在双触发模式下,我在“冻结”的DSO1024A前面晃动。
无论我按什么按钮,如果我打开和关闭和打开示波器或拔掉它,它会保持冻结状态。 显示监视器周围的值(触发,敏感......),但显示屏上没有迹线。 无论我按什么按钮,键盘就死了。 有什么方法我把它恢复生机,某种类型的BIOS MASTER RESET? (该BIOS是最新的,这是一项新的收购,并且在过去的5个月里一直运行良好) 以上来自于谷歌翻译 以下为原文 I'm stcuk in front of a "frozen" DSO1024A in the dual trigger mode. No matter what button I push, if I turn the scope ON and OFF and ON or unplug it it remain frozen. The values around the monitor are displayed ( trigger, sensivity ... ) but no trace are on the display. No matter what button I push, the keyboard is dead. Any way I kick it back to life, some type of BIOS MASTER RESET ?? ( The bios is up to date, it's a new acquisition and had been running perfectly for the last 5 month ) |
1个回答
它可能类似于卡住按钮或松散的电缆。
重置BIOS可能无济于事,因为每次上电都会发生这种情况。 范围是否有效,然后停止? 如果你摇动它,里面有什么东西松动吗? 我会建议一些轻微的“打击式维修”。 如果这不起作用,则需要进行修复。 Al P.S. 冲击式维护涉及摇动,攻丝,撞击和/或拍打硬件 以上来自于谷歌翻译 以下为原文 It's probably something like a stuck button, or a loose cable. Resetting the BIOS probably won't help, since that happens on every power-up. Did the scope work at one point, then stop? If you shake it, is there anything loose inside? I would suggest some light to moderate "percussive maintenance". If that doesn't work, a repair is in order. Al P.S. Percussive Maintenance involves shaking, tapping, hitting and/or slapping the HW |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 20:48 , Processed in 1.686565 second(s), Total 76, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
