了类似的问题。
当旋转旋钮时,示波器上的时间和电压旋钮(两个通道)都会产生不稳定的值。 在相同方向上的两次单击可以产生一步,然后向下一步。 这在一个非常好的设备中真的很烦人。 显然,旋转编码器产生不稳定的值。 它们要么磨损要么脏。 是否可以获得范围的原理图? 是否有可能获得制造商和零件号。 有关这些旋转编码器的信息? 谢谢迈克尔 以上来自于谷歌翻译 以下为原文 I am having a similar issue with both of my 54616C oscilloscope. The knobs for time and voltage (both channels) on both oscilloscopes generate unstable values when turning the knobs. Two clicks in the same direction may produce one step up followed by one step down. This is really annoying in an otherwise nice piece of equipment. Clearly the rotary encoders are producing unstable values. They are either worn or dirty. Is it possible to get schematics of the scope? Is it possible to get manufacturer and part no. information on these rotary encoders? Thanks Michael |
cqeqw 发表于 2019-10-22 14:19 安捷伦可能会在某处获取此信息,但我只是用Google搜索“54616手册”并获得以下链接:5461X用户和服务指南这可能是您可以做的最好的。 人 以上来自于谷歌翻译 以下为原文 There's probably somewhere within Agilent to get this info, but I just Googled "54616 manuals" and got the following link: 5461X User and Service Guide This might be the best you can do. Al |
cqeqw 发表于 2019-10-22 14:19 我也有这个范围。 编码器多年来变脏和油腻。 如果它不稳定地移动,只需在每个方向拨打200+完整旋转(不要交替)直到你的手累了。 如果它不起作用,PM我,因为我有一些部分范围,我可以挽救键盘。 祝你好运! 以上来自于谷歌翻译 以下为原文 I have this scope as well. The encoder gets dirty and greasy over years. If it's moving erratically, just dial it 200+ full rotations at each direction (do not alternate) until your hand get tired. If it doesn't work, PM me as I do have some parts scopes that I can salvage the keyboard from. Good luck! |
我找到了一个有点机械和电气兼容的编码器,除了它是每转12个脉冲而不是9个。不幸的是,这并没有解决接收到这个信号的IC在两个通道之一上保持高电平的问题。
它似乎不是由键盘电路引起的,而是由系统板上的IC引起的。 没有一个像样的原理图,我没有希望解决这个问题。 编码器部件号为PEC11-4020F-N0012,可在Mouser找到。 请注意,旧编码器上的公共端子位于设备的左下方,而更换的公共端子位于中间,因此需要焊接跨接线才能使其工作。 以上来自于谷歌翻译 以下为原文 I found an somewhat mechanically and electrically compatible encoder except that it was 12 pulses per revolution instead of 9. Unfortunately this didn't fix the problem it appears that IC that receives this signal is staying high on one of the two channels. It doesn't appear to be caused by the keyboard circuitry but rather by an IC on the system board. Without a decent schematic I have little hope of solving this issue. The encoder part number is PEC11-4020F-N0012 and can be found at Mouser. Note that the common terminal on the old encoder is on the lower left of the device while the replacement's common is in the middle so jumper wires need to be soldered for this to work. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2574 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1557 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-18 15:44 , Processed in 1.332422 second(s), Total 74, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
