请问cc2540simpleBLEPeripheral工程中的advertData这个数组可以动态修改么,用lightblue写characteristics 1来实现动态修改advertData[]的某个元素
static uint8 advertData[] = [ 0x02, 0x01, 0x1A,0x1A, 0xFF,0x4C, 0x00,0x02,0x15, 0xB9, 0x40 ,0x7F, 0x30, 0xF5, 0xF8, 0x46, 0x6E, 0xAF, 0xF9, 0x25, 0x55, 0x6B, 0x57, 0xFE, 0x6D,// # iBeacon proximity uuid 0x00, 0x01,//# major 主要是利用characteristics 1实现动态修改这个值 0x00, 0x01,// # minor 主要是利用characteristics 1实现动态修改这个值 0xc5 ]; 下面这个函数是特征值的调用返回,在这里该作何处理呢? static void simpleProfileChangeCB( uint8 paramID ) [ uint8 newValue; switch( paramID ) [ case SIMPLEPROFILE_CHAR1: SimpleProfile_GetParameter( SIMPLEPROFILE_CHAR1, &newValue ); #if (defined HAL_LCD) && (HAL_LCD == TRUE) HalLcdWriteStringValue( "Char 1:", (uint16)(newValue), 10, HAL_LCD_LINE_3 ); #endif // (defined HAL_LCD) && (HAL_LCD == TRUE) 我在这里直接修改advertData的值,但是没用,app上接收到的值还是原先默认的值 break; |
6 个讨论
请问怎么解决的、、、我在定时事件中实时更新广播数据,结果手机端搜到的还是之前的名称,只有连接上一次之后才能显示新名称,为什么?? if ( events & SBP_START_DEVICE_EVT ) [ DMS_SNV_DEV_Name(DMS_SNV_NAME_READ, attDeviceName, sizeof(attDeviceName)); DMS_SNV_ADV_Name(DMS_SNV_NAME_READ, scanRspData, sizeof(scanRspData)); uint8 advertData[] = [ // Flags; this sets the device to use limited discoverable // mode (advertises for 30 seconds at a time) instead of general // discoverable mode (advertises indefinitely) 0x02, // length of this data GAP_ADTYPE_FLAGS, GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED, // service UUID, to notify central devices what services are included // in this peripheral 0x0b, // length of this data GAP_ADTYPE_MANUFACTURER_SPECIFIC, // some of the UUID's, but not all attDeviceName[0], attDeviceName[1], attDeviceName[2], attDeviceName[3], attDeviceName[4], attDeviceName[5], attDeviceName[6], attDeviceName[7], attDeviceName[8], attDeviceName[9], ]; GAP_UpdateAdvertisingData(simpleBLEPeripheral_TaskID, TRUE, sizeof(advertData), advertData); osal_start_timerEx( simpleBLEPeripheral_TaskID, SBP_PERIODIC_EVT, SBP_PERIODIC_EVT_PERIOD ); return ( events ^ SBP_START_DEVICE_EVT ); ] |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1898 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3648 浏览 4 评论
5032 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1736 浏览 1 评论
9382 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
669浏览 2评论
714浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
676浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1773浏览 1评论
GMT+8, 2024-4-25 04:55 , Processed in 0.478398 second(s), Total 43, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
