嗨Shawn,我只是在第二台计算机上尝试了同样的事情也发生了这个matlab错误,在那里我发现了一个不同的程序(我甚至不知道这个程序的目的)还包含许多Matlab DLL。
重命名该程序的整个程序文件夹后,我尝试了VEE7.51 Matlab示例,它也起作用.BRManfred - 以上来自于谷歌翻译 以下为原文 Hi Shawn, I just tried the same thing on a second computer were also this Matlab Error occurs and there I found a different program (I even dont know the purpose of this program) that also contained many of the Matlab DLLs. After renaming the whole program folder of this program I tried the VEE7.51 Matlab example and it also worked. BR Manfred |
6个回答
在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。
以上来自于谷歌翻译 以下为原文 Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
您好,这应该很简单,但我似乎无法在手册中看到它。
我有一台机器将一个ASCII字符(0-7)发送到一个串口,其中一些程序会记录正在发生的事情。我只需要让VEE读取串口并让我知道是否有什么东西, 如果那个东西是数字0 - > 7.请告诉我如何攻击这个。 ......如果重要的话,我正在使用6.01。 幸运的是,7.5上有一个模块,仅用于查看串口或其他东西。谢谢,Mike ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送空白电子邮件至“join-vrf” @ it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件至此邮件列表,请发送电子邮件至”vrf@agilent.com ”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hello,This should be easy, but I can’t seem to get itlooking at manuals. I have a machine that sends an ASCII char (0-7)out to a serial port where some program would keep counts of whatever is going on. I just need to get VEE to read the serial port and let me know if something isthere, and if that something is a number 0 -> 7. Please tell me how toattack this. …and if it matters, I am using 6.01 rightnow. With my luck there is a module on 7.5 that is just for looking atserial ports or something. Thanks,Mike---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
您好,我不确定您在VME平台上的VEE是什么意思。
我已经在VXI C-Size机箱中安装了一个VME卡,并使用NI LabWindows / CVI通过Slot 0控制器在寄存器级别与它进行通信。 VME卡采用安静的E1403C B尺寸至C尺寸适配器。 我不明白为什么你不能使用AEE这种类型的应用程序。 您必须使用VISA中的低级命令来查看和戳到正确的内存位置。 我使用的VME卡有一个C API。 你可以从VEE调用dll。如果你在谈论VME单板计算机而不是我不知道。 Ino更长时间可以使用它在我上一份工作中的设置,或者我会尝试VEE.Good Luck,Paul -----原始消息-----来自:Vera Fernndez,Juan [mailto:jvera @ indra。 发送时间:2005年11月17日星期四上午10:00:VRFCc:vrf@agilent.com主题:RE:[vrf] vrf:VEE& VMEVME并不一定意味着UNIX。 有一些支持WIN2K和XP的VME嵌入式处理器(例如,Toles)。 我担心的是IO,即可以与VME设备通信吗? 实际上SCIL / VISA确实支持GPIB,USB,TCP / IP,VXI,COM端口......但VME怎么样?我知道VXI实际上是一个用于仪器的VME扩展,所以我认为可能存在某种解决方案。 ---- Mensaje原创----- De:Shawn Fessenden [mailto:shawn@testech-ltd.com] Enviado el:jueves,17 denoviembre de 2005 15:21Para:VRFAsunto:RE:[vrf] vrf:VEE& ; VME> VEE能否在VME平台上运行? 它可能会在WINE下运行。 IO可能是一个挑战,但要解决这个问题应该不会太难。-SHAWN ----------------------------- -------------------------------------------------- ------------------------------------- Este correo electrnico y,en su caso,cualquier fichero anexo al mismo,contiene informacin de carcter confidencial exclusivamente dirigida a sudestinatario o destinatarios。 Queda prohibida su divulgacin,copia odistribucin a terceros sin la previa autorizacin escrita de Indra。 En elcaso de haber recibido este correo electrnico por error,se ruega notificarinmediatamente esta circunstancia mediante reenvo a la direccinelectrnica del remitente。 POR FAVOR,ANTES DE IMPRIMIR ESTE CORREOELECTRNICO考虑SU APORTACIN A LA CONSERVACIN DEL MEDIO AMBIENTE PORLA REDUCCIN DE CONSUMO DE PAPEL。本电子邮件和任何附件中的信息都是保密的,以便关注和使用指定的收件人。 。 特此声明,未经Indra事先书面同意,禁止传播,分发或复制本通讯。 如果您错误地接收了此通信,请通过回复邮件通知发件人。 请在打印电子邮件之前考虑您的环境责任.---您目前订阅了vrf:PMuckerh@systems.textron.com Tosubscribe发送空白电子邮件至“join-vrf@it.lists.it.agilent.com” 。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”.--- 您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf @ it .lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hello, I am not sure what you mean by VEE on a VME platform. I have put a VME card in a VXI C-Size Chassis and talked to it through the Slot 0 Controller at the register level using NI LabWindows/CVI. The VME Card was put on an Agilent E1403C B size to C Size Adapter. I do not see why you could not use VEE for this type of application. You would have to use the low level commands in VISA to do peeks and pokes to the correct memory locations. The VME card I used had a C API. You could call dlls from VEE. If you are talking about a VME single board computer than I don't know. I no longer have access to the set-up it is at my last job or I would try VEE. Good Luck, Paul -----Original Message----- From: Vera Fernndez, Juan [mailto:jvera@indra.es] Sent: Thursday, November 17, 2005 10:00 AM To: VRF Cc: vrf@agilent.com Subject: RE: [vrf] vrf: VEE & VME VME doesn't necessary mean UNIX. There some VME embedded processors (e.g. Thales) supporting WIN2K and XP. My concern is certainly IO, i.e. will VEE able to talk to a VME device? Actually SCIL/VISA does support GPIB, USB, TCP/IP, VXI, COM ports, ... but how about VME? I know VXI is really a VME extension for instrumentation so I thought some kind of solution might exist out there. Juan -----Mensaje original----- De: Shawn Fessenden [mailto:shawn@testech-ltd.com] Enviado el: jueves, 17 de noviembre de 2005 15:21 Para: VRF Asunto: RE: [vrf] vrf: VEE & VME > Is VEE able to run on a VME platform? It might run under WINE. IO would probably be a challenge, but it shouldn't be too difficult to get around that. -SHAWN- ---------------------------------------------------------------------------- --------------------------------------- Este correo electrnico y, en su caso, cualquier fichero anexo al mismo, contiene informacin de carcter confidencial exclusivamente dirigida a su destinatario o destinatarios. Queda prohibida su divulgacin, copia o distribucin a terceros sin la previa autorizacin escrita de Indra. En el caso de haber recibido este correo electrnico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvo a la direccin electrnica del remitente. POR FAVOR, ANTES DE IMPRIMIR ESTE CORREO ELECTRNICO CONSIDERE SU APORTACIN A LA CONSERVACIN DEL MEDIO AMBIENTE POR LA REDUCCIN DE CONSUMO DE PAPEL. The information in this e-mail and in any attachments is confidential and solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, distribution or copy of this communication is prohibited without the prior written consent of Indra. If you have received this communication in error, please, notify the sender by reply e-mail. PLEASE CONSIDER YOUR ENVIRONMENTAL RESPONSIBILITY BEFORE PRINTING THIS E-MAIL. --- You are currently subscribed to vrf as: PMuckerh@systems.textron.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
嗨Shawn,它现在有效!你100%正确。
我的计算机上安装了两个不同版本的仿真工具,其中包含许多Matlab DLL。 我刚刚重命名了这些额外的Matlab附加组件的文件夹,现在VEE7.51和Matlab示例正在工作! 非常感谢你的帮助.BRManfred -----原帖-----来自:分机Shawn Fessenden [mailto:shawn@testech-ltd.com]发送时间:2005年11月17日星期四下午4:52 VRFS主题:RE:[vrf]如果VEE6.01安装在同一台计算机上,VEE7.51中的Matlab无效>我得到一个新的ERROR messageYup,我看到了utEnterCautiousFreeMode。 似乎您可能安装了其他版本的Matlab(可能是其他产品的附加组件)。 在其他产品被淘汰之前,它可能会一遍又一遍。-SHAWN ----您目前订阅vrf为:r***@soco.agilent.com要订阅,请发送空白电子邮件至“join-vrf” @ it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件至此邮件列表,请发送电子邮件至”vrf@agilent.com ”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hi Shawn, it works now! You were 100% right. There where two different versions of a simulation tool installed on my computer that both contained many of the Matlab DLLs. I just renamed the folder of these additional Matlab adds-on and now VEE7.51 with the Matlab examples is working! Thank you very much for your help. BR Manfred -----Original Message----- From: ext Shawn Fessenden [mailto:shawn@testech-ltd.com] Sent: Thursday, November 17, 2005 4:52 PM To: VRF Subject: RE: [vrf] Matlab in VEE7.51 is not working if VEE6.01 is installed on the same computer > I get a new ERROR message Yup, I see utEnterCautiousFreeMode. Seems you might have other versions of Matlab (perhaps add-ons to other products) installed. It's probably going to be the same thing over and over until the other products are rooted out. -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 11:42 , Processed in 1.067294 second(s), Total 74, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
