附上代码,已经仿真验证,可以实现,请问还有其它更简单的方法吗?
-------------------------------------------------------- -- use Division IP core achieve /5 -------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity Division_ip is port ( Clk_i : in std_logic; Rst_i : in std_logic; DivisionA_i : in std_logic_vector(17 downto 0); DivisionC_o : out std_logic_vector(17 downto 0) ); end Division_ip; architecture arch_Division_ip of Division_ip is component M_Division port ( clock : IN STD_LOGIC ; dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ; datab : IN STD_LOGIC_VECTOR (31 DOWNTO 0) ; result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0) ); end component; constant DivisionB_c : std_logic_vector(31 downto 0) := b"0100_0000_1010_0000_0000_0000_0000_0000"; signal zero : std_logic_vector(31 downto 0) := b"0000_0000_0000_0000_0000_0000_0000_0000"; shared variable i : integer range 0 to 17; signal j : integer range 0 to 256; signal Dataa_s : std_logic_vector(31 downto 0); signal DivisionA_s : bit_vector(17 downto 0); signal DivisionD_s : bit_vector(31 downto 0); signal DivisionC_s : std_logic_vector(23 downto 0); signal result_s : std_logic_vector(31 downto 0); begin DivisionA_s <= to_bitvector(DivisionA_i); process (Rst_i, Clk_i) begin if (Rst_i = '0') then i := 17; Dataa_s <= (others => '0'); elsif rising_edge (Clk_i) then if (DivisionA_i(i) = '1') then Dataa_s(22 downto 5 ) <=to_stdlogicvector( DivisionA_s SLL (18-i)); Dataa_s(30 downto 23) <= conv_std_logic_vector(i+127,8); else i := i - 1; end if; end if; end process; process (Rst_i, Clk_i) begin if (Rst_i = '0') then DivisionC_s <= (others => '0'); elsif rising_edge (Clk_i) then DivisionC_s <= to_stdlogicvector( ('1' & DivisionD_s(22 downto 0)) SRL (150 - j)); end if; end process; j <= conv_integer(result_s(30 downto 23)); DivisionD_s <= to_bitvector(result_s); U_M_Division_0 : M_Division port map ( clock => Clk_i , dataa => Dataa_s , datab => DivisionB_c , result => result_s ); DivisionC_o <= DivisionC_s(17 downto 0); end arch_Division_ip; |
相关推荐 |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
815 浏览 0 评论
364 浏览 0 评论
1080 浏览 0 评论
374 浏览 0 评论
FPGA零基础学习系列精选:半导体存储器和可编程逻辑器件简介
1010 浏览 0 评论
1421 浏览 35 评论
GMT+8, 2024-4-23 20:56 , Processed in 0.592579 second(s), Total 53, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
