您好,我们希望使用Agilent 34970A / 34901A在测试过程中记录电子盒的温度。
我们的客户已在设备中嵌入了一些热电阻,但这些温度为25欧姆,温度为25欧姆,测试值= 3695K。我们已经在用户手册中查明了它表明Agilent 34970A / 34901A只能使用2.2k,5k和10k热敏电阻。 这是真的? 我们不能使用我们的15欧姆热敏电阻吗?我们知道我们可以监控电阻,然后对值进行后处理以提取温度,但是能够使用附带的软件实时查看实际温度非常有用(可以 完成我们的10k热敏电阻)。任何想法是否可行或可能的方法来克服这个问题?谢谢& 最好的祝福 以上来自于谷歌翻译 以下为原文 Hello, we want to use our Agilent 34970A/34901A to log the temperatures of a electronic box during a test. Our customer has embedded some thermistances in the device, but these are 15ohm @25ºC with a beta=3695K. We have checked in the user manual and it states that the Agilent 34970A/34901A will only operate with 2.2k, 5k and 10k thermistors. Is this true? Cannot we use our 15ohm thermistors? We understand that we could monitor the resistance and later postprocess the values to extract the temperature, but it would be very useful to be able to see the actual temperature in real time with the included software (as can be done with our 10k thermistors). Any idea about if this is feasible or possible ways to overcome this problem? Thanks & best regards |
4个回答
正确的是,您很可能不得不对电阻测量进行一些后处理。
热敏电阻的β值是从复数Steinhart-Hart方程得到的常数。 您可以使用任何想要进行转换的软件/编程环境。您可以将Benchlink Datalogger pro与仪器配合使用。 它具有从Steinhart-Hart方程计算温度的数学能力,免费版本没有。 如果您希望我发布它,我有一个BLDL Pro示例。 BLDL确实可以实时进行计算,因此您可以在PC上实时查看计算出的温度。 仪器本身只会显示阻力值。无论您想选择哪条路径,我都乐意帮助您前进。 以上来自于谷歌翻译 以下为原文 Correct, you will most likely have to do some post processing on resistance measurements. The beta value for a thermistor is a constant derived from the complex Steinhart-Hart equation. You can use any software/programming environment you want to do the conversion. You could use Benchlink Datalogger pro in conjunction with your instrument. It has the math capability to calculate the temperature from the Steinhart-Hart equation, the free version does not. I have a BLDL Pro example for this if you would like me to post it. BLDL does make the calculation in real time, so you will see the calculated temperature in real time on the PC. The instrument itself would just display the resistance values. Whichever path you wish to choose, I will be happy to assist getting you going. |
4864165sas 发表于 2019-8-6 07:58 我正在寻找Agilent 34972A用于将电阻测量值转换为温度值的方程式。 我们正在使用Data logger pro并输入我们自己的方程式,但如果安捷伦使用的方程式足够接近,我们可能不必将自己的方程式用于不同的热敏电阻。 谢谢。 以上来自于谷歌翻译 以下为原文 I am looking for the equations that are used by the Agilent 34972A to convert the resistance measurements to temperature values. We are using Data logger pro and inputting our own equations, but if the equation that the Agilent uses is close enough, we might not have to put our own in for different Thermistors. Thanks. |
ujsdfweer 发表于 2019-8-6 08:14 34970A使用快速分段线性拟合来得到Steinhart-Hart方程的表数据,用于支持的热敏电阻类型。 此拟合精确到0.1 C.对于实际的热敏电阻精度,您必须联系制造商。 精密校准的热敏电阻非常昂贵。 支持热敏电阻分类:2.252欧姆,在25℃的热敏电阻:44004和44033 5千欧,在25℃的热敏电阻:44007和44034 10千欧,在25℃的热敏电阻:44006和44031 *第一模型是+/-单元之间0.2C下互换。 第二个数字是+/- 0.1 C可互换。 请注意,“可互换性”与“准确性”不同。 当您查看两个探针之间的协议时,可以应用互换性。 请参见34970A / 72A和34410数据表中的脚注9:[9]对于总测量精度,请添加温度探头误差。 44006和44031热敏电阻之间的差异是+/- 0.2C互换性与+/- 0.1C互换性。 44000_THERMIS_ELEMENTS.pdf195.8 KB 以上来自于谷歌翻译 以下为原文 The 34970A uses a fast piecewise linear fit to the table data derived from the Steinhart-Hart equation for the supported thermistor types. This fit is accurate to 0.1 C. For the actual thermistor accuracy, you will have to contact the manufacturer. Precision calibrated thermistors are very expensive. Supported thermistor classifications: 2.252 ohm at 25C thermistor: 44004 and 44033 5 Kohm at 25C thermistor: 44007 and 44034 10 Kohm at 25C thermistors: 44006 and 44031 * First model is +/-0.2 C interchangeable between units. Second number is +/- 0.1 C interchangeable. Note that "Interchangeability" is not the same as "accuracy". Interchangeability applies when you are looking at the agreement between two probes. Please see footnote 9 in the 34970A/72A and 34410 Data Sheets: [9] For total measurement accuracy, add temperature probe error. The difference between the 44006 and 44031 thermistors is +/- 0.2C interchangeability versus +/- 0.1C interchangeability. 附件
lanziji 发表于 2019-8-6 08:31 谢谢Tom,这正是我想要的。 周末愉快。 保罗 以上来自于谷歌翻译 以下为原文 Thanks Tom, That is exactly what I was looking for. Have a great weekend. Paul |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2574 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1557 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-18 07:14 , Processed in 1.334541 second(s), Total 73, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
