这是关于avnet aes-s6dev-lx150t-g。
该电路板的原理图显示(https://www.em.avnet.com/Support ... -sch-revd090810.pdf)与FMC连接器的FPGA连接。 FMC2连接器引脚D8和D9对连接到2个不同的FPGA引脚对,导致两个FPGA引脚短路如下。 FMC2引脚编号网名FPGA引脚 D8 FMC2_LA01_CC_P V11,V12(短路) D9 FMC2_La01_CC_N W12,V10(短路) 此外,它注意到FMC连接使用FPGA上的2个引脚,但FMC引脚C22和C23转到bank 1,而所有其他FMC连接器转到bank 2.是否可能实际使用其中一个短路引脚对 而不是这个银行1连接。 请尽快确认。 以上来自于谷歌翻译 以下为原文 This is in regards to an avnet aes-s6dev-lx150t-g. The schematics for this board show (https://www.em.avnet.com/Support ... -sch-revd090810.pdf) FPGA connections to the FMC connectors. FMC2 connector pin D8 and D9 pair are connected to 2 different FPGA pin pairs resulting in the two FPGA pins being shorted as follows. FMC2 Pin Number Net Name FPGA Pin D8 FMC2_LA01_CC_P V11, V12 (shorted) D9 FMC2_La01_CC_N W12, V10 (shorted) In addition its noted that the FMC connection uses 2 pins on the FPGA but, FMC pins C22 and C23 go to bank 1 whereas all the other FMC connectors go to bank 2. Is it possible that one of the shorted pin pairs should actually be used instead of this bank 1 conneciton. Please confirm ASAP. |
1个回答
它是安富利制造板。所以我建议你在这里与你的航空公司联系,他会是一个合适的人来指导你。
您可以从以下链接http://www.xilinx.com/company/sales/ww_disti.htm找到它们的联系方式(该链接可以指向http://www.xilinx.com/company/contact/auth-disti) -table.htm) _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他论坛用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 It is Avnet make board. So I would recommend you here is to talk to your Avnet FAE he would be a right person to guide you on this. You can find contact details of them from the following link http://www.xilinx.com/company/sales/ww_disti.htm (That link can guide to http://www.xilinx.com/company/contact/auth-disti-table.htm) ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
只有小组成员才能发言,加入小组>>
2162 浏览 7 评论
2605 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2077 浏览 9 评论
3149 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2192 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
416浏览 1评论
1517浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2175浏览 0评论
507浏览 0评论
1633浏览 0评论
GMT+8, 2024-4-23 14:18 , Processed in 0.922157 second(s), Total 44, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
