配置信息:
OpenJTAG> set bootargs noinitrd root=/dev/nfs nfsroot=172.20.72.126:/work/nfs_root/tmp/fs_mini_mdev ip=172.20.75.120:172.20.75.126:172.20.74.1:255.255.254.0::eth0:off init=/linuxrc console=ttySAC0 OpenJTAG> save Saving Environment to NAND... Erasing Nand...Writing to Nand... done OpenJTAG> reboot 重启打印信息: IP-Config: Complete: device=eth0, addr=172.20.75.120, mask=255.255.254.0, gw=172.20.74.1, host=172.20.75.120, domain=, nis-domain=(none), bootserver=172.20.75.126, rootserver=172.20.72.126, rootpath= Looking up port of RPC 100003/2 on 172.20.72.126 rPCBind: server 172.20.72.126 not responding, timed out Root-NFS: Unable to get nfsd port number from server, using default Looking up port of RPC 100005/1 on 172.20.72.126 rpcbind: server 172.20.72.126 not responding, timed out Root-NFS: Unable to get mountd port number from server, using default mount: server 172.20.72.126 not responding, timed out Root-NFS: Server returned error -5 while mounting /work/nfs_root/tmp/fs_mini_mdev VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "nfs" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 2048 mtdblock2 (driver?) 1f03 259712 mtdblock3 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) |
12个回答
够详细吧:http://www.100ask.org/bbs/forum. ... id=14657&extra=
nfsroot的IP地址到底错在哪?难道不是虚拟机的IP地址?
这个我看过了,也按照上面的操作了,但还是出现同样的问题呀,能不能告诉到底错哪呀。卡在这好几天了。。
这个地方出错确实很粗心。但是改过来以后,仍然出现同样的问题。虚拟机IP:172.20.75.126;开发板IP:172.20.75.120:网关和子网掩码也没错。请问我错在哪了?这个问题搞得我有点烦躁上火了(我是严格按视频步骤做的,做了好几次了)
参数配置只是其一,网络连接错误的话,参数配置的再好也没有用。
视频中, 1.开发板、PC都用网线接到了路由器上,三者ip在同一网段 2.nfs目录/work/nfs_root/tmp/fs_mini_mdev 在虚拟机/etc/exports中声明了 3.开发板在uboot状态下能够ping通虚拟机 你能满足以上条件就不会错。 |
你好。又做了一遍,这次的现象是这样:
IP-Config: Complete: device=eth0, addr=172.20.75.120, mask=255.255.254.0, gw=172.20.74.1, host=172.20.75.120, domain=, nis-domain=(none), bootserver=172.20.75.245, rootserver=172.20.75.245, rootpath= Looking up port of RPC 100003/2 on 172.20.75.245 Looking up port of RPC 100005/1 on 172.20.75.245 VFS: Mounted root (nfs filesystem). Freeing init memory: 140K init started: BusyBox v1.7.0 (2008-01-22 10:04:09 EST) starting pid 765, tty '': '/etc/init.d/rcS' nfs: server 172.20.75.245 not responding, still trying 这又是什么问题呢? |
/etc/init.d/rcS 文件有问题。去看看二楼给你的链接,那里面说到这个问题了
你的网关是不是也写错了
好棒啊,终于找到了跟我完全一样错误的人。所以,你解决问题了吗?应该怎么做呢?求分享经验~~
修改nfs目录中 etc/init.d/rcS ,把 ifconfig那条命令去掉
用NFS启动时,commandline中已设置开发板IP;不要再在etc/init.d/rcS中再次设置IP
只有小组成员才能发言,加入小组>>
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2010 浏览 6 评论
1823 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4378 浏览 1 评论
GMT+8, 2024-4-20 08:42 , Processed in 0.528714 second(s), Total 80, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
