呵呵,那什么练手好呢,看了下7920的12864,就是他了,先对比下时序
一步步来。 上面是7920的SPI时序,下面是STC的SPI时序,用的是STC12C5A60S2,STC的英文资料,难得吧,感觉E文的广告能少点。。。。 继续折腾完毕~ 下面是结果~~ //========================================代码区==========================================// //#include #include "reg51.h" //============================================================================================================ #define uint unsigned int #define uchar unsigned char //引脚定义 ***it LCD_CS =P1^4; // 片选 高电平有效 单片LCD使用时 可固定高电平 ***it LCD_SID =P1^5; // 数据 ***it LCD_CLK =P1^7; // 时钟 ***it LCD_PSB =P3^5; // 低电平时表示用串口驱动, 可固定低电平 ***it LCD_RST =P3^6; // LCD复位,LCD模块自带复位电路。 可不接 //***it LCD_BACK =P2^6; // LCD背光控制 //========================================================================= #define MASTER //define:master undefine:slave typedef unsigned char BYTE; typedef unsigned int WORD; typedef unsigned long DWORD; sfr AUXR = 0x8e; //Auxiliary register sfr SPSTAT = 0xcd; //SPI status register 84 #define SPIF 0x80 //SPSTAT.7 #define WCOL 0x40 //SPSTAT.6 sfr SPCTL = 0xce; //SPI control register 85 #define SSIG 0x80 //SPCTL.7 #define SPEN 0x40 //SPCTL.6 #define DORD 0x20 //SPCTL.5 #define MSTR 0x10 //SPCTL.4 #define CPOL 0x08 //SPCTL.3 #define CPHA 0x04 //SPCTL.2 #define SPDHH 0x00 //CPU_CLK/4 #define SPDH 0x01 //CPU_CLK/16 #define SPDL 0x02 //CPU_CLK/64 #define SPDLL 0x03 //CPU_CLK/128 sfr SPDAT = 0xcf; //SPI data register 86 ***it SPISS = P1^3; //SPI slave select, connect to slave' SS(P1.4) pin void InitSPI() { SPDAT = 0; //initial SPI data SPSTAT = SPIF | WCOL; //clear SPI status #ifdef MASTER SPCTL = SPEN | MSTR | CPHA | CPOL | SPDH; //master mode #else SPCTL = SPEN; //slave mode #endif } BYTE SPISwap(BYTE dat) { #ifdef MASTER SPISS = 1; //pull low slave SS #endif SPDAT = dat; //trigger SPI send while (!(SPSTAT & SPIF)); //wait send complete SPSTAT = SPIF | WCOL; //clear SPI status #ifdef MASTER SPISS = 0; //push high slave SS #endif return SPDAT; //return received SPI data } //========================================================================= void Delay(uint Number) { uint i,j; for (i=0; i for(j=0; j<10; j++) { ; } } } /*****************************************************/ void Send_byte(uchar Byte) { SPISwap(Byte); // 以下方式为模拟SPI // uchar i; // for (i=0; i<8; i++) // { // LCD_SID = Byte&0x80; // 取出最高位 写入串行数据 // LCD_CLK = 1; // 串行同步时钟信号 // LCD_CLK = 0; // Byte <<= 1; // 左移 // } } /*****************************************************/ void WriteCommandLCM(uchar WCLCM) { uchar Start_data,Hdata,Ldata; Start_data = 0xf8; // 写指令 11111000 Hdata = WCLCM&0xf0; // 取高四位 DDDD0000 Ldata = (WCLCM << 4) & 0xf0; // 取低四位 0000DDDD Send_byte(Start_data); // 发送起始信号 第1字节-格式:1111ABC Delay(5); // 延时是必须的 Send_byte(Hdata); // 发送高四位 第2字节-格式DDD0000 Delay(1); // 延时是必须的 Send_byte(Ldata); // 发送低四位 第3字节-格式:0000DDDD Delay(1); // 延时是必须的 } /*****************************************************/ void WriteDataLCM(uchar WDLCM) { uchar Start_data,Hdata,Ldata; Start_data = 0xfa; // 写数据 11111010 Hdata = WDLCM & 0xf0; // 取高四位 DDDD0000 Ldata = (WDLCM << 4) & 0xf0; // 取低四位 0000DDDD Send_byte(Start_data); // 发送起始信号 第1字节-格式:1111ABC Delay(5); // 延时是必须的 Send_byte(Hdata); // 发送高四位 第2字节-格式DDD0000 Delay(1); // 延时是必须的 Send_byte(Ldata); // 发送低四位 第3字节-格式:0000DDDD Delay(1); // 延时是必须的 } /*****************************************************/ void Lcdinit(void) { Delay(10); // 启动等待,等LCM讲入工作状态 LCD_PSB = 0; // 串口驱动模式 LCD_RST = 0; Delay(1); LCD_RST = 1; // 复位LCD LCD_CS = 1; // 片选 WriteCommandLCM(0x30); // 8 位介面,基本指令集 WriteCommandLCM(0x0c); // 显示打开,光标关,反白关 WriteCommandLCM(0x01); // 清屏,将DDRAM的地址计数器归零 } /*****************************************************/ void DisplayListChar(uchar x, uchar y, uchar code *s) { uchar add; // 显示地址 switch (y) // 显示地址计数 { case 0: add = x + 0x80; break; // 第一行的地址 case 1: add = x + 0x90; break; // 第二行的地址 case 2: add = x + 0x88; break; // 第三行的地址 case 3: add = x + 0x98; break; // 第四行的地址 default: break; } WriteCommandLCM(0x30); // 8位介面,基本指令集 WriteCommandLCM(add); // 写入地址 while (*s > 0) // 写入字符串 { WriteDataLCM(*s); s++; Delay(50); } } /*****************************************************/ //图形方式 //void DisplayPicture(uint code *img) //{ // uchar Line,Row; // Line为行地址;Row为列地址 // uint regist = 0; // 图形地址寄存器 // // WriteCommandLCM(0x36); // 图形方式,扩展指令 // // -------------- 上半屏 ---------------- // for (Line=0; Line<32; Line++) // { // WriteCommandLCM(0x80 + Line); // 写入行地址 // WriteCommandLCM(0x80); // 写入列 // // for (Row=0; Row<16; Row++) // { // WriteDataLCM(img[regist++]); // 写入图片数据 // } // } // // --------------- 下半屏 --------------- // regist=512; // 下半屏起始数据 // // for (Line=0; Line<32; Line++) // { // WriteCommandLCM(0x80 + Line); // 写入行地址 // WriteCommandLCM(0x88); // 写入列 // // for (Row=0; Row<16; Row++) // { // WriteDataLCM(img[regist++]); // 写入图片数据 // } // } // // WriteCommandLCM(0x30); // 基本指令 //} /*****************************************************/ void main(void) { InitSPI(); //initial SPI Delay(10); Lcdinit(); // 初始化LCD Delay(100); DisplayListChar(0,0,"人生若只是初见,"); DisplayListChar(0,1,"何事秋风悲画扇。"); DisplayListChar(0,2,"等闲变却故人心,"); DisplayListChar(0,3,"却道故人心易变。"); while(1) { } } //========================================代码区完==pp上场==================================// 实际的IO用了两个,片选直接接高! 秉承一贯闹着玩的做风~ P.S: 这句话!! SPCTL = SPEN | MSTR | CPHA | CPOL | SPDH; //master mode 注意SPI的设置!!换了别的东西还得先看看手册啊!! |
11个回答
请问为什么此时的cpol和cpha是11啊?
怎么跟我理解的不同啊?下面的网址有说明。 http://user.qzone.qq.com/415645461?ADUIN=175344851&ADSESSION=1345443254&ADTAG=CLIENT.QQ.3721_FriendInfo_PersonalInfo.0&ptlang=2052#!app=2&via=QZ.HashRefresh&pos=1344518771 |
mark
为何要模拟的SPI??单片机本身不是有吗
不错的资料 mark一下
神貌似已经两年没来论坛了?
借来用用 谢谢分享
顶一个
好啊!请问大神,弱弱的问一句,用SPI有什么好处啊(比不用SPI)?
与11楼同问
只有小组成员才能发言,加入小组>>
2970 浏览 9 评论
2687 浏览 16 评论
3212 浏览 1 评论
8426 浏览 16 评论
3770 浏览 18 评论
6950浏览 6评论
求助,请问MS51FB9AE带隙电压能作为侦测的基准电压吗?
7449浏览 3评论
6950浏览 3评论
支持UART-to-BLE透传的新唐NuTool – BLE ATCMD开发工具推荐
5798浏览 3评论
9370浏览 3评论
GMT+8, 2024-4-19 08:33 , Processed in 0.832279 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
