是什么原因,为什么8902A调谐射频电平性能测试采用30MHz测试频率而不是50MHz?
我们还有N5531S系统和使用50MHz的相同测试。 如果8902A调谐射频电平测试也将在50MHz运行,是否会出现大的测量误差?编辑:bar28于2012年3月27日上午5:41 以上来自于谷歌翻译 以下为原文 What is the reason, why 8902A Tuned-RF level performance test using 30MHz test frequency and not 50MHz? We have also N5531S system and there same test using 50MHz. Does it couse a big measurement error if 8902A Tuned-RF level test will be run also at 50MHz? Edited by: bar28 on Mar 27, 2012 5:41 AM |
2个回答
我相信这是参考衰减器的传统频率,使用IF替换方法校准,该方法用于测试或验证8902A中参考步骤的规范。
我怀疑您可以使用任何其他频率,因为它转换为8902A IF频率,然后您将8902IF报告的步骤与参考预期步骤进行比较。 只要您在测试频率上有实际的校准步骤,整个过程就假设第一个混频器的亮度并且测试频率无关紧要。 希望这可以帮助。 以上来自于谷歌翻译 以下为原文 I believe that this is a traditional frequency for reference attenuators that were calibrated using the IF substitution method that is being used to test or verify the specification of the reference steps in the 8902A. I suspect that you can use any other frequency as it is converted to the 8902A IF frequency and you are then comparing the 8902IF reported step to the reference expected step. The whole process is assuming the liniarity of teh 1st mixer and the frequency of test should not matter, as long as you have the actual calibration steps at the test frequency. Hope this helps. |
非常感谢。
Actualy我认为完全相同。 步骤参与者以50MHz校准。 我已经测试过使用50MHz运行8902A Tuned RF级别测试,它运行良好。 使用可重复步进的attanuator我可以一起监控我们的校准实验室的8902A,N5531S和8510C VNA的电平精度.... 50MHz也适合8510C的频率范围:-) 以上来自于谷歌翻译 以下为原文 Thanks a lot. Actualy i thought totally same way. Step attenautor is calibrated in 50MHz. I have already tested to run 8902A Tuned RF-level test using 50MHz and it works perfectly. Using repeatable step attanuator i can monitor our cal lab's 8902A, N5531S and 8510C VNA's levelig accuracy together....50MHz fits also to 8510C's frequency range :-) |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:34 , Processed in 1.022886 second(s), Total 73, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
