2个回答
> {quote:title = rogerfreeman写道:} {quote}>你好>>简短版本:请有人解释我如何实现相对于我为了实现lambda / 4转换而捕获的现有s1p数据文件的相位偏移
每个数据点? 我只是在“度”栏中添加“90”吗? >>简短回答是肯定的; 这就是offeset的作用,将所有角度改变相同的量。 这有点不常见。 更常见的是改变电延迟,这意味着相位随频率而增加。 这就是你用模拟线得到的,它在中心频率为90度(假设中心频率为1/4波长)。 以上来自于谷歌翻译 以下为原文 > {quote:title=rogerfreeman wrote:}{quote} > Hello > > Short version: Please could someone explain how would I implement a phase offset to an existing s1p data file I have captured in order to effect a lambda/4 transformation for every data point? Do I just add "90" to the "degrees" column? > > Short answer is yes; that is what phase offeset does, change all angles by the same amount. This is somewhat uncommon. A more common thing to do is to change the electrical delay, which means that the phase change increases with frequency. That is what you get with a simulated line, where it is 90 degrees at the center freq (assuming a 1/4 wave length at the center freq). |
非常好 - 谢谢乔尔博士。
是的,我认为lambda / 4电气延迟就足够了,但是,正如我后来所知,你只能在延迟真正为90度的一个频率上旋转90度。 在测量谐振器并且想要获得对未调节的短位置的s1p响应的情况下,所有点需要被相等地旋转,因此不使用VNA上的电延迟,而是使用相位偏移。 谢谢你的澄清 - 我现在有了一个脚本,可以帮助我正确地转换所有的s1p跟踪,一切都很顺利。 以上来自于谷歌翻译 以下为原文 Excellent - thanks Dr Joel. Yes, I thought that a lambda/4 electrical delay would suffice but, as I later realised, you only rotate by 90 degrees for the one frequency where the delay truly is 90 degrees. In the case of measuring a resonator and wanting to get the s1p response to the untuned short position, all points need to be equally rotated and hence electrical delay on the VNA is not used but phase offset is used instead. Thanks for the clarification - I've now got a script together that will help me transform all of my s1p traces correctly and all is well. |
只有小组成员才能发言,加入小组>>
2091 浏览 1 评论
1850 浏览 1 评论
1707 浏览 5 评论
2577 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1558 浏览 4 评论
497浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
355浏览 0评论
1405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
268浏览 0评论
2254浏览 0评论
GMT+8, 2024-4-19 17:19 , Processed in 1.082836 second(s), Total 72, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
