板子用的天漠的SBC8100,OMAP3530的芯片,256M DDR SDRAM
256M NAND FLASH DVSDK是从ti网上下载的,编译codec engine 中的 video_copy例程,在主机上可以正确编译,将相关组件放到开发板上运行出错,不知道错在哪里? 运行情况如下: [root@OMAP3EVM 1]# ./loadmodules.sh CMEMK module: built on Sep 22 2009 at 10:44:38 Reference Linux version 2.6.29 File /db/rtree/install/trees/products/davincisw-h44x/imports/dvsdk_COMMON/dvsdk_3_00_02_44/linuxutils_2_24_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c ioremap_nocache(0x90000000, 50331648)=0xd3000000 allocated heap buffer 0xd3000000 of size 0x2cac000 cmem initialized 3 pools between 0x90000000 and 0x93000000 DSPLINK Module (1.61.03) created on Date: Apr 16 2009 Time: 18:31:36 mknod: /dev/dsplink: File exists [root@OMAP3EVM 1]# ls -a . app_local.xv5T in.dat sdmak.ko .. app_remote.xv5T loadmodules.sh unloadmodules.sh all.x64P cmemk.ko lpm_omap3530.ko app_local.x64P dsplinkk.ko out.dat [root@OMAP3EVM 1]# ./app_local.x64P ./app_local.x64P: line 8: syntax error: word unexpected (expecting ")") [root@OMAP3EVM 1]# ./app_local.xv5T @0x000971ae:[T:0x4001cfb0] ti.sdo.ce.examples.apps.video_copy.siUnhandled fault: external abort on non-linefetch (0x1818) at 0x40022000 nglecpu - main> ti.sdo.ce.examples.apps.video_copy.singlecpu @0x000973d4:[T:0x4001cfb0] ti.sdo.ce.examples.apps.video_copy.singlecpu - App-> Application started. Bus error [root@OMAP3EVM 1]# ./app_remote.xv5T @0x000b222c:[T:0x4001cfb0] ti.sdo.ce.examples.apps.video_copy.singlecpu - main> ti.sdo.ce.examples.apps.video_copy.singlecpu @0x000b26d2:[T:0x4001cfb0] ti.sdo.ce.examples.apps.video_copy.singlecpu - App-> Application started. Unhandled fault: external abort on non-linefetch (0x1818) at 0x4001f000 之前loadmodules.sh不能正确加载,手动修改了cmemk的地址,难道loadmodules.sh还是没有设置对? 还是别的哪方面的问题? 刚接触不久,小白一个,希望各位多多帮助! |
13 个讨论
Texas Instruments X-Loader 1.41 Starting OS Bootloader... U-Boot 1.3.3-svn (May 5 2010 - 13:10:34) OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz SBC8100 Board + LPDDR/NAND DRAM: 256 MB NAND: 256 MiB Using default environment Display-bmp: 480 x 272 with 256 colors In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x280000, size 0x300000 3145728 bytes read: OK ## Booting kernel from Legacy Image at 80300000 ... Image Name: Linux-2.6.29-rc3-omap1 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2212312 Bytes = 2.1 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux............................................................................................................................................... done, booting. Linux version 2.6.29-rc3-omap1 (luofc@TIOP) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #1 Fri Jul 9 16:06:20 CST 2010 CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c5387f CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache Machine: OMAP3 SBC8100 Ignoring unrecognised tag 0x54410008 Memory policy: ECC disabled, Data cache writeback OMAP3530 ES3.1 (full speed SGX, IVA2) SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024 Kernel command line: console=ttyS2,115200n8 ubi.mtd=4 root=ubi0:rootfs rootfstype=ubifs video=omapfb:mode:4.3inch_LCD Clocking rate (Crystal/DPLL/MPU core): 26.0/266/500 MHz IVA2 clocking rate: 360 MHz Reprogramming SDRC dpll3_m2_clk rate change failed: -22 GPMC revision 5.0 IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts Total of 96 interrupts on 1 active controller OMAP34xx GPIO hardware version 2.5 PID hash table entries: 1024 (order: 10, 4096 bytes) OMAP clockevent source: GPTIMER1 at 32768 Hz Console: colour dummy device 80x30 Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 128MB 128MB = 256MB total Memory: 254976KB available (4072K code, 371K data, 164K init) Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 520 bytes NET: Registered protocol family 16 omap3evmdc: Driver registration complete OMAP DMA hardware revision 4.0 USB: No board-specific platform config found OMAP DSS rev 2.0 OMAP DISPC rev 3.0 OMAP VENC rev 2 OMAP DSI rev 1.0 bio: create slab i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz twl4030: PIH (irq 7) chaining IRQs 368..375 twl4030: power (irq 373) chaining IRQs 376..383 twl4030: gpio (irq 368) chaining IRQs 384..401 i2c_omap i2c_omap.2: bus 2 rev3.12 at 400 kHz i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz SCSI subsystem initialized twl4030_u*** twl4030_u***: Initialized TWL4030 USB module u***core: registered new interface driver u***fs u***core: registered new interface driver hub u***core: registered new device driver u*** mu***_hdrc: version 6.0, mu***-dma, peripheral, debug=0 mu***_hdrc: USB Peripheral mode controller at d80ab000 using DMA, IRQ 92 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 8192 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 8192) TCP reno registered NET: Registered protocol family 1 OMAP35x Linux PSP version 02.01.03.11 (OMAP3EVM) NetWinder Floating Point Emulator V0.97 (double precision) VFS: Disk quotas dquot_6.5.2 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. msgmni has been set to 498 alg: No test for stdrng (krng) io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered Generic Backlight Driver Initialized. Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654 serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654 serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654 console [ttyS2] enabled brd: module loaded loop: module loaded dm9000 Ethernet Driver, V1.31 eth0 (dm9000): not using net_device_ops yet eth0: dm9000a at d08b2000,d08b6400 IRQ 185 MAC: 00:11:22:33:44:55 (chip) Linux video capture interface: v2.00 tvp514x 2-005d: Registered to v4l2 master omap34xxcam!! u***core: registered new interface driver uvcvideo USB Video Class driver (v0.1.0) i2c /dev entries driver Driver 'sd' needs updating - please use bus_type methods omap2-nand driver initializing NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit) Creating 5 MTD partitions on "omap2-nand.0": 0x000000000000-0x000000080000 : "X-Loader" 0x000000080000-0x000000260000 : "U-Boot" 0x000000260000-0x000000280000 : "U-Boot Env" 0x000000280000-0x000000680000 : "Kernel" 0x000000680000-0x000010000000 : "File System" UBI: attaching mtd4 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd4 to ubi0 UBI: MTD device name: "File System" UBI: MTD device size: 249 MiB UBI: number of good PEBs: 1996 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 1996 UBI: number of PEBs reserved for bad PEB handling: 19 UBI: max/mean erase counter: 2/1 u***mon: debugfs is not available ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver ehci-omap ehci-omap.0: OMAP-EHCI Host Controller UBI: background thread "ubi_bgt0d" started, PID 407 ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1 ehci-omap ehci-omap.0: irq 77, io mem 0x48064800 ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00 u*** u***1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 3 ports detected Initializing USB Mass Storage driver... u***core: registered new interface driver u***-storage USB Mass Storage support registered. g_ether gadget: using random self ethernet address g_ether gadget: using random host ethernet address u***0: MAC f2:c2:9b:db:f0:48 u***0: HOST MAC ba:a2:7a:a9:2a:8c g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 g_ether gadget: g_ether ready input: omap_twl4030keypad as /class/input/input0 ads7846 spi2.0: touchscreen, irq 187 input: ADS784x Touchscreen as /class/input/input1 twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0 twl4030_rtc twl4030_rtc: Power up reset detected. twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC. OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec cpuidle: using governor ladder cpuidle: using governor menu register sdio_ti_driver is OK! Registered led device: led0 Registered led device: led1 u*** 1-1: new high speed USB device using ehci-omap and address 2 Registered led device: led2 mmc1: new SDIO card at address 0001 Registered led device: led3 ti_sdio_probe: Add glue driver u***core: registered new interface driver u***hid u***hid: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.19. No device for DAI twl4030 No device for DAI twl4030 Voice No device for DAI omap-mcbsp-dai-0 No device for DAI omap-mcbsp-dai-1 No device for DAI omap-mcbsp-dai-2 No device for DAI omap-mcbsp-dai-3 No device for DAI omap-mcbsp-dai-4 TWL4030 Audio Codec init asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok u*** 1-1: config 1 has an invalid descriptor of length 0, skipping remainder of the config u*** 1-1: config 1 interface 0 altsetting 1 has 0 endpoint descriptors, different from the interface descriptor's value: 1 ALSA device list: #0: omap3evm (twl4030) TCP cubic registered NET: Registered protocol family 17 NET: Registered protocol family 15 RPC: Registered udp transport module. RPC: Registered tcp transport module. Power Management for TI OMAP3. u*** 1-1: configuration #1 chosen from 1 choice hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected SmartReflex driver initialized VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1 omapfb: using mode 4.3inch_LCD Console: switching to colour frame buffer device 60x34 GPIO-153 autorequested omap-dss DISPC error: Requested pixel clock not possible with the current OMAP2_DSS_MIN_FCK_PER_PCK setting. Turning the constraint off. tvp514x 2-005d: tvp5146m2 found at 0xba (OMAP I2C adapter) hub 1-1:1.0: activate --> -2 omap34xxcam omap34xxcam: video0 is now omap3/tvp514x// Display already enabled Display already enabled Buffer Size = 3686400 omap_vout: registered and initialized video device 1 [v4l2] Buffer Size = 3686400 omap_vout: registered and initialized video device 2 [v4l2] display->updated twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) UBIFS: recovery needed UBIFS: recovery completed UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: file system size: 103348224 bytes (100926 KiB, 98 MiB, 801 LEBs) UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) UBIFS: media format: 4 (latest is 4) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) VFS: Mounted root (ubifs filesystem) on device 252:1. Freeing init memory: 164K init started: BusyBox v1.9.1 (2008-10-17 18:20:44 IST) starting pid 482, tty '': '/etc/init.d/rcS' System initialization... Hostname : OMAP3EVM Filesystem : v1.0.2 Kernel release : Linux 2.6.29-rc3-omap1 Kernel version : #1 Fri Jul 9 16:06:20 CST 2010 Mounting /proc : [SUCCESS] Mounting /sys : [SUCCESS] Mounting /dev : [SUCCESS] Mounting /dev/pts : [SUCCESS] Enabling hot-plug : [SUCCESS] Populating /dev : [SUCCESS] Mounting other filesystems : [SUCCESS] Starting syslogd : [SUCCESS] Starting telnetd : Jan 1 00:00:01 OMAP3EVM syslog.info syslogd started: BusyBox v1.9.1 [SUCCESS] eth0: link down System initialization complete. start aging test... interval = 86400 second Please press Enter to activate this console. |
你好,我觉得你这个问题应该就是arm和dsp的cmem共享内存地址分配错误了,呵呵dvsdk单单在linux比起在android下使用简单多了,你的地址分配 loadmodules.sh 可以参考dvsdk目录下面的/dvsdk/codec-engine_2_26_02_11/examples/apps/system_files/OMAP3530/,然后关键是设好botargs 中的mem,我的
mem=68M@0x80000000mem=128M@0x88000000,预留了60M给dsp和arm共享通信,实际在loadmodules,sh申请了大概是10M,希望对你有帮助 可以参考http://community.csdn.net/ |
feiyu25 发表于 2019-8-23 14:27 忘了说下我的内存也是256M ,0x8到0x9也就刚好256,所以你去外面申请当然没用根本没有空间了啊,这个我之前也干过这种傻事 |
feiyu25 发表于 2019-8-23 14:27 botargs 中的mem 在哪设置,是在开发板的源码里吗? 那需要重新编译内核并烧到板子上吗? |
feiyu25 发表于 2019-8-23 14:27 不好意思,我想问下,你是怎么设置botargs中的mem的 |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1888 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3645 浏览 4 评论
5031 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1734 浏览 1 评论
9368 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
664浏览 2评论
707浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
668浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1197浏览 1评论
1771浏览 1评论
GMT+8, 2024-4-24 01:38 , Processed in 0.706919 second(s), Total 72, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
