DM8127启动错误,估计应该是IPCM3OUT的Link出了问题,但是又找不到出错的地方。
不知道有人遇到类似的情况没有,有可能会是哪里出错了呢? [host] 36: SYSTEM: ListElem Shared Addr = 0x405cfa80 [host] 36: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... [host] 38: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... [host] 40: SYSTEM: ListElem Shared Addr = 0x405ef480 [host] 41: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... [host] 43: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... [host] 44: SYSTEM: ListElem Shared Addr = 0x4060ee80 [host] 45: SYSTEM: System Common Init Done !!! [host] Vsys_allocBuf - addr = 0x4cedd000,size = 65011712 [host] MCFW_IPCBITS:App_streamSysInit:virt addr of 85000000 cir buffer is 4cedd000 ##########pInfo->totalsize 63897600 [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4 [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 10 Creat queue id:131076 queue id:131076 queue id:65538 [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:Entered... [host] Enable RAW Frame Write [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT [host] Opened file [VID_CH00.yuv] for writing CH0 [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered... [host] frist test [host] YUV_FRAMES_TO_A8 edit by changquan [host] ********** FULL FEATURE USECASE ******** [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @ 5fps ******** [host] 127: MCFW : CPU Revision [ES2.1] !!! [host] 127: MCFW : Detected [UNKNOWN] Board !!! [host] 127: MCFW : Base Board Revision [REV A] !!! [m3vpss ] VPS_DCTRL_INST_0 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2 [m3vpss ] 9525: CAMERA: Create in progress !!! [m3vpss ] 9525: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!! [m3vpss ] 9535: CAMERA: VIP 0: VID DEC 268436736 (0x36): bebebebe:bebebebe:8ebd60d8, AUD_STATUS -1 094795586 [m3vpss ] Stream ID 0: chId = 0 VpsUtils_queCreate. [m3vpss ] 9758: CAMERA: Create Done !!! [host] GlbceSupportLink_tskMain:Entered [m3vpss ] 9867: CAMERA: Detect video in progress !!! [m3vpss ] 9867: CAMERA: Detect video Done !!! [m3vpss ] ROI dimensions of 1920 x 1088 are optimal for performance. Optimal dimension is 1920 x 10 88 with processsing block= 32 x 16. Num horz table= 19, vert table= 11, localBlockWidth= 96. [m3vpss ] 10721: ISP : FVID2 Create Done !!! [m3vpss ] 10721: ISP : Create Done !!! [m3vpss ] Entered ISS ISP Process task [m3vpss ] 10811: NSF: Create in progress !!! [m3vpss ] NSF::HEAPID:0 USED:128 [m3vpss ] NSF::HEAPID:1 USED:4928 [m3vpss ] 10935: NSF: Create Done !!! [m3vpss ] 10942: DUP : Create Done !!! [m3vpss ] 10948: DUP : Create Done !!! [m3vpss ] DCC server task running [m3vpss ] 10950: NULL : Create Done !!! [m3vpss ] 10952: MERGE : Create Done !!! [m3vpss ] 10953: IPC_FRAMES_OUT : Create in progress !!! [m3vpss ] 10955: Assertion @ Line: 82 in links_common/system/system_linkApi.c: procId < SYSTEM_PRO C_MAX : failed !!! ApproDrvInit: 3 queue id:131076 queue id:0 queue id:32769 queue id:0 ApproDrvInit: 7 queue id:131076 TimeOut occure in boot_proc. Program exit. TimeOut occure in boot_proc. Program exit. ApproDrvExit: 7 Error: WaitStreamReady Fail. Error: SemWait: Invalid Semaphore handler |
5 个讨论
uryyywerw 发表于 2019-8-23 10:42 添加打印语句,结果打印出来procId=15;而实际上,实际上merge后面的模块为SWOSD LInk,但是从打印信息来看IPC_FRAMES_OUT这个先建立了,这个Link在M3video核里面,procId,应该为1,可是却变成了15...,我再去仔细检查程序,看chain是否编写错误。 [m3vpss ] 12196: IPC_FRAMES_OUT : Create in progress !!! [m3vpss ] In system_linkApi.c procId=15 [m3vpss ] 12198: Assertion @ Line: 82 in links_common/system/system_linkApi.c: procId < SYSTEM_PRO C_MAX : failed !!! |
改名字真烦 发表于 2019-8-23 10:48 此问题解决,谢谢edson的提示;确实是procId出错了,根本原因是因为一些不太好的编程习惯。 问题出在ipcFramesOutVpssToHost这个Link的参数:ipcFramesOutVpssToHostPrm.baseCreateParams.inQueParams.prevLinkId没有被正确赋值。 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3641 浏览 4 评论
5027 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1732 浏览 1 评论
9353 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
1186浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1189浏览 1评论
GMT+8, 2024-4-19 08:33 , Processed in 0.694517 second(s), Total 70, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
