发 帖
原厂入驻New
申请华秋企业认证 多层板首单免费打样!
30s提交资料,10分钟通过审核(免费赔付+顺丰包邮)>>立即报名
[问答] dsp编译报错,储存长度不够吗,如何解决呢?请指教!
516 DSP
分享
报错如图所示
我做的修改,但是错误没有消除
HRCap1      : origin = 0x006AC0, length = 0x000020
HRCap2      : origin = 0x006AE0, length = 0x000020
HRCap1RegsFile    : > HRCap1,   PAGE = 1
HRCap2RegsFile    : > HRCap2,   PAGE = 1
编译报错如图
编译报错如图
2019-8-29 21:48:55   评论 分享淘帖 邀请回答
1个回答
DEV_EMU     : origin = 0x000880, length = 0x000180     /* device emulation registers */
   FLASH_REGS  : origin = 0x000A80, length = 0x000060     /* FLASH registers */
   CSM         : origin = 0x000AE0, length = 0x000010     /* code security module registers */
   ADC_MIRROR  : origin = 0x000B00, length = 0x000010     /* ADC Results register mirror */
   XINTF       : origin = 0x000B20, length = 0x000020     /* external interface registers */
   CPU_TIMER0  : origin = 0x000C00, length = 0x000008     /* CPU Timer0 registers */
   CPU_TIMER1  : origin = 0x000C08, length = 0x000008     /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
   CPU_TIMER2  : origin = 0x000C10, length = 0x000008     /* CPU Timer0 registers (CPU Timer1 & Timer2 reserved TI use)*/
   PIE_CTRL    : origin = 0x000CE0, length = 0x000020     /* PIE control registers */
   PIE_VECT    : origin = 0x000D00, length = 0x000100     /* PIE Vector Table */
   DMA         : origin = 0x001000, length = 0x000200     /* DMA Rev 0 registers */
   MCBSPA      : origin = 0x005000, length = 0x000040     /* McBSP-A registers */
   MCBSPB      : origin = 0x005040, length = 0x000040     /* McBSP-B registers */
   ECANA       : origin = 0x006000, length = 0x000040     /* eCAN-A control and status registers */
   ECANA_LAM   : origin = 0x006040, length = 0x000040     /* eCAN-A local acceptance masks */
   ECANA_MOTS  : origin = 0x006080, length = 0x000040     /* eCAN-A message object time stamps */
   ECANA_MOTO  : origin = 0x0060C0, length = 0x000040     /* eCAN-A object time-out registers */
   ECANA_MBOX  : origin = 0x006100, length = 0x000100     /* eCAN-A mailboxes */
   ECANB       : origin = 0x006200, length = 0x000040     /* eCAN-B control and status registers */
   ECANB_LAM   : origin = 0x006240, length = 0x000040     /* eCAN-B local acceptance masks */
   ECANB_MOTS  : origin = 0x006280, length = 0x000040     /* eCAN-B message object time stamps */
   ECANB_MOTO  : origin = 0x0062C0, length = 0x000040     /* eCAN-B object time-out registers */
   ECANB_MBOX  : origin = 0x006300, length = 0x000100     /* eCAN-B mailboxes */
   EPWM1       : origin = 0x006800, length = 0x000022     /* Enhanced PWM 1 registers */
   EPWM2       : origin = 0x006840, length = 0x000022     /* Enhanced PWM 2 registers */
   EPWM3       : origin = 0x006880, length = 0x000022     /* Enhanced PWM 3 registers */
   EPWM4       : origin = 0x0068C0, length = 0x000022     /* Enhanced PWM 4 registers */
   EPWM5       : origin = 0x006900, length = 0x000022     /* Enhanced PWM 5 registers */
   EPWM6       : origin = 0x006940, length = 0x000022     /* Enhanced PWM 6 registers */
   ECAP1       : origin = 0x006A00, length = 0x000020     /* Enhanced Capture 1 registers */
   ECAP2       : origin = 0x006A20, length = 0x000020     /* Enhanced Capture 2 registers */
   ECAP3       : origin = 0x006A40, length = 0x000020     /* Enhanced Capture 3 registers */
   ECAP4       : origin = 0x006A60, length = 0x000020     /* Enhanced Capture 4 registers */
   ECAP5       : origin = 0x006A80, length = 0x000020     /* Enhanced Capture 5 registers */
   ECAP6       : origin = 0x006AA0, length = 0x000020     /* Enhanced Capture 6 registers */
   EQEP1       : origin = 0x006B00, length = 0x000040     /* Enhanced QEP 1 registers */
   EQEP2       : origin = 0x006B40, length = 0x000040     /* Enhanced QEP 2 registers */
   GPIOCTRL    : origin = 0x006F80, length = 0x000040     /* GPIO control registers */
   GPIODAT     : origin = 0x006FC0, length = 0x000020     /* GPIO data registers */
   GPIOINT     : origin = 0x006FE0, length = 0x000020     /* GPIO interrupt/LPM registers */
   SYSTEM      : origin = 0x007010, length = 0x000020     /* System control registers */
   SPIA        : origin = 0x007040, length = 0x000010     /* SPI-A registers */
   SCIA        : origin = 0x007050, length = 0x000010     /* SCI-A registers */
   XINTRUPT    : origin = 0x007070, length = 0x000010     /* external interrupt registers */
   ADC         : origin = 0x007100, length = 0x000020     /* ADC registers */
   SCIB        : origin = 0x007750, length = 0x000010     /* SCI-B registers */
   SCIC        : origin = 0x007770, length = 0x000010     /* SCI-C registers */
   I2CA        : origin = 0x007900, length = 0x000040     /* I2C-A registers */
   CSM_PWL     : origin = 0x33FFF8, length = 0x000008     /* Part of FLASHA.  CSM password locations. */
2019-9-2 09:27:57 评论
举报
撰写答案
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
高级模式
您需要登录后才可以回帖 登录 | 注册
我要提问
关闭
站长推荐 上一条 /10 下一条
快速回复 返回顶部 返回列表
