大家好,这是我前一段时间提交的VEE中的一个错误的结果。
VEE7及以上版本以rtf格式存储描述,在一行上。 先前版本将描述的每一行存储在.vee文件中的单独行上,并由其自己的引号集包围。 不幸的是,如果您打开一个以7之前的格式编写的程序,然后编辑了描述,它将导致VEE崩溃,并且它还会使描述的额外行孤立。这个错误已在最新的VEE补丁中得到修复 7.5(7.52?)。 我还没有得到VEE 7.5 ...我打算写一个实用程序来修复.vee文件,但我最终只是手动编辑了那些已被损坏的文件... yes:notepad.Reiner 以上来自于谷歌翻译 以下为原文 Hello all, This is the result of a bug in VEE that I submitted a little while ago. VEE 7 and above store the descriptions in rtf format, on one line. Previous version stored each line of the description on a separate line in the .vee file, surrounded by it's own set of quotes. Unfortunately, if you opened a program written in pre-7 format, and then edited the description, it would cause VEE to crash, and it also orphaned the extra lines of the description. The bug has already been fixed in the latest patch for VEE 7.5 (7.52?). I haven't got VEE 7.5 yet though... I was going to write a utility to fix the .vee files, but I ended up just manually editing the couple of files that had been corrupted in...yes: notepad. Reiner -----Original Message----- From: Shawn Fessenden [mailto:shawn@testech-ltd.com] Sent: Wednesday, February 22, 2006 4:45 PM To: VRF Subject: RE: [vrf] Clearing Out Variable References > If I were to, for this example I would nuke the following, correct? > (description2 6..... array.") Yes - the beginning left paren to the matching unescaped right paren. The next version of VV has an Object Tree which will make this far easier. You'll be able to select a single attribute of an object (like description) or a whole object and delete it without worrying about matching parens. -SHAWN- --- You are currently subscribed to vrf as: reiner.schlieker@siemens.com To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
10个回答
在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。
以上来自于谷歌翻译 以下为原文 Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
Jon,我还在VEE6.x,但当我右键单击User Object并查看描述时,Part1会出现几次。
如果我删除它们,搜索结果为空。 狂野猜想:这本来是一个VEE6.x程序,并且VEE7以不同的方式存储信息但留下旧信息吗? - Bill OssmannPhilips Ultrasound“Griggs,Jon”写于02/22/2006 02:51:40 PM:>你好 VRF,>我正在清理我的一个测试程序中的一些未使用的变量。>为了确保清除所有引用,我使用查找工具>搜索所有引用。>对于此示例,该变量名称为part1。 >>附件你会找到一个程序。>包含的唯一项目是空白的用户功能。>请搜索part1。>找到它?>>任何人都知道如何摆脱对不存在的> part1参考的引用? >(最好不要在文本编辑器中编辑.vee文件。>该变量曾经在(右键单击)描述字段中。>但是,我删除了那里的引用。)>不应该删除描述清除它们 .vee文件?>>目前正在使用的平台是VEE 7.03。>>>谢谢,> Jon Griggs >> mailto:jgriggs@crownintl.com >>测试工程师>> Crown In ternational> 1718 West Mishawaka Road> Elkhart,IN 46517 >> ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送空白电子邮件请求“join-vrf@lists.it.agilent.com “。要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要将邮件发送到此邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Jon, I'm still at VEE6.x, but when I right click on the User Object and look at the description, there are several occurrences of Part1. If I delete them, search comes up empty. Wild conjecture: Was this originally a VEE6.x program, and does VEE7 store the information differently but leave the old stuff behind? -- Bill Ossmann Philips Ultrasound "Griggs, Jon" wrote on 02/22/2006 02:51:40 PM: > Hello VRF, > I was cleaning up some unused variables in one of my test programs. > To make sure I have all references cleared, I use the find tool to > search for all references. > For this example, that variable name is part1. > > Attached you will find a program. > The only item included is a blank User Function. > Please search for part1. > Found it? > > Anyone know how to get rid of the reference to the non-existent > part1 reference? > (Preferably without editing the .vee file in a text editor. > The variable used to be in the (right-click) description field. > However, I erased the references there.) > Shouldn't deleting descriptions clear them out of the .vee file? > > Current platform being used is VEE 7.03. > > > Thanks, > Jon Griggs > > mailto:jgriggs@crownintl.com > > Test Engineer > > Crown International > 1718 West Mishawaka Road > Elkhart, IN 46517 > > --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
如果我删除它们,搜索会显示为空。 狂野猜想:这本来是一个VEE6.x程序,并且VEE7以不同的方式存储信息但留下旧信息吗? - Bill OssmannPhilips Ultrasound“Griggs,Jon”写于02/22/2006 02:51:40 PM:>你好 VRF,>我正在清理我的一个测试程序中的一些未使用的变量。>为了确保清除所有引用,我使用查找工具>搜索所有引用。>对于此示例,该变量名称为part1。 >>附件你会找到一个程序。>包含的唯一项目是空白的用户功能。>请搜索part1。>找到它?>>任何人都知道如何摆脱对不存在的> part1参考的引用? >(最好不要在文本编辑器中编辑.vee文件。>该变量曾经在(右键单击)描述字段中。>但是,我删除了那里的引用。)>不应该删除描述清除它们 .vee文件?>>目前正在使用的平台是VEE 7.03。>>>谢谢,> Jon Griggs >> mailto:jgriggs@crownintl.com >>测试工程师>> Crown In ternational> 1718 West Mishawaka Road> Elkhart,IN 46517 >> ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送空白电子邮件请求“join-vrf@lists.it.agilent.com “。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件至此邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Jon, I'm still at VEE6.x, but when I right click on the User Object and look at the description, there are several occurrences of Part1. If I delete them, search comes up empty. Wild conjecture: Was this originally a VEE6.x program, and does VEE7 store the information differently but leave the old stuff behind? -- Bill Ossmann Philips Ultrasound "Griggs, Jon" wrote on 02/22/2006 02:51:40 PM: > Hello VRF, > I was cleaning up some unused variables in one of my test programs. > To make sure I have all references cleared, I use the find tool to > search for all references. > For this example, that variable name is part1. > > Attached you will find a program. > The only item included is a blank User Function. > Please search for part1. > Found it? > > Anyone know how to get rid of the reference to the non-existent > part1 reference? > (Preferably without editing the .vee file in a text editor. > The variable used to be in the (right-click) description field. > However, I erased the references there.) > Shouldn't deleting descriptions clear them out of the .vee file? > > Current platform being used is VEE 7.03. > > > Thanks, > Jon Griggs > > mailto:jgriggs@crownintl.com > > Test Engineer > > Crown International > 1718 West Mishawaka Road > Elkhart, IN 46517 > > --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
或者只使用Integer for the range,然后将其设置为10. Itworks correct.detlef ----- Ursprngliche Nachricht ----- Von:Gregg C Levine [mailto:hansolofalcon@worldnet.att.net] Gesendet:
Mittwoch,22。Februar 2006 15:44安:VRFBetreff:RE:[vrf] Comaprison(> =)bug?你好Gregg C Levine这让我想起了当我第一次学习如何编程时我必须要学习的东西。看起来似乎 我们认为实数的并不总是平坦的......我们习惯的9组。 正如你们刚刚发现的那样,有一个四舍五入的错误出现了。 而且这可能是为什么VEE包含的那个设置告诉我们这个数字将会是什么重要数字。 我们应该做更多的测试,并准备好向公司提供一系列有效的程序,以便他们可以在他们的机器上重现这一点,以确认他们确实知道它确实是一个错误而不是一个功能.---- Gregg C Levine hansolofalcon @ worldnet .att.net ---“记住,力量会和你在一起。永远。” Obi-Wan Kenobi> -----原帖----->来自:Vinod [mailto:papineni_vinod@yahoo.com]>发送时间:2006年2月22日星期三上午8:41>收件人:VRF>主题: Re:[vrf] Comaprison(> =)bug?>> Warren,>>我认为这是另一个浮点现象。 只需探测For Range循环对象中last>值的行; 你会注意到它不是6但是5.999 ... >> -Vinod >> ---“Pickles,Warren”写道:>>>大家好,> >>>请看一下附加的程序。 我认为这是一个错误inVEE >>但我只是想检查一下我没有错过一些愚蠢的东西,然后我>将它提交给缺陷报告。 >>较低的记录字母数字中的最后一个值不应该为零吗? 这是一个VEE 6.2编程但是在VEE 7.01中>相同> >>>我的解决方法是将For Range的输出强制转换为Real32 soI'm >>猜测它是某种舍入错误(或“特征”)。 > >>>干杯,>> Warren> ---您目前订阅了vrf:Detlef.Baranski@pilkington.de订阅时,请发送空白电子邮件请求“join-vrf@lists.it.agilent.com”。 取消订阅会发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”.--- 您目前订阅vrf为:r***@soco.agilent.com要订阅,请向“join-vrf@lists.it.agilent.com”发送空白电子邮件请求。要取消订阅,请发送空白电子邮件至“leave-vrf @ it。 lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Or just use Integer allways for the for range and then devide it by 10. It works correctly. detlef -----Ursprngliche Nachricht----- Von: Gregg C Levine [mailto:hansolofalcon@worldnet.att.net] Gesendet: Mittwoch, 22. Februar 2006 15:44 An: VRF Betreff: RE: [vrf] Comaprison (>=) bug? Hello from Gregg C Levine This reminds me of something I had to learn the hard way when I was first learning how to program. It seems that what we consider real numbers aren't always the flat 1....9 groups that we are used to. As all of you have just discovered there is a rounding off error that surfaces. And that presumably is why VEE includes that setting that tells us to what significant figures the number will be rounded off. We should do more testing, and be ready to provide to the company a valid series of programs, so that they can reproduce this on their machines to confirm for themselves that its indeed a bug and not a feature. ---- Gregg C Levine hansolofalcon@worldnet.att.net --- "Remember the Force will be with you. Always." Obi-Wan Kenobi > -----Original Message----- > From: Vinod [mailto:papineni_vinod@yahoo.com] > Sent: Wednesday, February 22, 2006 8:41 AM > To: VRF > Subject: Re: [vrf] Comaprison (>=) bug? > > Warren, > > I think this another of the floating-point phenomena. Just probe the line for the last > value from the For Range loop object; you will notice that it is not 6 but 5.999... > > -Vinod > > --- "Pickles, Warren" wrote: > > > Hi all, > > > > Please take a look at the attached program. I think it's a bug in VEE > > but I just want to check I'm not missing something stupid before I > > submit it to the defect report thingy. Shouldn't the last value in the > > lower Logging Alphanumeric be a zero? This is a VEE 6.2 prog but it's > > the same in VEE 7.01 > > > > My workaround is to cast the output of the For Range as Real32 so I'm > > guessing it's some kind of rounding error (or "feature"). > > > > Cheers, > > Warren > --- You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
Mittwoch,22。Februar 2006 15:44安:VRFBetreff:RE:[vrf] Comaprison(> =)bug?你好Gregg C Levine这让我想起了当我第一次学习如何编程时我必须要学习的东西。看起来似乎 我们认为实数的并不总是平坦的......我们习惯的9组。 正如你们刚刚发现的那样,有一个四舍五入的错误出现了。 而且这可能是为什么VEE包含的那个设置告诉我们这个数字将会是什么重要数字。 我们应该做更多的测试,并准备好向公司提供一系列有效的程序,以便他们可以在他们的机器上重现这一点,以确认他们确实知道它确实是一个错误而不是一个功能.---- Gregg C Levine hansolofalcon @ worldnet .att.net ---“记住,力量会和你在一起。永远。” Obi-Wan Kenobi> -----原帖----->来自:Vinod [mailto:papineni_vinod@yahoo.com]>发送时间:2006年2月22日星期三上午8:41>收件人:VRF>主题: Re:[vrf] Comaprison(> =)bug?>> Warren,>>我认为这是另一个浮点现象。 只需探测For Range循环对象中last>值的行; 你会注意到它不是6但是5.999 ... >> -Vinod >> ---“Pickles,Warren”写道:>>>大家好,> >>>请看一下附加的程序。 我认为这是一个错误inVEE >>但我只是想检查一下我没有错过一些愚蠢的东西,然后我>将它提交给缺陷报告。 >>较低的记录字母数字中的最后一个值不应该为零吗? 这是一个VEE 6.2编程但是在VEE 7.01中>相同> >>>我的解决方法是将For Range的输出强制转换为Real32 soI'm >>猜测它是某种舍入错误(或“特征”)。 > >>>干杯,>> Warren> ---您目前订阅了vrf:Detlef.Baranski@pilkington.de订阅时发送空白电子邮件请求“join-vrf@lists.it.agilent.com”.To 取消订阅会发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”.--- 您目前订阅vrf为:r***@soco.agilent.com要订阅,请向“join-vrf@lists.it.agilent.com”发送空白电子邮件请求。要取消订阅,请发送空白电子邮件至“leave-vrf @ it。 lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Or just use Integer allways for the for range and then devide it by 10. It works correctly. detlef -----Ursprngliche Nachricht----- Von: Gregg C Levine [mailto:hansolofalcon@worldnet.att.net] Gesendet: Mittwoch, 22. Februar 2006 15:44 An: VRF Betreff: RE: [vrf] Comaprison (>=) bug? Hello from Gregg C Levine This reminds me of something I had to learn the hard way when I was first learning how to program. It seems that what we consider real numbers aren't always the flat 1....9 groups that we are used to. As all of you have just discovered there is a rounding off error that surfaces. And that presumably is why VEE includes that setting that tells us to what significant figures the number will be rounded off. We should do more testing, and be ready to provide to the company a valid series of programs, so that they can reproduce this on their machines to confirm for themselves that its indeed a bug and not a feature. ---- Gregg C Levine hansolofalcon@worldnet.att.net --- "Remember the Force will be with you. Always." Obi-Wan Kenobi > -----Original Message----- > From: Vinod [mailto:papineni_vinod@yahoo.com] > Sent: Wednesday, February 22, 2006 8:41 AM > To: VRF > Subject: Re: [vrf] Comaprison (>=) bug? > > Warren, > > I think this another of the floating-point phenomena. Just probe the line for the last > value from the For Range loop object; you will notice that it is not 6 but 5.999... > > -Vinod > > --- "Pickles, Warren" wrote: > > > Hi all, > > > > Please take a look at the attached program. I think it's a bug in VEE > > but I just want to check I'm not missing something stupid before I > > submit it to the defect report thingy. Shouldn't the last value in the > > lower Logging Alphanumeric be a zero? This is a VEE 6.2 prog but it's > > the same in VEE 7.01 > > > > My workaround is to cast the output of the For Range as Real32 so I'm > > guessing it's some kind of rounding error (or "feature"). > > > > Cheers, > > Warren > --- You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
350浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 23:01 , Processed in 1.113113 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
