我正在尝试使用matlab记录我的U3606A的读数。
到目前为止,我已经能够通过创建VISA-USB连接来连接到设备,并且我能够让设备进行自检。 我试过fscanf无济于事。我也试图通过程序改变电压。 我将启动仪器然后连接到一个简单的电路并通过它发送1V电压。 当我尝试给出命令“fprintf(obj,'Volt 2')”时,它将电压改为0.感觉就像我改变输出一样进步,但是如何让它改变到我的指定值呢? 任何其中一个的帮助将不胜感激。 以上来自于谷歌翻译 以下为原文 I'm trying to record readings from my U3606A using MATLAB. So far I have been able to connect to the device by creating a VISA-USB connection and I am able to get the device to self test. I have tried fscanf to no avail. I am also trying to change the voltage through the program. I'll start the instrument then connect to a simple circuit and send 1V through it. When I try to give the command "fprintf(obj,'Volt 2')" it changes the voltage to 0. It feels like progress since I am changing the output, but how do I get it to change to my specified value? Any help with either one of these would be appreciated. |
2个回答
我没有使用过这个特定的乐器,但这里有编程指南的链接。
看起来您正在使用Matlab,您只需要使用适当的SCPI命令,这些命令就在本手册中列出。 如果您有任何问题请告诉我.http://cp.literature.agilent.com/litweb/pdf/U3606-90023.pdf 以上来自于谷歌翻译 以下为原文 I haven't worked with this particular instrument but here is a link to the programming guide. It looks like you are using Matlab correctly, you just need to use the appropriate SCPI commands and those are what are listed in this manual. If you have problems let me know. http://cp.literature.agilent.com/litweb/pdf/U3606-90023.pdf |
只有小组成员才能发言,加入小组>>
2082 浏览 1 评论
1846 浏览 1 评论
1700 浏览 5 评论
2563 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1547 浏览 4 评论
关于Keysight x1149 Boundary Scan Analyzer
350浏览 0评论
1386浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
262浏览 0评论
2248浏览 0评论
1103浏览 0评论
GMT+8, 2024-3-29 20:53 , Processed in 1.062620 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
