#include
#define uint unsigned int #define uchar unsigned char uint i,j,k,n; uchar md; const uchar sin[]= { 0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e, 0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e, 0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xab,0xad, 0xaf,0xb1,0xb2,0xb4,0xb6,0xb7,0xb9,0xba, 0xbc,0xbd,0xbf,0xc0,0xc1,0xc3,0xc4,0xc5, 0xc6,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce, 0xce,0xcf,0xd0,0xd1,0xd1,0xd2,0xd2,0xd3, 0xd3,0xd3,0xd2,0xd2,0xd1,0xd1,0xd0,0xcf, 0xce,0xce,0xcd,0xcc,0xcb,0xca,0xc9,0xc8, 0xc6,0xc5,0xc4,0xc3,0xc1,0xc0,0xbf,0xbd, 0xbc,0xba,0xb9,0xb7,0xb6,0xb4,0xb2,0xb1, 0xaf,0xad,0xab,0xaa,0xa8,0xa6,0xa4,0xa2, 0xa0,0x9e,0x9c,0x9a,0x98,0x96,0x94,0x92, 0x90,0x8e,0x8c,0x8a,0x88,0x86,0x84,0x82, 0x80,0x7d,0x7b,0x79,0x77,0x75,0x73,0x71, 0x6f,0x6d,0x6b,0x69,0x67,0x65,0x63,0x61, 0x5f,0x5d,0x5b,0x59,0x57,0x55,0x54,0x52, 0x50,0x4e,0x4d,0x4b,0x49,0x48,0x46,0x45, 0x43,0x42,0x40,0x3f,0x3e,0x3c,0x3b,0x3a, 0x39,0x37,0x36,0x35,0x34,0x33,0x32,0x31, 0x31,0x30,0x2f,0x2e,0x2e,0x2d,0x2d,0x2c, 0x2c,0x2b,0x2b,0x2b,0x2b,0x2a,0x2a,0x2a, 0x2a,0x2a,0x2a,0x2a,0x2b,0x2b,0x2b,0x2b, 0x2c,0x2c,0x2d,0x2d,0x2e,0x2e,0x2f,0x30, 0x31,0x31,0x32,0x33,0x34,0x35,0x36,0x37, 0x39,0x3a,0x3b,0x3c,0x3e,0x3f,0x40,0x42, 0x43,0x45,0x46,0x48,0x49,0x4b,0x4d,0x4e, 0x50,0x52,0x54,0x55,0x57,0x59,0x5b,0x5d, 0x5f,0x61,0x63,0x65,0x67,0x69,0x6b,0x6d, 0x6f,0x71,0x73,0x75,0x77,0x79,0x7b,0x7d, }; const uchar jc[]= { 0x00,0x02,0x04,0x06,0x08,0x0a,0x0c,0x0e, 0x10,0x12,0x14,0x16,0x18,0x1a,0x1c,0x1e, 0x20,0x22,0x24,0x26,0x28,0x2a,0x2c,0x2e, 0x30,0x32,0x34,0x36,0x38,0x3a,0x3c,0x3e, 0x40,0x42,0x44,0x46,0x48,0x4a,0x4c,0x4e, 0x50,0x52,0x54,0x56,0x58,0x5a,0x5c,0x5e, 0x60,0x62,0x64,0x66,0x68,0x6a,0x6c,0x6e, 0x70,0x72,0x74,0x76,0x78,0x7a,0x7c,0x7e, 0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e, 0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e, 0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xae, 0xb0,0xb2,0xb4,0xb6,0xb8,0xba,0xbc,0xbe, 0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcc,0xce, 0xd0,0xd2,0xd4,0xd6,0xd8,0xda,0xdc,0xde, 0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xee, 0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,0xfe }; const uchar sj[]= { 0x00,0x02,0x04,0x06,0x08,0x0a,0x0c,0x0e, 0x10,0x12,0x14,0x16,0x18,0x1a,0x1c,0x1e, 0x20,0x22,0x24,0x26,0x28,0x2a,0x2c,0x2e, 0x30,0x32,0x34,0x36,0x38,0x3a,0x3c,0x3e, 0x40,0x42,0x44,0x46,0x48,0x4a,0x4c,0x4e, 0x50,0x52,0x54,0x56,0x58,0x5a,0x5c,0x5e, 0x60,0x62,0x64,0x66,0x68,0x6a,0x6c,0x6e, 0x70,0x72,0x74,0x76,0x78,0x7a,0x7c,0x7e, 0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e, 0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e, 0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xae, 0xb0,0xb2,0xb4,0xb6,0xb8,0xba,0xbc,0xbe, 0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcc,0xce, 0xd0,0xd2,0xd4,0xd6,0xd8,0xda,0xdc,0xde, 0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xee, 0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,0xfe, 0xfe,0xfc,0xfa,0xf8,0xf6,0xf4,0xf2,0xf0, 0xee,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0, 0xde,0xdc,0xda,0xd8,0xd6,0xd4,0xd2,0xd0, 0xce,0xcc,0xca,0xc8,0xc6,0xc4,0xc2,0xc0, 0xbe,0xbc,0xba,0xb8,0xb6,0xb4,0xb2,0xb0, 0xae,0xac,0xaa,0xa8,0xa6,0xa4,0xa2,0xa0, 0x9e,0x9c,0x9a,0x98,0x96,0x94,0x92,0x90, 0x8e,0x8c,0x8a,0x88,0x86,0x84,0x82,0x80, 0x7e,0x7c,0x7a,0x78,0x76,0x74,0x72,0x70, 0x6e,0x6c,0x6a,0x68,0x66,0x64,0x62,0x60, 0x5e,0x5c,0x5a,0x58,0x56,0x54,0x52,0x50, 0x4e,0x4c,0x4a,0x48,0x46,0x44,0x42,0x40, 0x3e,0x3c,0x3a,0x38,0x36,0x34,0x32,0x30, 0x2e,0x2c,0x2a,0x28,0x26,0x24,0x22,0x20, 0x1e,0x1c,0x1a,0x18,0x16,0x14,0x12,0x10, 0x0e,0x0c,0x0a,0x08,0x06,0x04,0x02,0x00 }; const uchar fb[]= { 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff, 0xff,0xff, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00 }; void delay(void) { uint tmp; for(tmp = 10000;tmp > 0;tmp--); } #pragma vector=PORT1_VECTOR __interrupt void P1_IRQ(void) { if(P1IFG&BIT4) //第1个按键被按下 { delay(); if(P1IFG&BIT4) { while((P1IN&BIT4)==0 ); //等待按键放开 md=0X10; P1IFG =0x00; } } if(P1IFG&BIT5) //第2个按键被按下 { delay(); if(P1IFG&BIT5) { while((P1IN&BIT5)==0 ); //等待按键放开 md=0x20; P1IFG =0x00; } } if(P1IFG&BIT6) //第3个按键被按下 { delay(); if(P1IFG&BIT6) { while((P1IN&BIT6)==0 ); //等待按键放开 md=0X40; P1IFG =0x00; } } if(P1IFG&BIT7) //第4个按键被按下 { delay(); if(P1IN&BIT7) { while((P1IN&BIT7)==0 ); //等待按键放开 md=0X80; P1IFG =0x00; } } } void key_init( void ) { P1DIR=0x00; //输入 P1OUT=0X0F; P1IES=0xf0; // 选择下降沿中断 P1IE=0xf0; // 打开中断使能 P1IFG=0x00; //中断标志位清零 } int main() { WDTCTL=WDTPW+WDTHOLD; P2DIR=0XFF; P6DIR=0XFF; P6OUT=0XFF; key_init(); while(1) { _EINT(); switch(md) { case 0x10:P6OUT=0XFE;for(i=0;i<240;i++) P2OUT=sin;break; case 0x20:P6OUT=0XFD;for(j=0;j<128;j++) P2OUT=jc[j];break; case 0x40:P6OUT=0XFB;for(k=0;k<256;k++) P2OUT=sj[k];break; case 0x80:P6OUT=0XF7;for(n=0;n<256;n++) P2OUT=fb[n];break; default:break; } } } |
5个回答
楼主看看这份资料~
可以参考一下《基于MSP430G2553的简易信号发生器》
云汉达人 又是这么多程序
内部写状态,产生波形rom表
只有小组成员才能发言,加入小组>>
650 浏览 1 评论
2099 浏览 5 评论
2403 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2161 浏览 6 评论
2146 浏览 7 评论
使用eim外接fpga可是端口一点反应都没有有没有大哥指点一下啊
289浏览 9评论
285浏览 7评论
请教大神怎样去解决iMX6Q在linux3.0.35内核上做AP失败的问题呢
419浏览 6评论
284浏览 5评论
331浏览 5评论
GMT+8, 2024-3-29 18:21 , Processed in 0.907114 second(s), Total 84, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
