您好,是否可以通过以太网电缆连接控制B2902A和PNA-X(N5242A)?
或者GRIB接口对IC-CAP是强制性的? 奥列格 以上来自于谷歌翻译 以下为原文 Hello, Is it possible to control B2902A and PNA-X (N5242A) via ethernet cable connection? Or GRIB interfaces are mandatory for IC-CAP? Oleg |
3个回答
Hello Oleg,官方说来,目前不支持以太网连接。
但是我已经将它与PNA一起使用并且没有任何问题。 可以将PNA视为LAN接口,例如 添加接口>> lan“左括号”“pna的IP地址”“右括号”:“pna sicl ..often hpib7”例如:lan“left bracket”1.2.3.4“right bracket”:hpib7(其中左括号= =“[”等)此外,必须将PNA设置为期望通过以太网进行gpib通信。 我没有用B2200进行测试,但我希望它也可以工作,前提是它配置为通过以太网接受gpib。 如果您对这种方法感兴趣,尝试它应该没有任何缺点。 唯一的问题是,如果遇到一些与以太网接口特别相关的问题,则无法保证它会被解决,至少不会立即解决,因为它目前尚未得到官方支持。 如果您还有其他问题,请联系eesof_support@agilent.com。 我们在LinkedIn上也有一个IC-CAP用户组。 最好的问候Else 以上来自于谷歌翻译 以下为原文 Hello Oleg, Officially, the ethernet connection is not supported at this time. However I have used it with the PNA and have not had any problems with it. One can treat the PNA as if it were a lan interface e.g. add interface >> lan "left bracket" " ip address of pna " " right bracket" : " pna sicl ..often hpib7 " for example: lan "left bracket" 1.2.3.4 "right bracket" : hpib7 (where left bracket == "[" etc.) In addition, one must set the PNA up to be expecting the gpib communications via the ethernet. I have not tested it with the B2200, but I would expect it would likely work also, provided it was configured to accept the gpib via ethernet. If you are interested in this approach, there should be no downside to trying it. The only issue is that if you ran into some issue specifically related to the ethernet interface, it is not assured it would be addressed, at least not immediately, since it is not currently officially supported. If you have further questions, please contact eesof_support@agilent.com. We also have an IC-CAP User's Group on LinkedIn. Best regards Else |
victorlekwk 发表于 2019-8-21 08:34 谢谢! 以上来自于谷歌翻译 以下为原文 Thank you! |
不用谢! 我希望你能看出添加lan接口的语法。 此论坛发布工具会破坏实际语法,因此无法在此上下文中发布实际语法。 我希望你理解我的意思。 要查看示例语法,可以转到ICCAP Main: - * Examples * to * demo_features * to * 2_LINKING_TO_MEAS_INSTRUMENTS *然后加载* Link_ICCAP_to_GPIB_interface.mdl *,并查看* + README + *宏。 最好的问候Else 以上来自于谷歌翻译 以下为原文 You are welcome! I hope you can discern the syntax for adding the lan interface. This forum posting tool corrupts the actual syntax so that am unable to post the actual syntax in this context. I hope you are understanding what I mean. To see the example syntax, for adding a lan interface, you can go to ICCAP Main: - *Examples* to *demo_features* to *2_LINKING_TO_MEAS_INSTRUMENTS* and then load *Link_ICCAP_to_GPIB_interface.mdl*, and look in the *+README+* macro. Best regards Else |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-20 05:37 , Processed in 0.925291 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
