发 帖
原厂入驻New
申请华秋企业认证 多层板首单免费打样!
30s提交资料,10分钟通过审核(免费赔付+顺丰包邮)>>立即报名
[问答] 如何改写uboot的启动延迟?
34 uboot
分享
* (C) Copyright 2000
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* SPDX-License-Identi€€Fier:        GPL-2.0+
/* #define        debug        */
#include <common.h>
#include <autoboot.h>
#include <cli.h>
#include <version.h>
DECLARE_GLOBAL_DATA_PTR;
* Board-specific Platform code can reimplement show_boot_progress () if needed
void inline __show_boot_progress (int val) {}
void show_boot_progress (int val) __attribute__((weak, alias("__show_boot_progress")));
static void
(void)
#ifdef CONFIG_modem_SUPPORT
        debug("DEBUG: main_loop:   gd->do_mdm_init=%lu\n", gd->do_mdm_init);
        if (gd->do_mdm_init) {
                char *str = getenv("mdm_cmd");
                setenv deldy("preboot", str);  /* set or delete definition */
                mdm_init(); /* wait for modem connection */
#endif  /* CONFIG_MODEM_SUPPORT */
static void run_preboot_environment_command(void)
#ifdef CONFIG_PREBOOT
        char *p;
        p =
("preboot");
        if (p != NULL) {
# ifdef CONFIG_AUTOBOOT_KEYED
                int prev = disable_ctrlc(1);        /* disable Control C checking */
# endif
                run_command_list(p, -1, 0);
                disable_ctrlc(prev);        /* restore Control C checking */
# endif
#endif /* CONFIG_PREBOOT */
/* We come here after U-Boot is initialised and ready to process commands */
void main_loop(void)
        const char *s;
        bootstage_mark_name(BOOTSTAGE_ID_MAIN_LOOP, "main_loop");
#ifndef CONFIG_SYS_GENERIC_BOARD
        puts("Warning: Your board does not use generic board. Please read\n");
        puts("doc/README.generic-board and take action. Boards not\n");
        puts("upgraded by the late 2014 may break or be removed.\n");
#endif
        modem_init();
#ifdef CONFIG_VERSION_VARIABLE
        setenv("ver", version_string);  /* set version variable */
#endif /* CONFIG_VERSION_VARIABLE */
        cli_init();
        run_preboot_environment_command();
#if defined(CONFIG_UPDATE_TFTP)
        update_tftp(0UL);
#endif /* CONFIG_UPDATE_TFTP */
        s = bootdelay_process();
        if (cli_process_fdt(&s))
                cli_secure_boot_cmd(s);
        autoboot_command(s);
        cli_loop();
mad5d3xek的开发板的800ms延迟
2019-10-21 04:37:37   评论 分享淘帖 邀请回答
2个回答
只有小组成员才能发言,加入小组>>
63个成员聚集在这个小组
加入小组
创建小组步骤
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
