扫一扫,分享给好友
大家好,
我是非常新的编程,特别是PSoC。我是一个工科学生,必须学习M3皮层,我选择PSoC作为我的解决方案。 我有一些问题,我无法从任何网络工作。我正在接收错误信息: “该设备已被识别,但PSoC Creator不支持此时使用它” 我从这里开始工作:www. CyPress。 我复位设备(拔出它从USB电缆,没有外部电源连接,只是从USB电缆),也重置电脑。尽管这些尝试我仍然有同样的错误。 有什么新资料吗? 以上来自于百度翻译 以下为原文 Hello All, I am very new to programming and expecially the PSoC. I am an Engineering Student and must learn the M3 Cortex, I chose PSoC as my solution. I am having a few problems which I can not resove from any web work through. I am recieving the error message: "this device was recognized but PSoC Creator does not support using it at this time" I followed the work around from here: www.cypress.com/ and here: www.cypress.com/ I reset the device (unplugged it from the USB cable, no external power is connected, just from the USB cable) and also reset the computer. Dispite these attempts I am still getting the same error messege. Any recomendatons? |
3个回答
您在PSoC3论坛没有一个ARM处理器,而应该使用一个拥有一个ARM M3 CPU的PSoC5 LP。
你需要创造者3。PSOC 5 LP(“LP”)的开发工具包是必不可少的! 请检查您的版本和资源。 鲍勃 以上来自于百度翻译 以下为原文 You are here in PSoC3 forum which does not have an ARM processor, Instead you should use a PSoC5 LP which has got an ARM M3 CPU. You need Creator 3. and a development kit for PSoC 5 LP (the "LP" is essential!) Please check your version and resources. Bob |
如果你有一个旧的PSoC 5板,而不是PSoC 5 LP,那么最后
版本的创建者支持2.2。所以你要么学习 旧的工具或升级板。 如果你有一个旧的板,它可能会升级到 5LP板 HTTP://www. CyPress?COM/?RID=51577 问候,Dana。 以上来自于百度翻译 以下为原文 If what you have is an older PSOC 5 board, not PSOC 5 LP, then last version of Creator to support that was 2.2. So either you learn with the older tool or upgrade the board. If you have an older board it might be possible to get it upgraded to the 5LP board - http://www.cypress.com/?rID=51577 Regards, Dana. |
你是说创建者3.1会支持PSoC5(不是5LP)设备吗?
以上来自于百度翻译 以下为原文 Do you mean that Creator 3.1 will bring support for PSoC5 (not 5LP) devices back? |
只有小组成员才能发言,加入小组>>
716个成员聚集在这个小组
加入小组1901 浏览 1 评论
1652 浏览 1 评论
3405 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1568 浏览 6 评论
1380 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
186浏览 2评论
183浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
321浏览 2评论
348浏览 1评论
62浏览 1评论
GMT+8, 2024-4-24 04:49 , Processed in 0.406641 second(s), Total 43, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
