大家好!
我使用Agilent 34970A长时间使用34901A多路复用器和使用经典的Benchlink软件记录TC温度数据。 现在我需要迈出新的一步。 我想买一台34903A执行器并用它来控制一个实验:我会试着简单地描述它。 我正在记录10个不同的TC温度(来自34901A)。 当其中一个温度达到一定值时,系统必须自动关闭执行器上的某个通道(以便制冷系统启动......)。 当温度回到选定值以下时,执行器上的通道必须再次自动打开。 我认为标准的Benchlink软件通过命令“工具>开关控制”或使用警报为我做了这个简单的操作,但有人告诉我学习使用Command专家可能很有用。 是否有可能使用这两个软件之一编写我在此描述的简单操作?编辑:Frenky77于2012年4月16日下午12:43我在Benchlink软件上找到了关于“开关控制”工具的以下句子:“ 您可以将开关配置为打开或关闭以响应警报。“开关控制”对话框显示这些基于警报的操作。“ 在“警报属性”部分中,还有其他有关在34903A模块上打开或关闭通道的有用信息。 以上来自于谷歌翻译 以下为原文 Hello everyone! I'm using an Agilent 34970A for a long time to log TC temperatures data with a 34901A multiplexer and using the classic Benchlink software. Now I need to do a new step. I'd like to buy a 34903A Actuator and use it to control an experiment: I'll try to simply describe it. I'm logging 10 different TC temperature (from the 34901A). When one of these temperature reaches a certain value the system must automatically close a certain channel on the actuator (so that a refrigeration system starts...). When the temperature goes back below the choosen value the channel on the actuator must be automatically opened again. I thought that the standard Benchlink software make this simple operation for me with the command "Tools>Switch control" or using the alARMs but someone told me it could be useful to learn to use the Command expert. Is it possibile to program the simple operation I described here with one of the two softwares? Edited by: Frenky77 on Apr 16, 2012 12:43 PM I found on the Benchlink software help the following sentence about the "Switch control" tool: "You can configure a switch to open or to close in response to an alarm. The Switch Control dialog box shows these alarm-based operations." In the Alarm properties section there are other useful info about opening or closing channels on a 34903A module. |
5个回答
Benchlink Data Logger软件就是这样做的方法。
IO Libraries Command Expert仅允许您手动发送单个SCPI命令以打开和关闭34903A继电器。 以上来自于谷歌翻译 以下为原文 The Benchlink Data Logger software is the way to do this. The IO Libraries Command Expert only lets you manually send individual SCPI commands to open and close the 34903A relays. |
我终于尝试使用Datalogger Benchlink,但我遇到了问题。
我试着解释我的问题。 我试图在温度通道上使用Hi Alarm。 当温度高于警报时,开关会自动打开,但当温度回到警报以下时,我无法自动关闭。 我还尝试了高/低报警。 当温度处于报警范围内时,开关自动打开,但是当温度超出范围时,我无法配置它自动再次关闭。 是否可以配置此功能?编辑:Frenky77于2012年4月27日下午12:02 以上来自于谷歌翻译 以下为原文 I finally tried to use Datalogger Benchlink but I have a problem. I try to explain my problem. I tried to use a Hi Alarm on a temperature channel. When the temperature is higher than the alarm the switch automatically opens but I can't make it automatically close when the temperture goes back below the alarm. I tried also the Hi/Low Alarm. The switch automatically opens when the temperature is in the alarm range but I can't configure that it closes again automatically when the temperature is out of the range. Is it possible to configure this function? Edited by: Frenky77 on Apr 27, 2012 12:02 PM |
为了解决这个问题,我想使用计算通道,但我在此值上设置的警报(“警报5”?)似乎没有打开或关闭开关...... 以上来自于谷歌翻译 以下为原文 To try to solve the problem I would like to use computed channels but the alarm I set on this value ("Alarm 5"?) didn't seem to open or close the switch... |
您好...我从您试图在临时打开频道的问题中理解了什么。 当温度低于该限制时,超过限制并关闭相同的通道。 为此,您必须使用计算通道,您需要将两个警报条件设置为原始通道上的Hi和计算通道上的Lo。 但是我们的软件中存在一个错误,即硬件警报在计算通道上不起作用,但好消息是其已经修复的新版本将在4-6周内提供。 所以请耐心等待,直到发布。 谢谢,拉克什米塔尔 以上来自于谷歌翻译 以下为原文 Hello... What i understood from the problem that you are trying to open the channel when temp. rise above a limit and close the same channel when temp is below that limit. For this you have to use the computed channel where you need to put two alarm condition one is Hi on original channel and Lo on computed channel. But there is a bug in our software that hardware alarm does not work on computed channel but good news is that its already fixed and new release will be available within 4-6 weeks from now. So please bear with us till the release will happen. Thanks, Rakesh Mittal |
非常感谢Rakesh。
我正在等待新版本! 以上来自于谷歌翻译 以下为原文 Thank you very much Rakesh. I'm waiting for the new release! |
只有小组成员才能发言,加入小组>>
2099 浏览 1 评论
1855 浏览 1 评论
1714 浏览 5 评论
2581 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1561 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 19:18 , Processed in 0.930751 second(s), Total 49, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
