file:///c:/users/administrator/appdata/roaming/360se6/User Data/temp/%E6%96%B0%E5%BB%BA%E4%BD%8D%E5%9B%BE%E5%9B%BE%E5%83%8F.bmp
1.uboot中Mx6q_tqcorec.c u-boot-imx-2014.04boardfreescaleMx6q_tqcorec static struct display_info_t const displays[] = { { .bus = -1, .addr = 0, .pixfmt = IPU_PIX_FMT_RGB24, .detect = NULL, .enable = do_enalle_lvds_clock, .mode = { .name = "LVDS10", .refresh = 60, .xres = 800, .yres = 600, .pixclock = 25000, .left_margin = 256, .right_margin = 0, .upper_margin = 0, .lower_margin = 28, .hsync_len = 1, .vsync_len = 1, .sync = FB_SYNC_EXT, .vmode = FB_VMODE_NONINTERLACED } } }; static void setup_display(void) { ......................... reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES | IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_LOW | IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW | IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG | IOMUXC_GPR2_DATA_WIDTH_CH1_24BIT | IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG | IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT | IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED | IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; writel(reg, &iomux->gpr[2]); reg = readl(&iomux->gpr[3]); reg = (reg & ~(IOMUXC_GPR3_LVDS0_MUX_CTL_MASK | IOMUXC_GPR3_HDMI_MUX_CTL_MASK)) | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 << IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); writel(reg, &iomux->gpr[3]); } 2.dts aliases { mxcfb0 = &mxcfb1; mxcfb1 = &mxcfb2; mxcfb2 = &mxcfb3; mxcfb3 = &mxcfb4; }; mxcfb1: fb@0 { compatible = "fsl,mxc_sdc_fb"; disp_dev = "ldb"; interface_pix_fmt = "RGB24"; default_bpp = <24>; int_clk = <0>; late_init = <0>; status = "disabled"; }; &ldb { status = "okay"; lvds-channel@0 { fsl,data-mapping = "spwg"; fsl,data-width = <24>; primary; status = "okay"; display-timings { native-mode = <&timing0>; timing0: hsd100pxn1 { clock-frequency = <40000000>; hactive = <800>; vactive = <600>; hback-porch = <256>; hfront-porch = <0>; vback-porch = <0>; vfront-porch = <28>; hsync-len = <1>; vsync-len = <1>; }; }; }; lvds-channel@1 { fsl,data-mapping = "spwg"; fsl,data-width = <24>; status = "okay"; display-timings { native-mode = <&timing1>; timing1: hsd100pxn1 { clock-frequency = <65000000>; hactive = <1024>; vactive = <768>; hback-porch = <220>; hfront-porch = <40>; vback-porch = <21>; vfront-porch = <7>; hsync-len = <60>; vsync-len = <10>; }; }; }; }; 3.uboot参数设置 setenv bootargs console=ttymxc0,115200 video=mxcfb0:dev=ldb,LDB-XGA,if=RGB24 ldb=sin0 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off root=/dev/nfs rw ip=192.168.1.103:192.168.1.235:192.168.1.1:255.255.255.0 fec_mac=12:32:43:34:21:43 nfsroot=192.168.1.235:/home/nfs_server/imx6q_3.14.28_rootfs,proto=tcp,nfsvers=3,nolock |
1个回答
请问还需要修改哪些?
只有小组成员才能发言,加入小组>>
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2003 浏览 6 评论
1815 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4372 浏览 1 评论
GMT+8, 2024-3-28 17:31 , Processed in 0.629042 second(s), Total 75, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
